      05-22-2010, 03:37 PM   #1
dekaliber
What the...jackpoints?
Is it me, or am I missing 2 jackpoints?
Here's what the back looks like:
Here's what the front looks like:
Looks like the rubber part of the jackpoint was removed at some point....or is this some sort of silly M feature? Both sides in front look like this.
More importantly, is it still safe to use that part of the front as a jackpoint without the rubber part?
      05-22-2010, 03:45 PM   #2
Thisisdudewhoru
Thisisdudewhoru's Avatar
Drives: 16 BSM 340i
Yea, you're missing some.
I wouldn't jack without the pad.
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
      05-22-2010, 04:08 PM   #3
MerLOW
Drives: 05 Z4 3.0i
2005 Z4 3.0i  [9.00]
I recently found the front of my car was missing one as well. The parts guy at the dealership said they fairly commonly were dislodged. They had them in stock for $27.85, part# 51-71-8-268-885
2005 Z4 3.0i roadster, Merlot red metallic, beige int & top, sport, premium, heated M seats, xenons, Aux input, OEM strut brace, OEM hard mount wind diffuser
      05-22-2010, 04:32 PM   #4
AWM3
BMW Fan
AWM3's Avatar
11
Drives: 2012 E92 M3, Alpine White
yes, you can jack there using a small block of hard wood. You won't be able to use a jackstand though. You can also lift both sides using the front center jack point which is a round piece of hard rubber at the front edge of the aluminum under body panel.
      05-22-2010, 05:09 PM   #5
dekaliber
Whoa, that seems super overpriced. RealOEM lists it as 51717894027 for $9.03...
I'll see if I can get to the front center jack point. How far in from the front is it? Would a regular hydraulic jack be able to get access?
      05-22-2010, 05:16 PM   #6
nmulax
nmulax's Avatar
Drives: '07 Z4 M Coupe
2007 Z4M Coupé  [7.66]
It's WAAAY up there.
You really can't reach it from the front, so I've always raised the rear first then used a Craftsman floor jack coming in behind the front wheel to reach the front center jack point.
      05-22-2010, 07:04 PM   #7
blender
Custom User Title
blender's Avatar
Drives: black
Suggest you re-pad your chassis before you begin jacking
      05-22-2010, 08:20 PM   #8
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
I built little ramps out of a 2x10x10 and jack from the center jack pad. Added little rubber stoppers to keep them from sliding when I drive up on them.
      05-23-2010, 07:45 AM   #9
bosstones
Drives: o_0
+1 except I'd use a hockey puck instead of a wood block until the replacement part came in.
      05-23-2010, 12:35 PM   #10
jmillet
jmillet's Avatar
64
The jack supports are there for a reason.
http://www.bimmerfest.com/forums/sho...27&postcount=3
If properly installed with the center locking pin fully inserted the Z4 jack pad is very difficult to remove without removing the locking pin. Since the jack pad occupies the place where you insert the tie-down T-hook I modified the jack pad so it can be levered out without removing the locking pin. Haven't lost a jack pad yet
http://www.bimmerfest.com/forums/sho...light=jack+pad
I carry four T-hooks so the car can be properly lashed down for flatbed towing. I've seen too many tow truck operators lash down BMWs using straps wrapped through the wheel spokes or around suspension components.
http://bimmerfest.com/forums/showpos...94&postcount=1
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      05-23-2010, 05:28 PM   #11
Blind32
Blind32's Avatar
Drives: '07 Z4MC
Tried to purchase some from AWdirect, no luck finding part PD1. Do you have a newer part number?
Did find these tho.
http://www.awdirect.com/tie-down-hooks-ca13/hooks/
Do these look like yours?
      05-23-2010, 05:35 PM   #12
AWM3
BMW Fan
AWM3's Avatar
11
Did find these tho.
The T hook is the one you want. $6 is a good price.
Turner sells the jack pad for about half of what the rip off dealer wanted
http://www.turnermotorsport.com/html...ID=51718268885
      05-23-2010, 06:07 PM   #13
jmillet
jmillet's Avatar
64
Did find these tho.
Yes you want the CA-13 T-hook. I wrap them in bubble wrap, put them in a Ziploc bag and store them next to the battery.
You can find your towing specs here: http://www.towspec.com/vehent/unsecure/
Jim Millet
      05-23-2010, 07:41 PM   #14
Blind32
Blind32's Avatar
Drives: '07 Z4MC
Cool thanks for info, I'll grab some of these and hope I never need to use them except for dyno testing!
      02-27-2011, 05:39 PM   #15
bucko521
More of this than that!
bucko521's Avatar
Drives: BMW Z4 3.0i, Z3 2.5i
Good info....this should be 'pinned' for future reference in the DIY section!
'06 Z4 3.0i Jet Black/ Biege/Black
Leather / Premium Package / DICE Silverline DUO / Stubby Antenna / Matte Black Grill
Ultimate Cup Holder x2 / Gaptech RCH+ / First Aid storagebox x2 / Acrylic Wind Deflector
      02-27-2011, 06:51 PM   #16
Diokaef
Engineer
Diokaef's Avatar
Drives: M235I 2015, 335i 2011
2008 Z4M Coupe  [6.33]
I have 4 of this if you guys need
      02-28-2011, 08:43 AM   #17
imz4n
imz4n's Avatar
Drives: 2006 3,0 si TITANIUM SIlVER
If you jack the car from the rear pad it will lift the whole side of the car.
SoCal Z Enthusiast contact me to get on the list. Events for like minded people and when you talk about your Z, we will know what you are saying. https://www.facebook.com/groups/ZSCCACalifornia/
      02-28-2011, 09:56 AM   #18
porshah
porshah's Avatar
197
Drives: M4, R8, Huracan - All topdown
Sorry to go off topic. Anyone have opinions on this?
I have seen them listed on ebay for around $40. Is it worth it?
      02-28-2011, 10:19 AM   #19
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
I am missing all 4, I'll take these if they haven't been claimed yet.
Apparently the Z4 loves to shed parts because I thought I was the only one missing these. I also thought I was the only one missing a couple of the little plastic interior pieces on the vents and doors but a fellow member confirmed his were missing as well! Same with the battery cover clips!
Nikki
      02-28-2011, 11:33 AM   #20
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Yeah, you could say the brake cooling ducts and I had a "falling out." The first one is somewhere on 46, and the second decided to unseat itself and get munched by the tire. Btw, nice signature. Where did you get the pic?
      02-28-2011, 11:49 AM   #21
Nikki
Nikki's Avatar
Drives: Sepang Z4MC
LOL, ouchies!
Thanks, I stole it from here and edited it:
http://www.flickr.com/photos/victory...7625979001939/
Nikki
      02-28-2011, 12:00 PM   #22
HpDellNestle
Drives: Z4
A proper sports car, always finding way to lose that extra couple oz..
