FORUMS
- 5
| 07-12-2009, 02:48 PM | #1 |
Carsoft 6.5 problems
Hi to all
i have just installed carsoft 6.5, i have a bought a replica module off ebay. I have then carried out a full diagnostics scan and it is telling me that all the modules are not responding any suggestions?? Thanks Adam |
| 07-13-2009, 09:07 AM | #2 |
![]() Drives: '03 Z4 + '07 ///M Roadster Join Date: Jun 2007
The first question would be, do you have an original copy of CarSoft or a "cracked' copy? CarSoft 6.5 doesn't have all the modules in it. A friend of mine has it and when I run it on my 2003 Z4, it doesn't see some of the modules like the DME. I ran it last night and I see 9 of the modules... but I know a lot of the others I don't have... I'll run it tonight and let you know which ones I do see.. Chuck I
| 07-13-2009, 09:40 PM | #3 |
CarSoft 6.5 information
This is what I get when they run 6.5 on my 2003 Z4. Chuck I
DME / DDE diagnosis - Status: Module does not respond Inst. Cluster dia. - Status: OK SIM - Status - Module does not respond AIRBAG - Status: OK ABS/ASC - Status: OK BC/MID - Status: Module does not respond DWA - Status: Module does not respond ZKE / ZVM - Status: OK HKL - Status: OK EGS - Status: OK EWS - Status: OK LCM / CCM - Status: OK PDC - Status: Module does not respond CVM - Status: OK CAS - Status: Module does not respond ZGM - Status: Module does not respond RLS - Status: Module does not respond |
| 07-18-2009, 01:00 PM | #4 |
sorry for the late reply
this is a cracked version that came with the module under the heading of test software Unfortunately my module can not see any of the modules in the car it says every one in 'not responding' Any ideas. i have found some info on another website but it just seems that they have the same problems with no obvious solution |
| 07-18-2009, 08:50 PM | #5 | |
| 07-19-2009, 01:57 PM | #6 |
With regards to the lights
the module has 5 lights Power Service Interval k-line pin20 k-line pin17 l-line pin15 the only light which isn't on is the 'Service Interval' I have't looked if they flash whilst i am trying to talk to the Z4 but i will try again in a min My mate has a 2000 320 coupe so i will try it on his car Also with regards to the cracked version of the software, i have found the 2 exe files one wont even talk to the car (software crashes) the other gives me the fault of not being able to see any modules. Thanks for your help by the way |
| 07-19-2009, 03:14 PM | #8 | |
| Bookmarks |
