08-30-2023, 12:57 PM | #23 | |
Rep 1,544
My car doesn't see the track (read: I'm interested but chicken) but I've been trying to trace an intermittent noise Ive been getting. Thought it might've been from the front sway bar/bracket but it both are solid/look good. I was planning to check the VT mounts this weekend and will report back on how mine are holding up.
- Jeff
bosstones' flickr |
08-30-2023, 02:08 PM | #24 |
10965
Rep 4,910
What makes you think that?
08-31-2023, 01:58 AM | #25 |
Rep 5,329
Because so far every reported unit that's failed prematurely has been the blue dot ( road versions ). I haven't seen one reported failure of the competition units as yet. one a largest threads on the m3 forum and every single one was the blue dots.
This side of the pond they have used the orange dots in quite a-few race series over a fairly long time span and reported ( to me at least ) that these were seeing pretty much zero failures. Due to how close i am to VT ( they are 25 mins from my house, im going to see if i can table a meeting to understand what their thoughts are on the reported failures. ill report back asap. Either way, they are failing and i think it needs to be answered. Mine don't have many miles but have had some very extreme use and quite a few all day track days in hot temps, they look like new.
08-31-2023, 02:00 AM | #26 | |
Rep 5,329
i cant comment on how quick they have been wearing but i think its important to note that mounts will still wear! They were one of the biggest changes to my car, like i mentioned i will speak to VT asap and report back. They may say that's just normal after X years , or they may say its user installation like over torquing etc. im sure they are aware of some of the recent press on this.
08-31-2023, 08:13 AM | #27 |
Rep 913
I'm fairly certain my are the race version, and they don't look disintegrated as some I've seen. But, the engine sure is moving sideways more than I am comfortable with. The hot side (passenger side)'s motor mount is wrapped in thermal aluminum padding to protect from heat. The exhaust manifold and wastegate are right near it. This is the side where I kept melting the Powerflex control arm bushings (FCABS) and had to go solid FCAB. The mount it hidden do to the shielding so I don't know of it's status. Driver side looks normal.
I'll inspect these upon removal and post my findings here. Chances are they are "fine" and if that's the case, they may not be solid enough for my needs. I agree, I don't want a 100% solid mount up there.
Andre - 2J into a Z4 Coupe!
08-31-2023, 11:33 AM | #28 | |
Rep 5,329
08-31-2023, 11:45 AM | #29 |
10965
Rep 4,910
Don't you think mileage and circumstances during use (like sitting in traffic in hot area's where temperatures under the bonnet on components not being connected to the engine are sometimes hotter than racing on a track where there's much ventilation)) might be a deciding factor?
08-31-2023, 10:26 PM | #30 |
Rep 913
Alright. Just replaced them with the black series powerflex units and added all 4 inserts. Will see how this goes.
I've had these Vibra Technics for over 6 years, logged 70 race hours on them. They looked surprisingly good, especially the one on the hot side. The rubber seemed softer than I expected. I don't have any dot on these, but I did remember the groupbuy and part number was BMW360M (I believe the 362MX is the race version?). Perhaps I don't have the race version, no clue... I took them apart and they look to be in great shape inside and out. Perhaps I was lucky. Still, I think these are too compliant for my needs, and the fact my 2JZ is about 100lbs more weight than the N52 that originally was on here, I need something stiffer. I haven't seen a single real review of these powerflex units, so I have no idea if these will last in a racing environment. It looks like they only make them for BMW. Did these just come out?
GuidoK10965.00 |
09-01-2023, 07:35 AM | #31 |
10965
Rep 4,910
No, they've been out for a few years now. At least 5 years now. Instructions were uploaded to vimeo in 2018
Looks like you're gonna be the first one to give an elaborate review of how they perform on track compared to VT motormounts I hope they give what you're looking for. What's your first impression on the look&feel of the units themselves?
09-01-2023, 08:25 AM | #32 |
Rep 913
Wow, ok. 2018...
I don't like using untested parts and appreciate the recommendations from here and others, but these are beefy and stout. They were easy to slide in. I don't know how easy it will be to remove/add the inserts while mounted. Will definitely report back how these perform and NVH.
09-02-2023, 10:16 AM | #33 | |
Rep 5,329
what i WILL say, mine have been on the car for over 5 years , have been subjected to some pretty harsh conditions are absolutely fine. VT when i tested these initially were VERY specific abt Tq specs and not over tightening the bolts
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 09-02-2023 at 10:22 AM.. |
09-02-2023, 10:23 AM | #34 | |
Rep 5,329
09-02-2023, 11:15 AM | #35 |
dances with roads
4738
Rep 4,099
The S54 is at least 100 lbs heavier than the flyweight N52. Z4M engine mounts should be a good match.
