      06-03-2018, 04:53 AM   #45
MOTK
Drives: Z4MC
Originally Posted by Vanne View Post
Flow dynamics? Nfi,
I guess nfi means you have no fucking idea. That's a shame, for I had assumed you must because otherwise making these sorts of statements about intake flow analysis would be pretty much worthless.
those snorkels going down and connecting up to your OEM Z4M intake hole, youll be getting about 1/8th of the air that this intake can handle and pretty much useless in that regard.
and yeah oem Z4 air hole at that rpm that will provide enough flow at this stage
youll be strangling the intake
Given the above and the idea that imo BMW would have applied at least some math to the design of their intake (for instance it sits in a low pressure area of the front end) which would be needed to supply an S54 with enough air, and that we know this intake is also able to supply more than enough air to a supercharged s54 which will need more than any NA version I think I'll drop out of this conversation here
Best of luck with your project, I hope it works out well for you.
MC IB, CSL intake, Schrick 288/280 cams, SS race bbox, RPI, AP f&r w/RSL-29, Apex ARC-8, A048, KW CS, Turner arms & RTAB limiters, VT engine mounts, Rogue pulleys & RSMs, Tillett B6s, custom half cage, UUC ssk, M5 knob, oem strutbrace
      06-03-2018, 05:27 AM   #46
MOTK
Drives: Z4MC
Originally Posted by FD3S View Post
WTF is this???
What is the purpose of those 2 huge holes? And where is the radiator?
Those are actually pretty cool, induction resonance optimised intakes. If you can tune the resonant frequency of the intake to peak as you hit max power you can increase the volumetric efficiency. These are good on a race car as they generally tune the intake runner for operation around in the smaller rev range that it will be working in, for a road car it is less than ideal as outside of this range the resonance will have negative effects on efficiency. If they have some way on this to vary the runner length that would be really really cool, I don't know, but that would definitely need a pretty fancy ecu.
FD3S69.50
      06-03-2018, 11:15 AM   #47
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
Lol mate, they are not air intakes, but direct exhausts for the radiator. Maybe you should be typing nfi a bit more too if you think those exhaust are air intakes.
Still would be great if you could post up the bottom end of your snorkel so we can see how large it is compared to the actual flap snorkel.
Anyways, it's ok to have different opinions, that's what makes us all unique, and how we find out different ways to do things. It's all good Tom, nothing personal implied mate. I just wanna see if we let this intake breathe better if we can up the performance a bit. Would probably require extra fueling and adjusted maps, but hey, can't hurt to try.
Powered by
      06-03-2018, 11:32 AM   #48
MOTK
Drives: Z4MC
Lol too, you're probably right. My first thought was that they were acting as some kind of s-duct helping flow attach to the car by ducting air from the floor, but reading the specs of the car it notes a "Carbon fibre airbox with resonance induction optimised inlet pipes", that got my mind twiddling (it uses a helmholtz resonator design which can have similar shapes) . Any better pictures of the intake mouth out there? Either way it looks pretty badass!
Listen, I'm not saying that you are wrong (I don't have the knowledge to calculate it), it's indeed possible you might be right, but without any analysis on the system how can you be so certain about the statements you make?
      06-03-2018, 11:53 AM   #49
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Your right Tom, I can't mate, but seeing as most S54 NA race cars with our intakes seem to have huge intake frontal area, must be for a reason. Either way, no harm done.
Gonna give it a go, if it works, great, if it doesn't, nothing lost.
Powered by
      06-18-2018, 04:26 PM   #50
GPower
GPower's Avatar
Drives: 2007 BMW Z4M Coupe
This is how the Karbonious looks like with the trimmed snorkel. A more elegant solution is needed. I wrote Karbonious if they are working on a Z4M specific snorkel, we'll see what happens.
I am not sure if I can feel any difference in mine after full exhaust, CSL intake and Alpha N tune. Seems a but too loud with the Stromung mufflers and Rogue X pipe but I still have some adjustment to make. X Pipe is/was rubbing on one of the braces.
It'll be interesting.
Vanne1620.50
ANILE8179.50
      06-19-2018, 11:51 AM   #51
GPower
GPower's Avatar
Alright, alright. I will be first in line. It's confirmed official on their facebook page. I hope it's soon. I want it in before we do the Fall cruise in Canada. Muahahaha
FD3S69.50
      06-19-2018, 12:11 PM   #52
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
Great news! I'll be in line to buy as well.
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE
E90 M3 Sedan 6MT Jerez Black/Fox Red GONE
E86 Z4M Coupe Interlagos Blue/Black
E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread
FD3S69.50
      06-19-2018, 01:36 PM   #53
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
Oh SNAP !! time to plant another money tree in my backyard and water the shit out of it!!
FD3S69.50
      06-19-2018, 02:15 PM   #54
GPower
GPower's Avatar
Hahaha
      06-19-2018, 02:15 PM   #55
FD3S
Drives: BMW Z4M
Guys I can see we are a lot of us with the need for the Karbonius snorkel. Maybe it is time to go for a group buy? And also start thinking of the best solution how this snorkel should be designed?
Before 20 days and more I have send them detailed measurements from my car about the snorkel, but I have no news to hear back from them.
      06-19-2018, 08:51 PM   #56
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
This picture shows exactly what I was trying to say in the above posts. That oem inlet is tiny. I hope Karbonious are not just looking to straight connect it to that inlet?
Powered by
      06-20-2018, 11:39 AM   #57
TurboDream17
///M Enthusiast
TurboDream17's Avatar
Drives: '07 Z4M Coupe
Rob Turner asking on that Facebook page is me by the way
If we ever set up a group buy I'm definitely interested.
///M Coupe - Volk TE37's 19x10.5R +22 19x8.5F +30 | KW V3 w/ Clubsport rear springs | RPi exhaust | Autosolutions SSK | RE transmission mounts | RE RSM's | Vibra-Technics engine mounts | RPi scoop | RPi skid plates | Tekarbon spoiler | Apex wheel studs | Blox burnt titanium lug nuts | UUC Front 27mm Swaybarbarian | Status Gruppe adjustable front links | EAS Blacked out kidneys | Full Beisan Vanos Refresh
      06-20-2018, 12:58 PM   #58
tominizer
tominizer's Avatar
@Vanne, nothing a bit of C4 or a grinder with a giant cutting wheel can't fix eh !! But it is an interesting point.
Yeah, I'd be REALLY interested in this setup. If there's some sort of GB, not sure I'd be able to contain myself as my whole intake is still all stock. My E30 M3 had racing intake box on it........ pure sexy!!
      06-20-2018, 03:23 PM   #59
TurboDream17
///M Enthusiast
Not apples to apples, but just came across this video which highlights temperature differences between intakes positioned under the hood and ones potentially pulling air from the front of the car:
      06-20-2018, 03:23 PM   #60
GPower
GPower's Avatar
I got a reply from Karbonious but no time frame at the moment. Just a project. Wrote back if they would like to get deposits of interested people. Will let you know how it goes.
I suppose going on their Facebook page and posting a comment or just sending them email wouldn't be a bad idea.
How many people have the CSL box from Karbonious?
1) GPower
      06-20-2018, 03:27 PM   #61
GPower
GPower's Avatar
Hi Rob, good to see you in the forum(I am Georgi Baltov, right below you) Setting up a group buy is the easy part. I remember the Ohlins group buy attempt and then nothing happened. I would really hate getting my hopes up for nothing.
Although I think Karbonoius will do it. I just hope we don't wait forever that's all.
      06-20-2018, 03:58 PM   #62
FD3S
Drives: BMW Z4M
1) GPower
2) FD3S
And definitely count me in a group buy.
      06-20-2018, 07:49 PM   #63
Steeler
Steeler's Avatar
2428
Vanne, although my car is a non M the front end sheet metal is the same except for the hood latch mechanism.
My solution to feed more air for my SC was to fabricate a 3.5” duct system using household PVC plumbing pipe.
There was a bit of modification required to the front end sheet metal as noted in the diagram by the blue lines, This area was cut and removed. Then that area was sandwiched with an inner and outer 10gauge(1/8”) thick steel plates and bolted through to regain integrity in that area. Not sure it was needed for integrity but the plates also created a smooth and visually appealing location for the ductwork to pass through. Finally a K&N filter fits nicely behind the kidney grille.
In the case of the snorkel you guys are looking at,a silicone connector may be utilized to join the CF snorkel to the duct.
inTgr8r2425.50
Vanne1620.50
      06-20-2018, 10:11 PM   #64
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^nice work!!!!
      07-24-2018, 06:00 PM   #65
Terraphantm
Drives: E46 M3 Coupe
Originally Posted by MOTK View Post
In my opinion if you really want to be running this intake 'optimally' as you say, you'd be better off figuring out how to run the box with correct CSL map sensor rather than the bodge we currently have of using alpha-n, a very flawed approach unfortunately. Certainly more important than worrying about increasing the size of the intake hole by an inch or so. Just my 2c.
As I'm not sure if that's possible I have concentrated on what I know to be important for getting alpha-n to work well which is to have a good supply of cold air and making sure the IAT probe reports this air temperature accurately (i.e. not suffering from any heatsoak to give false readings for the table).
I look forward to seeing your headlight/carbon tube mod and the results you see from it...
While I don't think it's impossible to hack the MSS70 to run a MAP sensor, I don't think it's really necessary. MSS70 should be able to do alpha-n much more reliably than the MSS54 in the M3 if tuned properly. A big factor in that is the fact that the Z4M uses wideband O2 sensors unlike the M3.
      02-15-2019, 10:08 AM   #66
GPower
GPower's Avatar
Hi guys,
could you go Karbonious' facebook page and bug them about that snorkel. I just did but got a sad face reply. We need to keep expressing interest to hopefully get them to do it.
Thanks
https://www.facebook.com/karboniusAi..._comment_reply
