FORUMS
- 5
| 07-21-2012, 10:01 AM | #89 |
![]() ![]() Drives: flat out Join Date: Apr 2008
^^ nice, I could've swore those were either 35 or high 30's like 37-38mm offsets.
![]() Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance Click here for my track videos |
| 07-21-2012, 11:03 AM | #90 | |
![]() Drives: 2007 Alpine/Black 3.0Si Coupe Join Date: Sep 2011
![]() Love the look of the RXII and since it's long discontinued was tough to find a set. Still battling TPMS since it was designed before these damned sensors. |
| 07-24-2012, 04:17 PM | #91 |
So many cars,so little time....
Drives: ACS5 Silhouette E34,Z4si-coupe Join Date: Mar 2009
SSR GT-10
While I do love the BBS lace design, it just shows up on almost EVERY Z4 I see these days. Its almost the new STOCK look. Perhaps they should have come from BMW this way..
![]() They are a engineering perfect design in my opinion and I LOVE your cars that run them. ![]() So in an attempt to be different....I continued to look for a strong and light forged 3-piece wheel and bought these Japan made SSR GT-10's . -19x9 et43 -245 -19x10 et24 -275 I'll need to slightly roll the fender arch in the rears to avoid max compression rubbing. Fronts are fine. These are the same offsets as I ran with my previous 19" wheels with the rears being 9.5" wide. They also need a full restoration due to salt air in Japan and curb rash. ![]() I have ordered CF -(blk. & Slvr.) center caps like I used on the Axxia Penta's to match my hood,trunk and side roundels. What do you folks think ? Certainly not the common Z4 look....or German for that matter....but my roots do stem from the JDM world after all. ![]() I'm thick, er.. thick-skinned .....so comment away,lol. ![]() -(short vid) http://s21.photobucket.com/albums/b2...t=IMG_0139.mp4 -(Stills) ![]() ![]() ![]() Last edited by Twisted Six; 07-24-2012 at 04:30 PM. Reason: added still pix |
| 08-11-2012, 01:59 AM | #93 |
thinking of replacing my style 107 18ers with the bmw performance 313 19ers.
will i have a problem with rubbing? spec for the 313 19ers are 37F and 39R. anybody with this setup? i'm on eibach pro kit and bilstein sport on my 2003 z4 roadster |
| 08-30-2012, 09:29 AM | #94 |
Not a New Member
Drives: with both hands and both feet Join Date: Mar 2012
for any interested... the X1 staggered setup is perfect for the non-///m z4's.
front: 8.0 et30 rear: 9.0 et41 stock tire widths style #'s: *18's- 322 323 355m *19's- 225m 311 324 465
| 09-04-2012, 09:09 PM | #95 |
![]() Drives: 2004 Z4, 20011 X5 5.0 Join Date: Dec 2006
Fit
I am looking at the following setup to buy but I don't think the offset will work. Can anyone confirm either way? Thanks
BRAND: VMR STYLE: v710 DIAMETER F: 19x8.5 et 25 wrapped in Yokohama S-Drives (235/35) R: 19x9.5 et 22 wrapped in Yokohama S-Drives (245/35) |
| 09-04-2012, 10:09 PM | #96 | |
Then your offsets are way too aggressive, assuming this is for a non-M Z4 (your info says you have a 335i). For an 8.5 front, you'll want an offset of high 30's to low 40's. For a 9.5" rear, you really don't want to go lower than offset of 35
![]() Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance Click here for my track videos Last edited by DSC_OFF; 09-12-2012 at 07:51 AM. |
| 09-05-2012, 04:17 AM | #97 |
Does having the M sport suspension option on a 3.0si change the setup to M hubs/rims etc?
I looked at some great 18 X 8 et35 225/40 R18 18 X 9 et 35 255/35 R18 today and the guy at the shop should fit fine, not rub or stick out the fender. Thanks heaps for all the posts above, this has been an education! |
| 09-05-2012, 08:04 AM | #98 | |
| 09-05-2012, 08:54 AM | #99 |
Thanks for the response. I now have an 04 Z4 and looking for a new setup as the car has the stock 17" which look anemic. I like the look of the M6 replicas. What would be the ideal size and fitment if I can find them? Thanks. I prefer to buy a set from a forum member but I am struggling with fitment so I may need to go new. I am also looking at a set of 336 189 Sport wheels and tires but I am not sure they fit and I cannot find any pictures of a Z4 with these wheels on them. Thanks again for the repsosne.
| 09-12-2012, 08:01 AM | #101 |
Apex Arc8 17x9.5 et35 square, Hankook RS-3 255/40. Lowered approx 1" all around, camber plates and 5mm spacer used up front. This seems like the max you can push on our cars. NO rub during normal driving, rubbing front right liner on the track.
| 09-12-2012, 08:33 AM | #102 | |
Not a New Member
![]() i still can't believe you got those to fit. you must drive in an alternate universe where fender liners magically vaporize when tires approach them because the unicorns that made them said it was ok and don't be sad rainbow house-sized mushroom goatboy faerie dust moon.
| 09-12-2012, 09:12 AM | #103 | |
| 09-12-2012, 10:25 PM | #105 | |
HAHAHAHAA
| 09-24-2012, 02:33 AM | #106 |
So the 313 18inches are ordered. But i gotta wait 4-5 weeks ARGH!!
But, can anyone tell me what is printed or stamped on the 313 rims on the inside etc, so that i confirm that when i get them through the 3rd party company i had to order from that they are OEM legitimite. Thanks heaps in a advance. (Also ordered the BMW Performance brake kit. Should look great, and be somewhat better stopping power too with the stainless steel brakelines i get as well). |
| 10-01-2012, 10:16 AM | #107 | |
2006 330i, TSM, Black, manual, sport
Drives: E90 330i, E86 Z4 3.0si Join Date: Nov 2005
We picked up a 2007 3.0 Si Coupe and want to get the largest R-comp we can on it. I'm going to use my Enkei RPF1 (18x8.5 et40) square setup. Currently, I have BFG R1 in 245/40. They clear my e90 withouth any issues at all. Do you think we'll clear them on the Z4? With you running a 17x9.5 up front, I have a feeling it should work. Do you think a 265/35 BFG R1 will clear? Of course trimming fender liners won't be an issue since it'll be a race car.
2006 330i, TSM, Black, Sport, JIC Cross Coil-Overs, UUC Sways, 18" Advan RS, Mich PSS 255/265, Custom Alcantara M-tech steering wheel, VAC pedals, Rogue shifter, M-Tech front, CF emblems, Dinan TB, Intake, exhaust, strut bar, Stoptech BBK, LSD, M3 susp., LUX 5, CF Hood and CSL, Sparco Seats, AA tune, CF Roof
| 10-01-2012, 10:31 AM | #108 | |
Btw as your car progresses and you get to the point of installing a cage, let me know. I'm thinking about doing a half cage but chances are you'll beat me to it so it'd be good to know what's involved, who you went with, etc. Last edited by DSC_OFF; 10-01-2012 at 10:38 AM. |
| 10-01-2012, 11:59 AM | #109 | |
Unfortunately, BFG doesn't make a 255/35 R1, so they go from 245/40 to 265/35. We're crossed who is going to be doing the cage right now. Either we have Chris at Bimmerworks do it slowly over several weeks or have a local shop do it in two days and just pay them. It's about $1,500 for a full - NASCAR style cage. I'm not sure how much a half cage will be, but would be excellent for harnesses to hold you in place and added safety.
| 10-01-2012, 12:36 PM | #110 | |
| Bookmarks |
| Thread Tools | Search this Thread |
