      10-04-2012, 03:43 PM   #111
Coenz4
Drives: Z4
Hey Guys,
this is my first post.. sorry for that but you have to start somewhere, right?
I own a 3.0 Roadster from 2003.
I want to have 2 sets for my car, stance and competition.
I have a question about the stance set.
I've my eye on a set of enkei's but the sizes are a bit off.. I think!
I am on coilovers with camber plates...
Can I fit 18x10+25 all-round with the right rubber and camber?
Do you please have any advice on this?!
Obviously I'll share the information in/on here.
Thanks in advance!
greets from The Netherlands!
      10-04-2012, 06:25 PM   #112
3002 tii
3002 tii's Avatar
Drives: E86, E90, F25
Originally Posted by Coenz4 View Post
Hey Guys,
Thanks in advance!
Definitely will not work.
Active Autowerke | Supersprint | TC Kline | Ground Control | MFactory | Volks | Nitto
NASA NE TT5 #821
      10-05-2012, 02:34 AM   #113
Coenz4
Drives: Z4
Just the fronts right?!
With the right amount of stretch and camber, still not going to work?
what would you advice then for the MAX width (because of lip or camber) and offset?
I've been reading forums for weeks now and cannot figure out what to do..
      10-05-2012, 08:00 AM   #114
Coenz4
Drives: Z4
if this fits an Z4M...
http://www.zpost.com/forums/showthread.php?t=737954
Why wouldnt 10J+25 fit with a fair amount of camber + stretched tyres on an NON M roadster?
      10-05-2012, 02:05 PM   #115
Coenz4
Drives: Z4
One more question...
will 18x9J+30 fit better?
      10-08-2012, 02:11 AM   #116
Coenz4
Drives: Z4
I think Iíll go for
18x9+25 front 225-40-18
18x10+25 rear 225-40-18
Anyone running the same specs or almost?
      10-08-2012, 08:45 PM   #117
pmmjarrett
Retired Paratrooper
pmmjarrett's Avatar
Drives: 2006 BMW Z4 3.0i Sport
The M Coupe and M Roadster does not have the same rear axle we do on the non M cars, The rear axle is narrower which is why they have a more agressive offset on their wheels, not sure if or what they changed up front other than the brakes are different.
I think Iíll go for
Not me, I don't want that Mexipoke look.
Front 18x8 ET35 225/40R18
Rear 18x9 ET35 255/35R18
Stock specs all around on alignment, good fit, no rubbing. I think fronts could come out a bit more but rear is pretty close to flush. Tempted to put an 18x9 ET35 up front too and square her up with 255/35R18 all the way around. I really like how the 255 fits a 9" wheel but the 225 on an 8 looks stretched a bit.... Really like the 3" lip on the 9" wheels too.
      10-08-2012, 09:48 PM   #118
3002 tii
3002 tii's Avatar
I think Iíll go for
225 on 9" will look stretched
225 on 10" would just be dangerous
NASA NE TT5 #821
      10-10-2012, 03:16 PM   #119
Coenz4
Drives: Z4
You are right guys..
I am about to order 18x9.5+31 fronts (3" lip)
and for the rear side 18x10.5+35 (4" lip)
the rears won't be with a 225tyre tho.. probably 245-40-18
check this out :
This is 18x8+20 225-40-18
Which make my 18x9.5+31 poke about 8mm (without any camber, but I'll be using camber plates)
This is 18x8.5+15 255-40-18
Which make my 18x10.5+35 poke about 6mm (without any camber, but I'll be setting camber)
So thats where we stand right now!
      10-10-2012, 03:32 PM   #120
Coenz4
Drives: Z4
btw.. whats the real difference between the M and NON M?
just a slight difference according to this: http://www.bmwz4roadster.net/bmw_z4_specifications.htm
      10-18-2012, 01:16 PM   #121
wynnstuff
wynnstuff's Avatar
Drives: 2005 Z4 2.5l
Hi all, I'm looking to replace my OE '05 Z4 rims. I read these posts about sizing the wider rims and tires but no talk on the bolt pattern. If I am looking at used rims how can I know if they will fit my Z? Such as this past from an add "4 Rial Salerno rims 17x8 ET 20 silver made in Germany with TPMS Sensors and valves to fit E60 535,528, 528xi 2006-2009" with "4 Dunlop Wintersport 3D 225/50-17 runflats mounted." Will these rims fit the Z4 and whatís the result of using these tires. Looking for a winter run only tire in my Seattle area then put my summer tires on. -Thanks
aspire to inspire before you exspire!
      10-19-2012, 09:04 PM   #122
StigJ
StigJ's Avatar
Norway
116
Drives: '06 Z4 Coupe & '14 F30
Ok, Ill post a little update even that I do not know the algnment.
This is how it sits right now.
And this is how it sits during a little racing
Im not really sure but I think this is the setting I run now:
The wheel/tire setup is:
Front: 235/35 on 8.5x19 ET34
Rear: 265/30 on 10x19 ET41
Tires are Michelin Pilot Super Sport.
It rubs a little in the front when pushing really hard in corners.
Also had 3mm spacers just to test in the rear (ET38). Then it rubbed a little bit on the right tire.
Suspention is OEM -Tech shocks with 35mm H&R springs.
Handles great!
Had this setup and tires for two seasons now. Driven aprox. 15.000km including some trackdays. More treads left but I think I need new front tires some time next year.
I think I will try Michelin Pilot Sport Cup next time.
      10-21-2012, 02:25 AM   #123
Matched88
Drives: 2003 2.5l Manual
Ok, i have a question for you guys. i have been researching for a week or so now on the new wheels i would like to get to upgrade form these 16x7s when my tread is up. the wheel im wanting to get is 18x9.5 and want to run it square. now my question is what would be a good tire size for the meaty look, pretty much in essence an 18" version of 255/40/17x9.5. Im gonna want to run Conti DWS and was looking at some pics of 275/35. I also would be at stock height when i get this setup, i already know im gonna have to buy spacers to make up for the offset i cant get from the get go.
      10-22-2012, 03:04 PM   #124
3002 tii
3002 tii's Avatar
Any reason why you insist on going with a narrow tire? Even 245 is narrow for a 10.5. Are you trying to go for the stretched look?
NASA NE TT5 #821
      10-22-2012, 03:09 PM   #125
3002 tii
3002 tii's Avatar
The equivalent of a 255/40-17 in terms of maintaining overall diameter is a 255/35-18. However you may not achieve the same meaty look as you would get from a 255/40-17. You'd need a taller profile but anything taller than a 255/35-18, ie 255/40 will most likely rub up front.
And 18x9.5 square is going to be tough for the fronts on stock suspension. For a street car, don't see the benefit of going that wide on the front especially without a suspension to go with it. If you want just the meaty look, I say go staggered with narrower tires up front and run a 235/40 say on a 8.5" wide front and 265/35 on a 9.5" rear. Of course we haven't even mentioned offsets...
NASA NE TT5 #821
      10-23-2012, 01:35 AM   #126
Matched88
yeah the wheel i found was 18x9.5 ET45 and was gonna use spacers to make up for offset instead of doing staggered, but i guess i could see if the wheel comes in that width also. I originally wanted a 17x9 squared set up but couldnt find wheels i liked so had to give that up. It would just be stock suspension until i bought coilovers. So now i guess i will do 8.5ET45 up front and 9.5ET45 in rear and get spacers to adjust, because the next offset is a 30 in the wheel i want and not sure if that offset would fit the rear or front with those sizes.
      10-23-2012, 07:56 AM   #127
3002 tii
3002 tii's Avatar
8.5/9.5 sounds like it should work so not sure why you want spacers "to make up for offset"... Also keep in mind while a 235 is fine width wise it may rub up front fit to it being an extra third of an inch taller. I say it may because that was jt experience but I also had a slightly more aggressive offset than yours at the time. YMMV
NASA NE TT5 #821
Last edited by 3002 tii; 10-23-2012 at 07:51 PM. Reason: dunno why the barf emoticon showed up lol
      10-23-2012, 07:16 PM   #128
Matched88
Oh I wasn't sure if ET45 was acceptable as is or was going to need spacers or not, that is why I said.
Appreciate your advice, Been trying to figure all this out over the passed 2 weeks and finally decided to ask, hah. hopefully I will be able to get them soon and post up some pics.
      10-23-2012, 07:50 PM   #129
3002 tii
3002 tii's Avatar
If both front and rear are the same offset, but rear is 1" wider, you wouldn't need spacers in the rear "to adjust". It'll already sit wider, and spacers would only further push out the track. You might use spacers in the front if the tire were so wide and wheel offset too high (high offset means it sits closer INwards), that the tire was rubbing against your suspension. Then you'd put a small spacer up front to push the wheel out and clear your suspension. But a 8.5/9.5 combo both et45 should be fine.
I'll just leave one final thought, are you going for looks or performance? If it's just looks, I say ditch the 8.5" front because whether you run a 235 or 255, you may risk rubbing. The 235 might be too tall and the 255 might be too wide. The best tire width would honestly be a 245 but a 245/30 will actually sit lower than stock. Also a 225 on a 8.5" will be a little stretched so 225 on 8" is perfect and it won't rub. If you want the flush look, just pick a lower offset, ie mid to hi 30's. On the rears, you have more room to play but I'd go 9" wide with a 255. Again for the flush look, go with offset of mid to high 30s. Sure you can go 9.5" but with all that extra traction in the rear (as compared what you'd be running up front) it might just induce more understeer.
If you're going for performance, wider up front and running square makes sense. But that's where it gets really tricky of knowing what the right offset, wheel width and tires are. And the only way to get it right AND get the performance benefit out of it is to add negative camber (either through lowering the car or getting camber plates). And if you're not ready for that kind of investment/headache, I say stay away from the square or wide up front.
My 2 cents... I'm sure other wheel/tire experts can chime in or correct anything above.
NASA NE TT5 #821
      10-26-2012, 05:09 AM   #130
Matched88
Not tracking as of now, later on when fully paid off (bought used not too long ago) then it will be a fully dedicated for track. but as of now just really going for something I like.
I have been comparing tire sizes and offsets and I think i'm on as of now 245/35/18x8.5 et40 for the front and 275/35/18x9.5 et40-45(somewhere around that).
(edited part): bah and of course never check the tires i wanted first (they don't have that size for the front). think I could slide the front in as a 245/40 or a 255/35?
      10-30-2012, 01:35 PM   #131
Denton
Drives: '11.5 328xiT/6 - '99 M3/2/5
E9x M3 Style 219 on non-M Coupe?
Front: 8,5 x 18 ET29
Rear: 9,5 x 18 ET23
I'd be on Eibach Springs, no camber plates but doing the strut bolt trick for a bit more camber. Not sure on tire size that you would run?
      10-30-2012, 01:42 PM   #132
v3.2mc
Not a New Member
v3.2mc's Avatar
Rear: 9,5 x 18 ET23
no way those rears will fit. the fronts would work with camber plates.
also, what strut bolt trick are you referring to? i knew there was a kit for the ///m's, but it won't work on the rest.
