01-13-2010, 07:45 AM | #1 |
///M'n it Up
17
Rep 344
Z4 Blowing only hot air, at random
My Z4M has this little bug where the air conditioning system will go into a "blow only hot air" mode. It happens randomly, about 3 times a week. Only shutting off the car for 20 minutes will fix the situation.
The dealer has replaced the IHKA (ac control) module, but the problem remains. They tell me that the IHKA module reports that it can't control the internal duct doors that direct air to the console vents. The module then goes into an "emergency" mode where it ensures that hot air is available to melt snow/ice off the windshield if necessary. Has anyone else had a similar problem? |
01-13-2010, 08:37 AM | #2 |
Rep 4,057
Did a politician own it at some point?
And to be serious, no, I have not had this problem. I wonder, the inability to control the duct doors - could it be that something has gotten lodged in the mechanism preventing the doors from operating correctly?
Huz-Z
01-13-2010, 08:44 AM | #3 |
///M'n it Up
17
Rep 344
I know that they've had the center console apart, so I assume that they'd have investigated that. I may get up under there myself if the they can't figure out something today.
01-13-2010, 09:10 AM | #4 |
Rep 1,989
What is the dealers next move? The car is under warranty and your AC system is malfunctioning. They need to figure it out. Sounds like they need more time. I wouldn't spend any of my own time on it when the car is under warranty... Get a loaner until they fix it.
01-13-2010, 09:21 AM | #5 | |
///M'n it Up
17
Rep 344
I'm waiting for a loaner right now. They say 3 - 4 hours for the waiting list |
01-13-2010, 09:40 AM | #6 |
Rep 4,057
It certainly seems that the dealer should replace the entire system for you to eliminate the problem.
Huz-Z
01-13-2010, 04:44 PM | #7 |
Rep 42
No help but one of the gremlins in my car will randomly take control of the vent controls. It will decide @ random which vents to blow air out of- the controls do nothing when it occurs. It switches randomly between vents.
Happened 2x now. Another gremlin controls the heat/cold and will only permit cold air to be emitted until the temp control knob is switched back to cold then later to hot. My conclusion? It's either cursed or infested by gremlins. So, subscribed in case you post a solution (I'm thinking the problems are similar). |
01-13-2010, 05:20 PM | #8 |
Rep 165
I had this same problem in my Z4MC. I took it into the dealership, they gave me a loaner, and the next day problem solved. Sorry if it isn't helpful at all, but they did this all under warranty.
01-13-2010, 07:13 PM | #9 |
///M'n it Up
17
Rep 344
Would you mind calling up your dealership and getting a summary or work order that explains what they did? I'd appreciate it very much!
01-14-2010, 05:50 AM | #10 |
Rep 1,989
No paperwork when you picked up the car? It should list what was done(parts replaced, ect.) to fix the issue.
01-14-2010, 04:06 PM | #11 |
///M'n it Up
17
Rep 344
Got the car back from the dealer. They said that the tech found a broken motor for one of the internal ducts. I don't know why they couldn't have found this during one of the last three times I had a tech look at the car. The air coniditioning system operated normally on my drive home.
Replaced so far... IHKA Module Passenger's side footwell stepper motor If I don't update this thread in the future, that means the problem has been fixed. |
01-14-2010, 08:46 PM | #12 |
Rep 165
sorry that I didn't get back to you. Paperwork wise same things as you have already listed were replaced.
IHKA Module Passenger's side footwell stepper motor anyone else have this issue? it may be a factory faulty part? |
05-31-2022, 06:30 AM | #14 | |
Rep 2,051
