      05-04-2010, 10:34 PM   #1
runnerx
runnerx's Avatar
Drives: 06 M roadster; 06 330i 6spd
Z4M roady @ thunderhill (video)
Alright... I guess I will be the first one since no one has posted any roady track video.
NCRC event at Thunderhill. I just mounted Dunlop Direzza Sport Z1 Star Spec 245/275 on the stock rims not long ago. the car understeered a bit due to incorrect tire pressure. A little bit more PSI tweaking should help rotate the car better.
Comments and tips are welcomed...
2009 BMW X5 4.8i
2006 BMW ///M Roadster 6spd manual
2006 BMW 330i 6spd manual - gone
https://lh5.googleusercontent.com/--bIgrh8ES_s/TxSUCvOmDUI/AAAAAAAAPh0/OOjwrRZtta0/s912/z4mcomparo.jpg
      05-04-2010, 11:32 PM   #2
Shorestyle031
Shorestyle031's Avatar
23
Drives: 08 M roadster
video not working
08 M roadster
      05-05-2010, 01:32 AM   #3
Thisisdudewhoru
Thisisdudewhoru's Avatar
Drives: 16 BSM 340i
You aren't first lol.
http://www.zpost.com/forums/showthread.php?t=381719
'16 BSM 340i M Sport + Track Pack.:.M Perf Exhaust.:.Polished BBS RS-GT.:.JB4.:.BMS Intake.:.H&R Sport.:.
      05-05-2010, 11:33 AM   #4
runnerx
runnerx's Avatar
The video works for me...
He posted his video in a different section, so I guess I am still the first one here hahaha....
2009 BMW X5 4.8i
      05-05-2010, 01:21 PM   #5
The HACK
Roger Murdock
The HACK's Avatar
519
Drives: 2006 MZ4C, 2015 Fiat 500e
Man it's been 2 years since the last time I was at T-Hill. If it weren't for the usual heat and humidity (and the 8+ hour drive) I'd put T-Hill near the top of the list of favorite tracks.
Not sure if you want any comments, but here's a little tip I picked up from a friend. That last turn onto the front straight? There's no "straight" section between the two apexes.
      05-05-2010, 01:31 PM   #6
runnerx
runnerx's Avatar
Thanks..
I did have a tiny bit of straight there.. next time (6/25) I will try out your suggestion
2009 BMW X5 4.8i
      05-05-2010, 07:08 PM   #7
Shorestyle031
23
nice driving man very smooth
08 M roadster
      05-06-2010, 11:17 AM   #8
runnerx
runnerx's Avatar
thx for the compliment!
2009 BMW X5 4.8i
      05-06-2010, 01:48 PM   #9
The HACK
Roger Murdock
The HACK's Avatar
519
Originally Posted by runnerx View Post
Thanks..
In order to make the last "turn" into a turn-in, pause and let the car track out to the outside, hold the arc for the 2nd apex, you need to make the first apex super late. By being on the first geometrical apex you won't be able to make a single arc through the entire turn.
Again, to do so you must give up a little bit of entry speed but the exit speed and ultimately terminal speed gained down the front straight will more than make up for the split second lost in the braking zone to the first half of the turn.
A friend of mine put it this way regarding T-Hill...A 1 mph difference at the exit to the straight will equal a 5 mph difference at the end of the straight.
      05-07-2010, 11:07 AM   #10
runnerx
runnerx's Avatar
very good information.. I will definitely try this next time.
2009 BMW X5 4.8i
