      12-29-2017, 11:56 PM   #45
pcube
pcube's Avatar
58
Drives: Z4MC, G20 320i
Read several bad reviews about the high vibrations with the jb lightened flywheel. Interested to hear how it works out for you.
      01-03-2018, 08:36 PM   #46
M-Cast
M-Cast's Avatar
Drives: 2007 M Coupe
2007 E86 Coupe  [0.00]
2006 Z4 3.0si Coupe  [6.00]
2002 330 CI  [0.00]
2018 BMW 240M  [0.00]
2007 M Coupe  [10.00]
Will do, that might be due to people not balancing the flywheel prior to install.
I have seen good brands come and not be balanced at all and then cheap stuff come in and be perfectly balanced. I have just got to the point of always checking prior.
I hoping to have the engine back at the end of the month. I will post a full review of all the upgrades with this rebuild.
      01-04-2018, 05:19 PM   #47
StickMon
StickMon's Avatar
Drives: 2006 MR
I've seen a few threads where, probably due to poor balance, lightweight flywheels have caused the harmonic balancer to explode.
      01-16-2018, 01:20 PM   #48
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
The UUC rattles at low RPM but it’s just noise. Runs smooth after you get through the lower bits (600-900 rpms). I’ve heard from a couple of folks it’s not abnormal but I’m not an expert on the matter. I think y’all are talking about something much more involved as well.
Just another testament. Looking to see more from this still!
◙ Shane
      02-06-2018, 08:20 PM   #49
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
My good buddy in Abudhabi had the UUC flywheel, removed it and went back to stock. It WAS noisy as hell, kinda sounded like a dry clutch Duke when idling.
Hows the engine build coming along mate? Cant wait to see some updates.
Powered by
      02-07-2018, 05:41 AM   #50
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
We are finally getting closer, hoping to get the engine back from the machine shop in the next week or two and the last of the parts are being shipped today.
Just as a recap of all the modifications this round. It seems like this has been the longest winter waiting for parts while we sit laid up
Rebuilt the Vanos - Beisan Vanos Rebuild and added the Turbo Toy TT C300 hub
Upgraded the cams - Schrick 280/272 12.5 Lift with new rocker arms
Full 3.4 L Lang Racing Stroker Kit 95mm lift
Upgraded the bearings as well.
Added the Dinan High Flow Throttle Bodies
Changed out both the Trans and motor mounts AKG Motorsports Polyurethane ungrades
New Water pump, oil cooler and radiator custom configuration from Mishimoto with braided hose lines and aluminum fittings
JB Racing Lightweight flywheel and clutch combo
Supersprint x pipe and straight pipe mid-section replacement just got in yesterday.
Geoffsteel CSL airbox - is the last part and is going out today
Lastly, I have my carbon guy finishing my new gauge panel to swap out the existing ashtray.
wdb4718.00
Mirko182.00
SaltyNC369.50
Azeka1285.50
      02-07-2018, 06:23 AM   #51
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
I was looking at that clutch/flywheel combo today.. can you do me a solid and let me know the part numbers on the parts in that kit? I already have the jb flywheel, just need to source rest.
I can't wait to hear how that stroker kit goes... Kinda hoping mine spins a bearing now... Lol
      02-07-2018, 07:17 PM   #52
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
I am heading up to the shop tomorrow and pull it for you.
      02-08-2018, 12:45 PM   #53
tiltmode43
I plead the 5th.
tiltmode43's Avatar
Drives: '18 Frontier Pro-4X, '06 Z4MR
Hey wait a second, this makes me want one even more
M-Cast, looking forward to the continued updates! Some really good stuff on the way. The stripes seem to have grown on me a bit too
-Matt
| Z4M Build Thread | @violetnites | flickr |
      02-09-2018, 04:52 AM   #54
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
OEM LuK Clutch Throw Out Bearing / Release Bearing -- E46 M3, E39 M5
I INA A #21511223582 LUK
Sachs Performance Pressure Plate - E36 Z3 M3 3.2L
Disc #184900760 3/6 SSLS 86 42070216
Cover #TYPMF240 /883082999792
E36 M3, MZ3 JB Racing Lightweight Aluminum Flywheel
Sachs
JB Racing 520-010-240
Vanne1620.50
      02-09-2018, 05:12 AM   #55
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Thanks, I ended up pulling them. I have some other ideas after all this is completed.
      02-09-2018, 10:15 AM   #56
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Sachs
Thx mate, yup, that's the exact JB wheel I have. Thanks very much for chasing up those part numbers. Love your work and can't wait to see when it turns over.
V.
      02-21-2018, 07:46 PM   #57
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
So today, I finally got my CSL airbox from Geoff Steel Racing in the UK, and I have to say I am a little disappointed in the quality. They did a great job packing it, even though DHL just dropped it at someone else's door even when it said signature required.
I have a ton of carbon fiber in my car, and I understand it can be challenging to deal with at times. But it blows my mind when someone goes through all the work and then just half aXX finishes it. Unfortunately, I am going to have to have my local guy fix it and spend additional money to get it the way I want.
I guess it does not matter if it is Varis or any other company that makes parts for our cars that does quality work.
Back to work and pull off all these decals and wait for the engine to be completed.
      02-23-2018, 09:41 AM   #58
GPower
GPower's Avatar
Drives: 2007 BMW Z4M Coupe
They did increase the price of it as well by about 300 pounds. I was really considering it. But then again the Karbonious is so much more expensive.
Is the damage in the clear coat or in the weave. You'll probably still be cheaper after refinish. Only thing is it's extra hassle.
Project looks great BTW. Love what you're doing to the car.
Good luck
      02-28-2018, 04:36 AM   #59
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
I hate it when it does that.. i am sure it will come out fine though. also not a fan of those stickers. they should have just included them in the shipping box,and you could have added them if you deemed to fit.
Starting to get itchy feet wanting to see this puppy turn over so bad...
so much good stuff in this thread.
Powered by
      02-28-2018, 04:37 PM   #60
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
Already stripped all that off, I have my local guy fixing everything and getting it up to my specs. They said they would cover the cost to fix the issues, I just wish people would do things right the first time.
      03-10-2018, 09:02 AM   #61
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
I'm very curious to see the condition of your rod bearings after your sessions in track. Do you have any pictures of that?
      03-10-2018, 02:56 PM   #62
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Amen brother. Sorry about the irritations, but like Vanne, can't wait to see the finished product. It's going to be great.
Salty
      03-10-2018, 07:40 PM   #63
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
They were pretty flat. Unfortunately, I didn't keep them once we tore the engine down. I initially thought it was the vanos as you could hear the ticking in the front of the engine. When we got it back to the shop and had them rebuild the top end and add the new cams, I had them check the bottom end as well, and that's when we saw the real damage.
      03-10-2018, 08:32 PM   #64
E90PAT
SOFLO CODING
Slovenia
199
Drives: Z4M
im picking a z4m soon and the rod bearing issue really has me on edge. How many miles on your car? The one im picking up has 70k
      03-12-2018, 06:06 PM   #65
M-Cast
M-Cast's Avatar
2002 330 CI  [0.00]
The S54 should be able to go 80 to 100k if the car has been maintained well. I went 102k before wearing out.
      03-12-2018, 07:47 PM   #66
StickMon
StickMon's Avatar
Drives: 2006 MR
These were mine after 127k miles, but I don't track it.
Still had a little life left in them.
Figure I'm good now until 250-300k miles.
