      12-30-2015, 08:34 AM   #1
Nikitas_Z4mcoupe
Nikitas_Z4mcoupe's Avatar
15
Drives: Z4 m coupe
ESS VT2 525 installed
Finally after couple of years of thread checking and lots of research ESS VT2 525 order and installed.
Very happy with the result, although I am still in the break in period (only yesterday the kit has been installed) car is running without any hips or hesitation and feels really strong. Current set up with SS V1 stepped headers and 3.91diff.
After break in period I will dyno the car and keep you all updated.
Mirko182.00
      12-30-2015, 08:40 AM   #2
Beedub
well done !!! Bet your really pleased, who did the install for you?
spent a decent amount of time in rhodes this year and LOVED it... really really loved it....
      12-30-2015, 08:48 AM   #3
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
Hey!! I was really influenced by you mate....... thanks
Myself with the help of a freind who has a BMW service garage. Intercooler pipes were really a big headache, very tight fit....
I love Rhodes spend 2 years of my life there and specially Symi, a small island very near... propably you know.
Cant wait to start pushing the car, it feels amazing!!!
      12-30-2015, 11:16 AM   #4
Steenos
Drives: 2007 Z4M Coupe
2021 BMW M240i  [0.00]
2007 M Coupe  [0.00]
Well done! Have you experienced any whistling noises when you get to the higher RPMS and changing gears?
2021 m240i on order
      12-30-2015, 11:57 AM   #5
Beedub
can you make a video???
yeah the intercooler setup on this kit is a blessing and a curse in equal measure!! its a very nice setup and i love that ESS went to the trouble of A/A but my god its a pain in the ass to get right and you will probably be messing with it for a good while till its perfect.
Maybe consider loosing the blue vacuum line and replace with black, it makes a clean setup look alittle rough imo.
as i can see your not diverting air back into the intake, how about a video of the BOV sounds??
      12-30-2015, 12:06 PM   #6
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
Thanks man. Up to now I have not crossed 4000rpm still at break in period (only 50Km done) as its been raining here a lot.
Whistling is caused from the manifold dump valve outlet which is going to air, open type (the ESS plastic inlet tube bypass is plugged)
      12-30-2015, 12:27 PM   #7
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
I will make lots of videos and share it with you guys. Its been raining here so I did not have the chance to drive it a lot. A/A is the only way you were right.. my piping still needs some adjustment to be perfect, after the weekend I will try to fix it.
I still have the black one supplied with the kit incase I change my mind.
I was also a bit comfused and had to ask ESS in the beggining with the BOV but now the new plastic inlet tube bypass is plugged intentionaly in order manifold dump valve to blow into the air. I will provide video for your convinience.
Below picture of how it was supplied. I was told to remove pipe and let it blow on air.
      12-30-2015, 12:48 PM   #8
Beedub
mine diverts back into the plastic intake via that silicone elbow you have their.
i think you now have to specify you want it recircing now days, wonder why they chose to Vent from the off now? They always told me the car would run better with the air being looped back into the system.
Their v8 kits still recirc.
On side note those new VT BPVs look great!
      12-30-2015, 12:51 PM   #9
Steenos
2007 M Coupe  [0.00]
Thanks for the info sir! I may upgrade some stuff from my 455 kit. So much fun though!
2021 m240i on order
      12-30-2015, 04:40 PM   #10
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
This is what I thought, that is why I asked ESS about it. From my previous experience with turbochargers was always better to recycle the blow off to help you build up pressure. I dont know if ESS considers this as an improvement......... But I am telling you up to now I like the way it sounds, if performance is good then spot on. First chance i will post some videos so you get the feeling
      12-30-2015, 11:20 PM   #11
tikamak
Lebanon
58
The recirculation or venting off does nothing to performance with this kit.
Its just a matter of preference if you like the blow off sound or not.
Frankly i tested both and i felt that recirculating is better on the ears IMO and cleaner in the engine bay
      12-31-2015, 07:42 AM   #12
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
This is correct. I noticed no change in performance when I went from a recirculating bypass to a venting BOV.
      12-31-2015, 08:27 AM   #13
Beedub
it definitely looks cleaner with all it all plumbed in too.
OP how about a video of the sound with the newer valve? when you get chance please make something, a simple cell phone clip will do :-)
      12-31-2015, 10:38 AM   #14
NickyC
NickyC's Avatar
17508
Very nice man, awesome setup!! I'm working crazy hours all winter long to hopefully have enough disposable income to pick up an SC kit of my own. Enjoy it!
      01-04-2016, 01:20 PM   #15
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
Its been raining the last week and did not have the chance to really push the car. Managed to complete 500km so ready for dyno......
Below dyno sheet....
Very very happy with the results, 476whp and 45Kg-m.....
Next days hope it will stop raining so I will have the chance to post some nice videos
      01-04-2016, 02:36 PM   #16
Beedub
g-power stick that in your pipe and smoke it.....
some serious numbers .... unless the rollers are inaccurate thats very impressive.
      01-04-2016, 02:43 PM   #17
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
one of the best dynos in Greece. The strongests cars of the country have been dynod here........ please have a look https://www.facebook.com/pages/Dynoj...55250351247269
      01-04-2016, 03:02 PM   #18
Beedub
videos ASAP please :-P
      01-04-2016, 03:08 PM   #19
Nikitas_Z4mcoupe
15
Drives: Z4 m coupe
I will try tomorrow night!!! if weather permits......
If streets are not dry really its not possible to find traction, I tryed but even with 5th gear it spins.........
      01-04-2016, 04:21 PM   #20
NickyC
NickyC's Avatar
17508
SICK!!
      01-04-2016, 04:38 PM   #21
pokeybritches
2006 BMW Z4M  [8.50]
Can you do SAE correction factor?
      01-04-2016, 04:41 PM   #22
pokeybritches
2006 BMW Z4M  [8.50]
Where the sensitivity to G-Power from?
