      07-09-2013, 07:27 PM   #1
VF-Engineering
VF-Engineering's Avatar
1009
Drives: F82 M4
\ VF-Engineering: Z4M Superchargers and Hex Tuning | up to 570HP /
We are happy to announce that in addition to the E9x M3 superchargers, our Hex Flash OBD2 cable is now applicable to be used on both Stages of our Z4M s54 Coupe and Roadsters (Euro and US) superchargers. Owners no longer have to ship ECU's to be benchflashed saving time and money. The Hex Flash OBD2 cable is also a fully functional diagnostic tool that can be used to read any CELs and codes. Along with this new capability, the new tuning is now done completely in-house by Hex Tuning for VF only.
Rated M Roadster's VF570 M Roadster in Bimmer Magazine:
http://www.bimmer-mag.com/issues/115...1#.UdymK231ppg
We've been celebrating this announcement with our s54 Supercharged Summer sale last month and we received plenty of requests to reserve and place orders at the end of this month past the end of the sale.
VF is happy to announce that we are extending the s54 Supercharged Summer sale until August 9th!!!
__________________________________________________ _______________
Z4M kits including FREE Hex Flash cable:
VF480 air-to-water cooled | 6.0psi | 480HP/340ftlbs.
VF570 air-to-water cooled | 9.0psi | 570HP/380ftlbs.
Click for SALE prices: http://www.zpost.com/forums/showthread.php?t=862858
The picture above includes the VF custom Air-to-Water aftercooling system only available in the VF480 or VF570 kits.
Design: VF-Engineering chose to supercharge these models to improve throttle response and mid-to-top end power with the centrifugal Vortech supercharger. Maintaining the the original BMW quality, smoothness and reliability were the key factors in the VF design. VF have harnessed reliability of Vortech superchargers with their 10 years of supercharging experience and worldwide OEM supply contacts to create the ultimate supercharger system for the ultimate driver's car.
Manufacturing: All key components are 100% made in California. This system has been fully road tested and dyno tuned on both the Mustang MD500AWD and in-house Dynojet 224XLC dynamometers with and without engine load. All kits are setup at 6 psi and create as much, if not more power than similar products running greater levels of boost.
Engineering: VF engineers spent over 12 months software testing the BMW Bosch and Siemens ECUs and resolved stalling and MAF issues faced by other supercharger systems. Software flash technology and latest BMW file versions have all been employed to provide the cleanest and the most reliable method of software installation. All test cars were put through long term full throttle testing in conditions varying from wet cold climates to hot dry Arizona desert temperature for safe-optimal air fuel ratios and knock activity monitoring. Competently-written ECU software has allowed VF to fully explore the potential of the BMW engine, making over 40% more power in most applications.
Components: VF chose to mount the Vortech supercharger with an in-house CNC machined aluminum bracket system. The unit is positioned in line with the original serpentine belt which is replaced with a longer OEM belt. The key to this design is that the OEM active-spring belt tensioner remains fully functional and eliminates belt slip or the need to manually tension the belt. The supercharger air ducts are custom molded in-house from plastic to give an OEM appearance, quality and fit. The incorporated Bosch boost overrun system is designed for smooth off-throttle cruising and deceleration with clean emissions. The crankcase ventilation system is designed to cope with positive pressure and high flow OEM injectors are supplied to fit as direct replacements without modification to the injector rail. A removable plastic air box is provided with the K&N induction filter for those who use their vehicles in persistently wet climates.
ECU Tuning: The VF supercharger system remains fully OBD2 compliant and is supported by a 1 year unlimited mileage warranty on the product only. Installation can be performed in approximately 8 hours (10-14 for E46 M3) and is non-intrusive, allowing it to be fully reversible.
Fitment: Every aspect of this kit has been fully engineered for high quality fitment and highly demanding performance and expectation. VF's in-house horizontal, turning and milling CNC's and plastic molding plant, and Vortech's reliability have been fully exploited to create a product with internationally un-rivaled material technology, quality, and performance.
  • - Hex Tuning custom tuned software flash
  • - Hex Flash OBD2 remote tuning cable
  • - Replacement supercharger pulley
  • - Top speed governor removed
  • - Replacement OEM serpentine belt & tensioner
  • - Vortech V3 SuperQuiet SCi trim supercharger (self contained, no external oil lines)
  • - Replacement fuel pressure regulator
  • - OEM High flow spray pattern matched fuel injectors
  • - Slide-in air/water heat exchanger for intake manifold
  • - VF custom molded 3 gallon water reservoir system
  • - OEM front center water radiator with OEM hangers and water lines
  • - Bosch water pump activated by key power relay
  • - Bypass valve spring upgrade
  • - Bosch MAF housing with recalibration
  • - 1 year unlimited mileage limited product warranty
  • - Replacement cast intake manifold
  • - VF CNC machined 6061 aluminum bracket system
  • - OEM BMW idler pulleys
  • - Stage 1 OEM High flow spray pattern matched fuel injectors
  • - VF Custom molded polypropylene ducting
  • - VF Custom tuned cast supercharger intake
  • - High flow Greddy Type R overrun bypass valve system
  • - Custom crank case ventilation system
  • - 4 ply silicon couplers with OEM screw clamps
  • - K&N induction filter with cold air intake
  • - Comprehensive installation CD-ROM
  • - Precision Made in the USA
VF570 Z4M Roadster vs. Stock
This offer ends August 9th. Call or email anytime, we're glad to assist!
p: 714-528-0066
e: sales@vf-engineering.com
      07-18-2013, 07:30 PM   #2
VF-Engineering
1009
Drives: F82 M4
Now shipping with all Hex Flash orders and applicable superchargers:
FREE with purchase of a supercharger kit until August 9th!!
Direct download and upload of software files and full diagnostics. FREE w/applicable supercharger kits until August 9th!
To order:
p: 714-528-0066
or click here
      08-01-2013, 07:50 PM   #3
VF-Engineering
1009
Drives: F82 M4
Only 7 days left.
Thank you everyone who've placed their order!
Only 25% prepayment needed. Pay the remaining balance with No Interest and No Deadlines when you are ready.
      08-05-2013, 02:32 PM   #4
VF-Engineering
1009
Drives: F82 M4
4 Days left!!
Place your 25% prepayment today to reserve your kit. We will not be offering these prices again.
By ordering/reserving your kit with these Sale prices, it's almost like getting a FREE Prepayment!
Z4M Coupe and Roadster: up to $1400 off
To order/enquire:
All major credit cards and PAYPAL accepted for prepayments.
Use our Order Form here: ORDER
Paypal: sales@vf-engineering.com
email: sales@vf-engineering.com
call: 714-528-0066
