03-28-2018, 09:29 PM | #1 |
SOFLO CODING
199
Rep 3,587
CSL Carbon airbox - Where to buy? or one like
I just picked up a Z4M. I love the car but it needs more sound. Im loving the videos im seeing of the CSL intakes on the z4m.
Q's Where can I buy this? Will the E46 intakes fit the Z4m? Will any cold air intake deliver the same noice? Opinions on Eventuri? |
03-29-2018, 08:50 AM | #2 |
Rep 1,031
Evolve - own design, high quality
http://www.zpost.com/forums/showthre...ghlight=airbox Karbonius - oem replica, high quality http://www.karbonius.es/web_ing/prod.../base_bmw.html Geoff Steele - oem replica, good quality https://www.geoffsteel.co.uk/shop/e4...t-breathers-3/ I have an Eventuri, nice bit of kit. I don't think I can hear it at all though over the headers and exhaust upgrades. Think it made throttle response a little better. Overall good quality and looks pretty. Worth it compared to the others out there.
08 M Coupe Ceramic Black Fabspeed Headers MCS 1WNR Poly FCAB Stoptech BBK Vibra-Tech Epic Tune Apex EC7 RPI Scoop Eventuri Stromung Rogue X Pipe Varis Diffuser CF E92 GTS Wing CF Roof
Jsinghzzzz76.50 |
03-29-2018, 06:25 PM | #3 |
Rep 188
Another option is GruppeM that you have to check.
If you can handle the cost do it. I have the Karbonius. You will have faster response from them if you go to their Facebook page for order. Also if you need more info about the Karbonius let me know if I can help. Last edited by FD3S; 04-03-2018 at 04:28 PM.. |
Jsinghzzzz76.50 |
03-30-2018, 01:27 AM | #4 |
Rep 598
Group buy over at M3Forum:
http://www.m3forum.net/m3forum/showthread.php?t=596674 |
Jsinghzzzz76.50 |
03-30-2018, 01:53 AM | #5 |
Rep 222
I have one of the Evolve units. They appear to be exceptionally well made. Mine still isn't installed... but that's another thread.
03-30-2018, 11:51 AM | #6 |
Rep 45
Worth looking for one that reaches to the Z4 cold air feed through the slam panel. You avoid sucking in hot engine bay air then and faffing around trying to link the m3 version. And yes, the noise is worth it, they should have come like this.
MC IB, CSL intake, Schrick 288/280 cams, SS race bbox, RPI, AP f&r w/RSL-29, Apex ARC-8, A048, KW CS, Turner arms & RTAB limiters, VT engine mounts, Rogue pulleys & RSMs, Tillett B6s, custom half cage, UUC ssk, M5 knob, oem strutbrace
04-01-2018, 09:40 PM | #7 |
SOFLO CODING
199
Rep 3,587
What additional hardware is required to make your Karbonius work? I am coming across threads for M3s discussing MAP sensor mods, splicing wiring, and some crazy ones like DME swaps. Did you order for your z4 or did you order an m3 one form them to which to had to shave or modify the airbox to fit.
04-01-2018, 09:46 PM | #8 | |
Rep 528
Drives: E86 Z4MC; E92 M3
E46 M3 Coupe 6MT Jet Black/Cinnamon GONE
E85 Z4M Roadster Imola Red/Black GONE E90 M3 Sedan 6MT Jerez Black/Fox Red GONE E86 Z4M Coupe Interlagos Blue/Black E92 M3 Coupe 6MT Interlagos Blue/Fox Red - Build Thread |
04-01-2018, 09:50 PM | #9 |
SOFLO CODING
199
Rep 3,587
Is this yours? Can you share what brand is this? Where to buy?
04-02-2018, 06:19 PM | #11 |
Rep 9,004
Likely ALFA N, which requires it's own tune. Most tuners (Epic, TTFS and BPC) should have the tune down pact.
I wouldn't pay all that money for sound though - power yes. |
04-03-2018, 12:44 PM | #12 |
Rep 222
The Evolve airbox comes with their alpha-n tune. It's good for ~25HP - and the sound is a free bonus.
04-03-2018, 04:49 PM | #13 | |
Rep 188
CSL Crank Case Vent Hose 11157833649 CSL Airbox Air Shut Off Valve 11617833647 6 x Clamps 59 - 66mm - 07129952125 OEM CSL filter 13727838625 CSL IAT Sensor 13621739510 Karbonius Snorkel - £300 (optional - I do not have it) Tuning - you must have Alpha N tune to make the Karbonius work with the car. Tuning is the most important part so choose wisely. Known tuners are Epic Motorsports (my selection), TTFS (I do not have opinion about them but I guess it is a good choice if later on you want to go the SC way), Evolve, ESS. The car after the Karbonius and the tune pulls stronger. But the best part of the CSL intake is the sound... You can have a look here: https://youtu.be/NDoNhiNBrxo Also you can see my comments about this mod here: http://www.zpost.com/forums/showthread.php?t=1422706 Last edited by FD3S; 04-03-2018 at 04:57 PM.. |
yousefnjr6115.00 rockstar93321.00 |
04-04-2018, 11:15 AM | #15 | |
1593
Rep 4,293
Powered by |
04-04-2018, 11:24 AM | #16 | |
SOFLO CODING
199
Rep 3,587
just want the noise |
04-04-2018, 12:27 PM | #17 |
Rep 11,665
I agree, 25HP increase is marketing BS.
04-04-2018, 04:37 PM | #18 | |
Rep 188
You can install the tune yourself, it is not something special, as long as you have a battery charger , because to load the tune makes more than one hour and the last thing you want to happen to you is to die the battery while uploading the tune. Also you will need a laptop with Windows. Vanne has written a guide about how to do the whole installation by yourself also for the Airbox. It has helped me a lot. Vanne and inTgr8r are right. If you want the noise you are ok. Last edited by FD3S; 04-04-2018 at 04:50 PM.. |
04-06-2018, 12:26 AM | #19 |
Rep 1,130
Having RPI and other exhaust mods, I doubt even a CSL air box will be heard. What’s the power gain difference between an air box versus say... Eventuri?
2014 BMW X5 Sdrive35i F15
04-06-2018, 03:06 AM | #20 | |
Driving Dog
871
Rep 1,218
Drives: 635/1815, X3M Comp
I can definitely feel an increase in power at 4 - 5k in the Evolve compared to having the Gruppe M. No dyno numbers to reference but there's definitely some gains. |
RossBMWZseries224.00 |
04-14-2018, 07:07 PM | #21 |
1593
Rep 4,293
Oh, you'll hear it alright.
Powered by |
