      05-10-2011, 02:11 PM   #45
850tgul
850tgul's Avatar
279
Drives: 718 GT4, F87 M2, F30 330xi, X3
count me in as well
Thanks
      05-10-2011, 04:07 PM   #46
esqu1re
esqu1re's Avatar
41
Drives: M Coupe
Originally Posted by vasaline View Post
wow 20 on the list! The whole forum is gonna be running this lip!
Unfortunately, not me. The roads around here---I'd scrape the crap out of it.
      05-10-2011, 04:29 PM   #47
Jumbosock
Jumbosock's Avatar
76
Drives: 2007 M coupe
On second thought, put me in for 2. One to rock and one to stock!
      05-10-2011, 06:27 PM   #48
beta
Drives: 2006 M Roadster
+1 there are lots of places around here that I know i'm just a hair off scraping. I'm really torn because I love how good it looks on sepang.
      05-10-2011, 10:49 PM   #49
HaiDef
Drives: M240i
When will production for this start?
      05-11-2011, 12:15 AM   #50
Composite Steve
Drives: 03 330i ZHP, 73 Mini, 74 914
You got it
Let us know when you decide.
Production has begun. I'm planning to start shipping out a few this week and will continue to ship them out as they're made. Will PM each participant in the GB for shipping info when ready.
Thanks for asking.
1. barryb97
2. NickyC
3. shimmy09
4. z4murder (in for 10+)
5. vicj (in for 10+)
6. MIKe86 (in for 10+)
7. Hdoan86
8. eunosracr (in for 10+)
9. BookerM3 (in for 10+)
10. Jumbosock with a 3 pointer to make it 10! (x 2)
11.wacaw325 (in for 10+)
12.JDN34
13.jair_onsa(in for 10+)
14.CobraR1339
15. Shec44 (in for 10+)
16. nofear
17. z4-villalona
18. krnnerdboy
19.MochaV
20. McWong
21. 850tgul
      05-11-2011, 08:45 AM   #51
vicj
vicj's Avatar
Drives: '06 M Roadster; 2010 Mini
Shipping in the same order as we signed up?
      05-11-2011, 10:43 AM   #52
Composite Steve
Yes.
      05-11-2011, 02:44 PM   #53
DR Z4
Drives: 2008 M Roadster
I'm in if i can attach without drilling additional holes (or I can at least see a pic of the holes that have to be made with the current setup). Please PM or post an answer to that Steve.
      05-11-2011, 03:31 PM   #54
johanness
Drives: 2008 Z4MC
Pic from the side too pls
      05-11-2011, 06:36 PM   #55
Jumbosock
Jumbosock's Avatar
76
You guys just look under your car. There are 2 holes at each end of the car that can be used. That leaves one needed towards the middle. There are holes towards the middle but they are probably a little offset from this lip. A small simple bracket may have to be fabbed to use the oem hole.
      05-11-2011, 06:55 PM   #56
krnnerdboy
krnnerdboy's Avatar
Drives: v10 m6
by the looks of it I'm 99% sure that you can attach it w/o drilling any holes. On each fang you can see 2 bolts each. You'll just have to drill the splitter to match those holes
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm
Gone:z4m, boss 302, c6 z06, m6,z3m
      05-13-2011, 02:40 PM   #57
Composite Steve
You guys are absolutely correct. There're 2 factory bolts underneath the bumper per side. Drill 4 holes on the Mstache to match the factory holes, add double sided tape and mount it. Simple to do and no permanent changes done to the car.
Shows factory holes, the 2 bolts are already removed in the picture.
Drill 2 holes per side on the Mstache to match.
Add double sided tape on the back edges.
Bolt on to install.
And you're done
      05-13-2011, 03:48 PM   #58
Little C
Drives: 07 Z4MC
PM sent!
      05-13-2011, 04:02 PM   #59
johanness
Drives: 2008 Z4MC
Thanks Steve!
Is it just me, or does the 1st pic look parallel to the ground, but the next pic looks like it's at a 45 degree angle?
Is it an optical illusion or does it lie nice and level to the ground?
EDIT: Never mind, I see that it's up on stands. DUH
      05-13-2011, 08:34 PM   #60
Composite Steve
Thanks Steve!
You're welcome
Originally Posted by Little C View Post
PM sent!
1. barryb97
2. NickyC
3. shimmy09
7. Hdoan86
12.JDN34
14.CobraR1339
16. nofear
17. z4-villalona
18. krnnerdboy
19.MochaV
20. McWong
21. 850tgul
22. Little C
      05-13-2011, 09:20 PM   #61
MPOWER78
MPOWER78's Avatar
Guatemala
Drives: 08 /// M
Count Me In (pm) Sent
      05-14-2011, 10:12 AM   #62
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Glad I saw this. Count me in!
      05-14-2011, 05:32 PM   #63
jair_onsa
jairon2
jair_onsa's Avatar
20
Drives: vt1-445 z4 MC- 14 335i M Sport
well guys looks like this gb it's been a great sucess, congrats!!!
      05-15-2011, 08:05 AM   #64
Samjam927
The One And Only
Samjam927's Avatar
15
Drives: 2006 TiAg ///M Roadster
2006 Z4M Roadster  [10.00]
2003 Z4  [5.00]
sort of makes me wonder what this would look like with the APR splitter attached to the bottom of it
      05-15-2011, 10:03 AM   #65
MIKe86
Drives: 90 332is
Ew.
OP or anyone else with this splitter, does the double sided tape and oem hole mounting secure the splitter such that, say 160mph runs won't send it flying off? (on a track of course )
      05-15-2011, 05:57 PM   #66
Samjam927
The One And Only
Samjam927's Avatar
15
2003 Z4  [5.00]
Originally Posted by MIKe86 View Post
Ew.
not to the whole piece just that middle section in between the fangs, if the apr splitter cover that section up like this lip does then that would be hawwt
