Reply
      05-22-2011, 12:10 PM   #45
Ferus
Drives: Z4
Great information. Has been helpful.
Does any one know the offset on factory "M" wheels -COMPARED TO- offset on factory "non-M" wheels?
Ferus is offline   Reply With Quote
      05-22-2011, 03:16 PM   #46
v3.0si
v3.0si's Avatar
Drives: '08 Z4C 3.0si
it depends on which "non-M" wheel you have... different styles have different specs. here is comparo of style 203 to style 224m...
style 203...
front = 18" x 8.0" et47
rear = 18" x 8.5" et50
style 224m...
front = 18" x 8.0" et42
rear = 18" x 9.0" et30
if you were to put 224m's on a non-///m z4 (coming from 203's)...
front = 5mm MORE inner clearance (strut), 5mm LESS outer clearance (fender)
rear = 14mm MORE inner clearance, 26mm LESS outer clearance (sticks out from fender on stock suspension and no camber adjustment)
great website for wheel/tire size comparison...
http://1010tires.com/WheelOffsetCalculator.asp
http://www.1010tires.com/TireSizeCalculator.asp
v3.0si is offline   United_States
      06-21-2011, 12:22 AM   #47
Avicenna
Drives: 2008 Z4 Coupe 3.0Si
StigJ, what are the wheels on the bottom right pic of your sig?
Avicenna is offline   Reply With Quote
      06-23-2011, 07:56 AM   #48
v3.0si
v3.0si's Avatar
http://www.zpost.com/forums/showthread.php?t=506796
      06-24-2011, 02:32 AM   #49
StigJ
StigJ's Avatar
Drives: '07 Z4 Coupe 3.0Si
Originally Posted by tarheel91 View Post
Edit: By the way, if anyone could identify the wheels on my car, I'd greatly appreciate it. I've looked at pretty much every BMW composite wheel and it's not there. I can't find an aftermarket place that makes it either. Finding the maker would help getting specs a lot.
Those are replicas of Hartge Classic.
You can see that they are replicas if you study them and see that yours do not have the curve between the bolts.
The Hartges are 2 piece wheels and yours are one piece. The bolts are only for the looks.
Here are the real Hartge Classics
Hellrot '07 BMW Z4 3.0si Coupe
Sparkling Graphite '06 BMW 318i Touring
StigJ is offline   Norway
      01-02-2012, 09:51 AM   #50
aftercorbu
aftercorbu's Avatar
Drives: 2003 Z3 3.0
18" VMR VB3 Gunmetal 8.5 ET40 front and 9.5 ET45 rear with 225/40 and 255/35 V12's.
BMW_four_sm by aftercorbu, on Flickr
BMW_one_sm by aftercorbu, on Flickr
BMW_three_sm by aftercorbu, on Flickr
aftercorbu is offline   Reply With Quote
      01-02-2012, 11:07 AM   #51
dharper
dharper's Avatar
Drives: 2003 Z4 2.5i
Wheels: AvantGarde M33518x8 ET35 front, 18x9 ET 38 rear
Tires: Continental Extreme Contact DWS 225/45/18front, 255/35/18 rear
2003 Z4 2.5i Sport pkg stock setup
dharper is offline   Reply With Quote
      01-02-2012, 02:17 PM   #52
Aries326
Aries326's Avatar
Drives: 2008 Z4 3.0si
Thanks for sharing your wheel sizes. I've been researching tire and wheel sizes and I still can't make up my mind whether or not I get 18" or 19" rims. Most of you guys here seem to have 18" rims. Did you choose to get 18" for comfort? With 19", I'll need to get low profile tires which will roughen up the ride.
Right now I'm leaning towards getting a set of VMR 701s 18" with Hankook V12s 235s in front and 265s in the rear. This should be ok without spacers, I imagine.
Aries326 is offline   United_States
      03-12-2012, 10:28 AM   #53
lpapostolis
lpapostolis's Avatar
Drives: Z4 Coupe 3.0Si
Originally Posted by G1HQ View Post
Ive been holding off on posting pics but here are some from last summer ...
yes they are from an iphone..lol
apex arc-8 on oem (zhp)sport suspension.
front: 18x8.5 et 40
rear: 18x9.5 et 35
tire sizes are standard set up
front: 225/40/18-hankook v12
rear: 255/35/18-dunlop direzza star specs
both to be dunlop very soon..
http://www.zpost.com/forums/attachme...1&d=1303589474
are the rears inside or outside of the fender? do you have any rubbing issues?
lpapostolis is offline   Greece
      03-20-2012, 06:46 PM   #54
bassrebel
The Lazy one...
Drives: Z4 3.0i & E90 330i
I'm planning on getting 18x8.5 in the front and 18x10 in the rear...
tires up front are 225/40/18 and rears are 265/35/18
what would the recommended offset be for a setup like this?
I have stock suspension for now
bassrebel is offline   United_States
      03-20-2012, 07:22 PM   #55
v3.2mc
Not a New Member
v3.2mc's Avatar
for 8.5" up front you'll want between et40 and et35
the only offset that will work for 10" in back is et40, and you'll need a serious amount of camber. you'll also need a fat stack of cash for all of the tires you're going to go through because of wacky alignment.
v3.2mc is offline   United_States
      03-20-2012, 07:44 PM   #56
CJW2OO4
Drives: E86 3.0si
I personally chose 19s for these reasons
1. I dont beat on my car or track my car. If i did i would opt for smaller lighter wheels.
2. 19"s look and I personally think 18s look kinda small on the Z
3. Also from my experience used 18" aftermarket wheels like Iforged, HREs, and DPEs are much harder to find than their 19" counterparts.
CJW2OO4 is offline   United_States
      03-20-2012, 09:05 PM   #57
Aries326
Aries326's Avatar
1. I dont beat on my car or trace my car. If i did i would opt for smaller lighter wheels.
2. 19"s look and I personally think 19s look kinda small on the Z
I've totally changed my game plan. I will be keeping my 108s for now, get new tires for them when the RFTs are no good and I'll use these for auto crossing. I'll get a pair of 19" just for looks. What were the offsets on your 19" rims? Did you use pacers? What size tires did you go with? Thanks!
      03-21-2012, 06:44 AM   #58
CJW2OO4
Drives: E86 3.0si
I am not sure of the offset of my wheels. Sorry. The wheels were previously on a non m e46.
Did you use spacers?
no spacers.
IIRC 245/35/19 Front and 275/30/19 rear. The wheels were 19x8.5 Front and 19x10 Rear.
here is an old cell pic
      03-24-2012, 03:14 PM   #59
Resilient1
Drives: 951Z4
20" staggered with Coils?
Have anyone tried fitting 20" staggered with Coils on their E85 non-M?
Resilient1 is offline   Reply With Quote
      04-17-2012, 10:26 AM   #60
DSC_OFF
DSC_OFF's Avatar
Drives: flat out
Doubt it, would be too heavy and would make your calipers look non-existent imho...
Recaro | AST | Vorshlag | Quaife | Stoptech | Volks | Autosolutions | BMW Performance
Click here for my track videos
DSC_OFF is offline   United_States
      04-17-2012, 10:50 AM   #61
CJW2OO4
Drives: E86 3.0si
I agree with this.
20" wheels are heavy and tires are expensive. However If you have a bbk and a really aggresive look then you might be able to pull it off. IIRC there is a z4 from europe that is on black 20"s and looks good because of the acs body kit. On a stock car with just coils it will be too much. thats just IMHO
      04-23-2012, 09:05 PM   #62
renesis
renesis's Avatar
Drives: 2007 BMW Z4 3.0SI Roadster
anyone has specs for stock 108's?
(weight, width, offset)
2007 Z4 3.0SI Roadster
Sport Package, Premium Package, Bluetooth & BMW Assist
Black Sapphirre Metallic, Dream Red Interior
See it in pictures
renesis is offline   Canada
      04-23-2012, 09:16 PM   #63
v3.2mc
Not a New Member
v3.2mc's Avatar
great data set for BMW wheels...
http://felgenkatalog.auto-treff.com/
it doesn't appear they have the weights for that style though.
      04-23-2012, 10:19 PM   #64
renesis
renesis's Avatar
nice website.
So there goes:
8x18 225/40R18 ET 47
8,5x18 255/35R18 ET 50
See it in pictures
      05-14-2012, 12:34 PM   #65
Denton
Drives: 2007 Alpine/Black 3.0Si Coupe
Ordered 18x8 ET20/18x9 ET22 Style 5s off an E38 today, brand new. We'll see how they fit up and what tires I need to run.
Denton is offline   Reply With Quote
      05-14-2012, 12:39 PM   #66
v3.2mc
Not a New Member
v3.2mc's Avatar
you will struggle to get those to fit... the offsets are REALLY aggressive.
you'll also need centering rings.
Reply
Forum Jump
