Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > Canada
      11-22-2011, 10:26 AM   #1
baege
Drives: 2022 Cayman GTS 4.0 6MT
Canadian Z4 Battery Experiences
With the pending drop in temperatures, I am contemplating replacing the battery.
It is still functioning fine at this time, but its 4.5 years old and I don't drive that often so it tends to sit for periods of time.
I got a quote of $360 taxes inc. installed from parkview bmw. $180 for the battery alone.
Curious what people's experiences are with getting the battery replaced on the Z4?
      11-22-2011, 11:30 AM   #2
nate96
Drives: TI Silver 06 Z4 Coupe
Why would you let the dealer replace it? Takes all of 5 minutes to do.
My factory battery died after having the car for 15 months. Being a sunday I ran to Wally world that was just a few blocks away and grabbed an Energizer battery that they had on the shelf. It got her started. All that mattered at the time. BMW would not warranty the factory battery so I purchased an Optima Red Top. It has been in the car now for 2 winters and doing great. This will be the third winter.
      11-22-2011, 11:31 AM   #3
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Do you use a tender when it's idle?
Mine's about the same age & still going strong, but it's stored for the winter & I use a tender when it's idle.
@ 5yrs you are close to a normal life span for a battery.
I haven't done any checking, so IDK if the $180 is reasonable or not.
The install price seems a little steep though for such a simple job.
      11-22-2011, 01:10 PM   #4
baege
Thanks for the input. I haven't actually taken a look at what was involved. I assumed battery replacement on a BMW might be a little more involved. I understand there is a tube vent involved? Did your replacement battery involve a tube vent?
      11-22-2011, 01:12 PM   #5
baege
Nah I live in a condo so a tender is not an option
      11-22-2011, 02:22 PM   #6
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
$180 is very reasonable for the BMW AGM battery up here. I paid that with a commercial discount for the spare I have in the garage waiting for the OE to move on. List I believe is $230. The reason for the high installation charge is they're using the book for all newer models where a programing match is required for battery replacement. Not necessary on the Z4 e85/86. It's a 20 minute job tops.
2006 Z4MC - #LL93158
      11-22-2011, 03:18 PM   #7
Quickid
Drives: 08 Z4MC, 06 X5 4.4i, 99 323i
^ whs.
My 2006 X5's battery died on a Sunday so my choices were Walmart, CTC , Costco, and PartSource. CTC has one with higher CCA rating than OEM and has the right dimensions.
I believe it was $115 plus tax. Easy install... just don't forget to re-install the vent hose on one side and plug the other side with plug removed from old battery.
      11-22-2011, 05:27 PM   #8
ZeD4Mr
ZeD4Mr's Avatar
Drives: Skyer Z4MR
My battery died about 6 months ago and it's my DD. However, I drive very little since I don't commute in it.
It seems that there are two OE batteries that's used. A black one with vent tube and a white one without. My black AGM battery that came with the car died and BMW just replaced it under warranty when I went in for other warranty items. I didn't even ask for it. It's white without vent tubes.
It's 3 10mm hex nuts on top of the cover to reveal the battery, then disconnect the +/-, it's out. 10 minutes with a 10mm socket.
HTHs,
      11-22-2011, 06:07 PM   #9
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
I don't believe the white cased battery is an AGM. Here's the current replacement BMW part # 61 21 7 598 775
They've actually increased the CCA to 800 due to the high amount of failure during warranty.
      11-22-2011, 07:47 PM   #10
Mirko
Mirko's Avatar
Drives: E86 Z4M, E90 328i, E84 X1
When the battery on my 330ci died I went to Buffalo to find an Autozone. Picked up a brand new battery that met all the requirements and spent I think $130 on it. Ended up being almost $100 cheaper than buying a comparable one here. You do get the warranty but only in the States so that is a downside but doubtful you'd use it anyways.
I would be willing to pay the $180 for the BMW one though. Thanks for the info .. hopefully won't need it anytime soon.
      11-22-2011, 07:58 PM   #11
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
I suspect the OTC price is not that cheap unless you're having it installed.
      11-23-2011, 07:39 AM   #12
Mirko
Mirko's Avatar
If I am to pay someone $180 to install a battery in my M then I expect the pretty blonde behind the counter to service me while they service my car.
      11-27-2011, 03:26 PM   #13
baege
Originally Posted by Quickid View Post
^ whs.
Here's a couple pics of my current battery
Is the tube on the left the vent hose you are referring to?
Couldn't find the plug on the other side you refer to?
      11-27-2011, 04:43 PM   #14
Quickid
Yes, that is the vent hose. My X5's OEM battery had two identical holes, one was plugged and the other had the vent tube attached. The replacement battery from CTC had the same configuration so I just took the plug from the old and used it for the replacement.
It should be on the exact location on the other side but it's also possible yours only have one hole.
      11-28-2011, 09:36 AM   #15
baege
cheers
      12-12-2011, 01:55 PM   #16
daveysew
daveysew's Avatar
Drives: '91 318is/'05 Z4 SC/'18 440ix
FYI, You can also use a portable power pack (I got mine at CT), leave in in the truck and plug the battery maintainer into it at the condo. You'll need to pull it out every 3-4 weeks or so and charge it back up overnight, but it will keep you battery topped up in a condo where you don't have access to an ac outlet.
Cheers,
dave
      11-03-2012, 11:51 AM   #17
TaylorP
TaylorP's Avatar
Drives: Z4mmmm
battery dies every winter
Last year was the second year in a row my batt was dead in as little as three weeks in storage.......i need a best solution for this problem....winter is nearly upon me.....can you leave a trickle charge on all the time? can you charge it while its still hooked up? etc.
TaylorP Z4M Roadie
      11-03-2012, 01:54 PM   #18
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
I've been using one of these for 5 years. Mine was manufactured for BMW by Batterytender.
http://www.turnermotorsport.com/p-41...ng-system.aspx
      11-03-2012, 02:03 PM   #19
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^whs
Get a battery tender type charger NOT a trickle charger.
I use the battery tender brand but CTEK brand also has a very good reputation.
...read up on why to use them.
http://smartercharger.com/
http://batterytender.com/
      11-03-2012, 08:27 PM   #20
TaylorP
TaylorP's Avatar
Drives: Z4mmmm
Thanks i will be checking this one out
P.
TaylorP Z4M Roadie
      11-04-2012, 09:26 AM   #21
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
CTEK is on sale at PartSource this month
