11-17-2009, 05:26 PM | #1 |
309
Rep 3,635
Drives: R56 Cooper S
▀▄ eas - Rearview Camera & Video Source Module
The Video Source Module (VSM) is a video input for integration for a rearview camera or aftermarket products (e.g. DVD player) with the factory navigation System.
Specifications: - 1 Video Input - 1 Camera Input - Auto Video Switching - PAL & NTSC Compatible - Analog & Digital Compatible - Plug & Play Connection - Any aftermarket device attached to this interface will work on the move Kit Contents - Video Source Module - Plug and Play harness - Instructions - Optional Bumblebee camera with forward/reverse image (end user selectable) Reverse bumblebee Camera (optional) Imported overseas from one of the best CCTV Security Surveillance equipment manufacturers in Taiwan, Misumi is well known for applying state-of-the-art CMOS Image Sensor Devices (Camera On A Chip) to the design and manufacturing of security surveillance video cameras. These kind of cameras incorporate high technology used to minimize the size of the cameras and produce a crisp and clear picture quality. The small and indestructible design allows for mounting virtually anywhere on the vehicle without the need for drilling. The "bumblebee" camera gets its name from the mounting bracket that can be mounted virtually anywhere from underneath the decklid next to your license plate or underneath the rear spoiler. This is perfect for newer BMWs that do not feature a keyhole, eliminating the need for drilling. The camera features a 150-degree maximum viewing angle and a 0.5 LUX rating for low light viewing, even in dark areas. Features: - Significantly decreasing power consumption; operates on 3-12V DC - Lightweight - High reliability at low cost - RCA video input - Simple installation - Great for covert use in anyplace imaginable Specifications: Water Proof (IP67) Color CCD Camera Wide Angle View for Reverse Back Up System Signal System: NTSC/PAL Pixels: NTSC-512x492, PAL-512x582 Image Sensor: 1/4" COLOR CCD Lens: 1.9mm/F2.4 Lux Rating: 0.5 Lux Viewing Angle: 150 Degrees Dimensions: 19x18mm Camera to main board box: 22cm W/Video & Power mixed line (AF-U183) Models Supported: 10/2002-2006 3 Series (e46, including M3) 9/2002-2003 5 Series (including M5) 10/2002-2007 X5 2004-2009 X3 2003-2009 Z4/Z4M eas - Video Source Module (VSM) for BMW http://www.europeanautosource.com/pr...oducts_id=2422 |
11-18-2009, 11:11 AM | #3 |
Rep 18,808
Drives: BMW
Gaining access to the back of the MKIV computer's connector was the most difficult, otherwise - it's all downhill from there.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-25-2009, 11:12 PM | #4 |
Rep 969
I live in DC where it would be nice to see out the rear from the display more than when just reversing. How hard is it to make the camera switch happen manually as well?
Very cool module. Any videos or screens of putting over devices through the display e.g. dvd etc.? Not that I am big on DVDs in a car... but it would be interesting. BTW is it just me, or can you still see the camera shot behind the regular display mode? Anyway to avoid that? Sorry for all the Q's
911 Carrera project car
Previous: E92 M3 ZHP - Sold E86 Z4M - Sold E36 M3 - Sold |
11-27-2009, 11:40 AM | #5 | |
Rep 18,808
Drives: BMW
DVD will be crystal clear on the screen as long as your files are higher than 640x480 resolution.
11-27-2009, 03:25 PM | #6 |
Rep 969
Thanks for the info.
Do you have greater details on the switching methods from camera input to other component? It looks like just a 'black box' but I didn't know if there was a wiring diagram that you could share etc. Just trying to understand how I might be able to utilize the box. Thanks!
11-27-2009, 05:20 PM | #7 | |
Rep 18,808
Drives: BMW
1. 1st input is auto-sensing. As soon as a signal is detected (RCA) the device will switch to that input. When the signal disappears, your screen reverts to normal. 2. 2nd input is activated by a "trigger wire" (+12V) from the device, when the power disappears, your screen reverts to normal. Hope this helps.
03-21-2011, 11:57 AM | #9 |
Rep 18,808
Drives: BMW
Video in Motion for e85 models are no longer available, sorry.
