      11-25-2017, 03:50 PM   #45
Swashplate
Swashplate's Avatar
Drives: in Anger.
Originally Posted by mattfwalters View Post
Thanks, all. It's taking awhile, but I am really enjoying the process. I hope it turns out to be as epic as I'm picturing.
And as epic as we are all picturing...
AFE Intake/Euro Cats/CSL Headers/Sportline CSL/H&R Springs
1217/1815
!!! BOILER UP !!!
      11-26-2017, 07:41 AM   #46
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Small progress this weekend: took video of the cam removal with clamps process, and installed the ARP head studs. Upcoming weekend will be head install, cam install, and maybe initial mechanical timing. I'm going to take video of as much of this part of the process as possible, since there's just not a lot of good video out there for working on S54s.
So here are some photos of at least one new thing:
View post on imgur.com
...love those JE pistons.
Just found this thread. You have an illness .
The insides are so pretty doesn't it just make you cringe to know you eventually will fire the thing up...
And... I thought I made myself a nice shop. I'm slightly jealous.
      12-04-2017, 04:41 PM   #47
mattfwalters
mattfwalters's Avatar
Drives: 06 Z4MC (Sepang/Sepang/insane)
+1
Yeah, I've got a fever, and the only cure is more cowbellhorsepower! Thanks for the kind words about the shop. It's a bit of a mess, but it is pretty much the working space I've always wanted to have, so I'm very grateful to have it. And yes, the brand-new internals are pretty, but I am 100% fine with them getting dirty if I get the results I'm after.
So: finally some more progress. I'm still not where I want to be, but between need-to-do items around the house, work demands, and preparing for a bit of a trip (3 weeks in Ecuador - motorcycling, diving in the Galapagos, and spending time in the Amazon), my free time has been close to nil.
I did get the head installed yesterday, though. The bit of soreness in my back and shoulders today (along with a bruise on my palm) is a good indication of how much work it is to torque and triple-check 14 nuts to 105ft-lbs.
I did a little bit of math, just for giggles:
35ft-lbs x 14 x 2 (double-checked): 980ft-lbs
70ft-lbs x 14 x 2 (double-checked): 1,960ft-lbs
105ft-lbs x 14 x 3 (triple-checked): 4,410ft-lbs
Total: 7,380ft-lbs of torque applied to head nuts. Next time I'm upgrading from the 18" ratchet to a 24".
The install / torque process was very straightforward. ARP specifies a 3-stage torque (per above: 35, 70, 105 ft-lb steps) for lubricated washers / nuts / studs. Minor note for posterity: if you have a stripped head, your life will be easier if you re-install the galley plugs before installing the cam follower shafts. I have long hex bits (~6" shafts on the bits), and they barely cleared the follower shafts - I had to use them at a slight angle to avoid contact. Not a huge deal, but a good thing to know.
Also: it's really hard to get some of the nuts to 105ft-lbs on a wheeled engine stand. I ended up doing some fun contortions to keep my body weight low, the socket upright, and the engine stand planted.
As always, some S54 porn:
n.b. the engine isn't actually drooping that dramatically on the stand, it's just a perspective trick from the wide angle of the iPhone lens. I think.
wdb4718.00
Mirko182.00
      12-30-2017, 12:57 AM   #48
mattfwalters
MAJOR PROGRESS ALERT
The cams are in - hopefully for the last time:
Cams prepped for VANOS:
Cam gears:
Full timing system:
Timing cover / VANOS drive / timing chain:
VARIABLE
NOCKEN
WELLEN
STUERUNG
Front crank seal:
And then.. what's this? It is fully. Mechanically. Timed.
So I adjusted the valve clearance where required:
And put a fucking cap on it.
Things I Learned Today(tm):
  • Don't install the head before the big cam chain guide on the intake side. It's a complete fucking nightmare to install with the head in place.
  • Following the Beisan walk-through for VANOS rebuild makes mechanically timing this engine pretty straightforward. Start with #1/6 @ TDC; install the cams per FSM specs with #1's intake / exhaust lobes pointing at each other with a ~45* upward angle; install the cam gears per Beisan's instructions. Ta-dah.
  • Harmonic balancer bolts are one-time use.
  • Valve clearances did tighten up a bit after installing the head - mostly. A few went the other way.
  • Metric feeler gauges make S54 valve jobs a lot easier. Glad I got a set.
I have new harmonic balancer bolts coming along with an underdrive crank pulley. Why not, right? A/C is already deleted, after all. Planning to button up the sump tomorrow, and hopefully prep the front subframe for install. Maybe even get the flywheel / clutch installed!
Still need to sort out fuel line under the hood, but might be ready to get the engine back in the car next weekend... :woop:
Mirko182.00
crfine88441.00
SaltyNC369.50
      12-31-2017, 12:40 AM   #49
mattfwalters
Minor additional progress today.
Hardline -> -8AN:
Re-sumped:
Definitely getting there. Time to bolt up the rest of the sensors (crank angle + knock sensors), main water pipe, fuel rail, oil / water pumps, and accessories...
wdb4718.00
Mirko182.00
      12-31-2017, 02:52 AM   #50
ZAR4MC
South Africa
93
Drives: '07 Z4 M Coupe
loving the progress, thanks for sharing...
07 Z4 ///M Coupe - Sapphire Black / Imola Red
My S54 Journal
      12-31-2017, 09:24 PM   #51
mattfwalters
Glad to share
No pics this evening, but water pump / tubes and the VAC coolant temperature sensor manifold are installed. Next up: oil manifold / filter housing, throttle bodies, fuel injectors and rail.
      01-01-2018, 11:59 AM   #52
Beedub
the oil pan on this car is a crazy shape....
      01-02-2018, 01:56 AM   #53
mattfwalters
Spent a lot of time cleaning the throttle bodies, so didn't get much other than the TBs and oil manifold installed this evening. Really starting to look like an engine, though.
wdb4718.00
coh661191.00
      01-08-2018, 02:34 AM   #54
mattfwalters
Fuel rail and vacuum manifold are installed, along with braided stainless hose for VANOS oil accumulator, Achilles underdrive pulley, and the rest of the throttle assembly (including TBW actuator):
Doesn't seem like a lot of progress, but I'm pretty much putting this bastard in the car next.
After I get the exhaust manifold studs and nuts, anyway. And also ordering the CSL dipstick and tube, because I'm a moron and forgot to do that, like, a year ago.
      01-10-2018, 04:13 PM   #55
Banang0
Drives: Black and Blue
So this is definitely not going to appear on BAT any time soon, then?
1935 House, 1965 Wife, 1967 Body, 1971 Sense of Humour, 1978 Musical Taste, 1988 SC MR2, 1998 AstroVan, 2002 M3, 2002 ML500, 2004 Child, 2005 M3 CS, 2006 Z4MC, 2007 Mower, 2014 Leaf Blower, 2015 GT3, 2016 Garage, 2018 Snowblower, 2019 GT3 RS, 2020 Lockdown
      01-11-2018, 01:23 AM   #56
mattfwalters
Strongly, strongly, strongly unlikely.
      01-12-2018, 06:13 AM   #57
wdb
dances with roads
wdb's Avatar
4718
BaT didn't treat the last couple of coupes very kindly IMO.
      01-12-2018, 09:09 AM   #58
mattfwalters
Agreed. The last one especially - high-mile car, but was in good shape. I think it ended up being well bought at that price.
      01-12-2018, 12:27 PM   #59
wdb
dances with roads
wdb's Avatar
4718
Agreed. I was one of those asking hard questions about it, specifically the fact that the valve cover had never been off. I thought that brought a good response (leakdown test). I also tried to balance it with high praise for the platform.
      01-12-2018, 04:40 PM   #60
mattfwalters
As was I ("so say we all").
      01-14-2018, 09:31 PM   #61
mattfwalters
Time to install the subframe and prep the engine bay for... you know... an engine.
coh661191.00
SaltyNC369.50
ZAR4MC93.00
      01-17-2018, 01:33 PM   #62
Beedub
how do you feel about the new vanos line??? i was slightly concerned when i saw the recommended interval for replacement every 12 months!!!!! especially when the stock hardline has lasted a decade in most z4m applications !
      01-18-2018, 02:52 AM   #63
mattfwalters
That replacement interval is utter nonsense. Almost as bad as the 1y recommended interval a certain vendor had published for the VANOS oil filter.
Riiiiiiiiight....
(I'm not worried. Seems like quality construction. )
      01-21-2018, 11:06 AM   #64
Beedub
any reason why you didn't upgrade the vanos hub while this was all out???? i'd have been very tempted with one of the larger tab offering units. Great great pics btw the s54 sure is a porn fest for any petrol head!!
      01-21-2018, 10:24 PM   #65
mattfwalters
I did - VANOS oil pump hub is now a Beisan unit.
      01-22-2018, 08:22 AM   #66
Beedub
let us know how you get on with it, i know the hubs are stupid money but the stock ones are clearly a weakness, im not sure the re-drilled disk really is a solution as they still seem to break!! Their is simply not enough material on those tabs !
