Reply
      07-10-2010, 01:49 PM   #1
Shipkiller
Shipkiller's Avatar
Drives: 2008 Z4MC & 2003 Z4 Roadster
Found an issue with my Cool Carbon Brake Pads
Installed my alarm today. While under the car, I noticed that the left rear inner pad was not right. It seems that the backing plate that is riveted to the pad got all fubar...
Pulled the caliper off. Cleaned everything off and removed the backing plate.
Regreased everything and put it back on, minus the backing plate.
We will see how this holds up.
First image is the pad with the issue.
Second image is a good pad on the right side, rear.
Third image is the pad off the car.
Shipkiller is offline   United_States
      07-10-2010, 02:28 PM   #2
Finnegan
Finnegan's Avatar
Drives: Sapphire Black/Black Z4Mc
EAS? I'd give them a ring or PM....see what they can do for you.
Finnegan is offline   United_States
      07-10-2010, 08:16 PM   #3
inTgr8r
inTgr8r's Avatar
Drives: 07 M Coupe
Thanks Ship, I'll keep an eye on mine.
Alpinweiss '07 M Coupe •Eisenmann Sport-Ceramic Black•Diablo-X•Fabspeed Headers•VRS Hyper-Narrow rear wing•Autosolutions SSK•APR splitter•Tekarbon headlights•StrongStrut STB•KW Clubsport•Poly FCAB/RTAB•Volk Racing G2•Direzza ZII•Stoptech BBK c/w Cool Carbon pads
inTgr8r is online now   Canada
      07-11-2010, 07:40 PM   #4
mousitch
Dark Sider
mousitch's Avatar
Drives: 2008 Space Gray Z4MC
Send a message via Yahoo to mousitch
So is the backing plate loose and shifted? Darn that could be really bad.
2008 Space Grey M Coupe-RPI Scoop-Gruppe M CAI-Eisenmann Race Cans-RE X-pipe-ECU Remap-H&R Sport springs-Zeck CDV-Stock Gloss black powder coated wheels-LED Tekarbon Angel Eyes Project-Michelin Super Sports-Hardwired Escort 9500ix-BMW CCA Member-ST Louis Chapter
mousitch is offline   United_States
      07-12-2010, 01:39 PM   #5
david @ eas
david @ eas's Avatar
Drives: BMW
This is not the backing plate that has shifted but only the anti-noise shim. As stainless steel is used, this shim also provides a heat barrier that is roughly 3X that of a conventional steel shim. The CC shim version is both staked on in 2 places and additionally bonded on. The final bonding takes place with the heat generated during the bedding process. The shim coming loose is not a usual occurrence, but can happen rarely on any manufacturers product.
This is by no means a safety concern but it can be a nuisance.
Each time the brakes are applied, there is always a slight rotational force between the piston and the brake pad/Shim interface. It appears that there may not have been noise coating or caliper grease applied to the piston contact surface (as recommended) which would minimize the rotational forces between the surfaces during the final bonding process.
Please PM me and we can discuss further.
David ///M | european auto source (eas)
david@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 x33 | ca: 714.369.8524
Blog | YouTube | facebook | twitter | flickr
david @ eas is offline   United_States
      07-12-2010, 04:53 PM   #6
Shipkiller
Shipkiller's Avatar
Thanks for the info. I removed the shim, cleaned everything up, re-lubricated the pad and reinstalled. Does not seem to affect operation, nor did I expect it to.
Thanks for the quick update.
      07-12-2010, 05:47 PM   #7
david @ eas
Drives: BMW
Sure thing. Let me know if everything works out in the future w/ those pads
Reply
Forum Jump
