      08-10-2010, 03:42 PM   #221
thekurgan
Bad Lieutenant
thekurgan's Avatar
Drives: E90M3
2008 BMW M3  [0.00]
Originally Posted by PatJags156 View Post
I wonder....The sport button allows for shorter gear shifting. Does the notchy, grinding and mis-shifts occur when the sport button is activated?
It's only "short" because the engine revs faster, I would imagine folks with the grind have it more with sport button engaged unless they've gone ESS on the DME
      08-10-2010, 04:56 PM   #222
Blind32
Certified Adrenaline Junkie
Blind32's Avatar
Drives: '07 Z4MC
Originally Posted by mhughett View Post
...The interesting thing is that my 3.0si coupe wasn't as notchy as the M coupe and they supposedly have the same tranny. Hmmmmmm.
Originally Posted by Ron Stygar View Post
Maybe there not.
According to realoem, the part numbers are as follows:
Z4M = GS6-37BZ - TJEE
3.0si = GS6-37BZ - TJER until 03/2007 ENDED
Replaced Previous tranny GS6-37BZ - TJES
Also not these are listed as Rmfd which I believe means remanufactuered.
Z4M
http://www.realoem.com/bmw/showparts...18&hg=23&fg=05
3.0si
Not sure what any of this means tho...Just providing the data.
      08-10-2010, 05:46 PM   #223
vasaline
Drives: 06 M Roadster
If it has triple synchos in 2nd then then it should take quite a beating and still be fine. Has the ZHP helped with the shifts? Maybe someone with the knob can chime in and if there are any improvements in the shifting with the knob..
      08-10-2010, 09:55 PM   #224
mhughett
Drives: 2007 Z4 M Coupe
I can attest that the ZHP shift knob does NOT help the issue. If anything, it exacerbates it because it creates a shorter lever requiring more effort for each shift. I've had the ZHP in for several weeks. I put the OEM shift knob back in last weekend and I actually think while the shifts are slightly longer that they are slightly smoother and require less effort. I like the shorter shifts but I'm not sure if the ZHP is going back in or not.
Retired--2007 Z4 M Coupe (Imola Red/Black, Premium Pkg, Heated Seats, XM, Bimmian stubby antenna, CDV delete, Apex EC-7--Anthracite, Goodyear F1 Asymetric 2.
      08-11-2010, 01:14 PM   #225
steveayd
Drives: 07 M coupe
I feel its def worse when sport mode is on. Guess i will deal for now. Is it even worth getting the dealer to look and tinker with it...i find they do more harm than good.
      08-11-2010, 02:20 PM   #226
PatJags156
PatJags156's Avatar
Drives: 335i Convertible
I would love to hear if someone has found a solution. My shift from 1st to 2nd is so notchy as well as 2nd to 1st.
When Sport button is on the shifts become so hard and jerky. Non-sport is much smoother.
      09-08-2010, 05:16 PM   #227
dekaliber
I don't think there's anything to get away from the notchiness. It's a characteristic of BMW transmissions and seems especially conspicuous in this particular setup. I found that the ZHP shifter provided a much better height at which to grip the knob and allowed for more precise shifts, and the UUC tranny mounts have made the notchiness much more consistent. The trifecta of ZHP knob, CDV delete (or Zeckhausen CDV), and UUC transmission mounts have made very clear improvements in the transmission setup, which is definitely the Achilles heel of this car.
I did very clearly grind 1>2 for the first time this past Saturday at an autocross (before installing the UUC mounts), shifting probably around 6500-7000K RPM. It totally caught me off guard then and I blamed it on the mounts, but thinking about it now it was more than likely sloppy, rushed shifting more than anything else.
When shifting into 2nd, you really need to make sure you're at about the right RPM. You can't let the clutch out too early, and you can't take your foot completely off the gas either, as either is likely going to make your car jerk. You need to feather the throttle some to maintain it at the correct RPM, and sport mode makes the throttle way too touchy to do so easily.
      09-08-2010, 05:31 PM   #228
MVF4Rrider
PCA, BMWCCA
MVF4Rrider's Avatar
102
Drives: 997S, MV Agusta F4, E46 M3
Read post #17
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU
      09-09-2010, 10:33 AM   #229
vasaline
When shifting at that high of a rpm range u don't really need to feather the throttle since the rpm takes longer to drop to the correct range for the next gear. I find it that I have to slow down my shifts just to have the rpm fall to the correct levels for a smooth shift
      09-27-2010, 11:53 AM   #230
FerRrari
FerRrari's Avatar
19
Drives: Catrinel Menghia
Originally Posted by MVF4Rrider View Post
Read post #17
That did it for me! Haven't had a grinding shift since I took your advice!
Thanks a lot!!!
      09-29-2010, 10:02 PM   #231
jbh
jbh's Avatar
18
Drives: 2007 Z4M
Update:
Still have not had a 1-2 grind since the mounts. On previous problem of 3-2 denial at Autox, turns out it was just my method. I guess shifting under stressfull situations at Autox I was pulling the shifter over to the left too much getting into the channel that has reverse. Of course there is no gear below reverse, so the denial of a downward motion on the shifter. Again this never happened on the street.
I have done 3 Autox events since that discovery which had several 3-2 shifts and no problems now that I know. I just pull it down real gently into second during hard braking and or turning and no problem now. I can't beleive that is all I was doing. Never had that problem in my 350Z but reverse was to the right of 6th and down so there was no way it could happen on the 350.
FYI for anyone still having problems.
      09-30-2010, 06:23 AM   #232
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by jbh View Post
Update:
IDK about the grind because I haven't had the problem.
RE; the 3-2 denial, it definitely helps with that.
see.. http://www.zpost.com/forums/showthread.php?t=430020
      09-30-2010, 08:12 AM   #233
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
I thought the grinds are related to the synchros? Anyway, I have the mounts...still grind sometimes during hard acceleration.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      10-13-2010, 11:36 AM   #234
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
I can tell you all that the z4M shifting is like BUTTER compared to my old modded DSM!
Doesn't Redline spec their D4 ATF for our tranny as opposed to MTL?
      10-13-2010, 02:58 PM   #235
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
The RP Syncromax in addition to the mounts has solutioned the 3-2 under hard braking (yes with rev matching) for both of us. The problem seemed to appear once a number of laps were run and the car was very hot before these modifications.
2006 Z4MC - #LL93158
      10-13-2010, 03:03 PM   #236
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^ if we were smart, we should have tried independent testing, instead of both RP & tranny mounts at the same time.
      10-13-2010, 03:10 PM   #237
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Normaly I would say yes - however, just engaging 1st from a stand still is silky now compared to before so I would say the RP ATF has made a difference too!
      10-07-2012, 03:01 PM   #238
G80indy
Save the Manuals
G80indy's Avatar
bringing back an oldie but goodie thread.
Since I live Indy where it gets cool I have the D4ATF from Redline in the gearbox. But this is what Redline specs for the z4M.
You guys are sold on the MTL. But why the deviation?
Who here has the RL D4ATF and has grinding?
I think for the synchros to operate to design the fluid spec would be critical.
http://www.redlineoil.com/tech_article.aspx?id=2
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
      10-07-2012, 10:34 PM   #239
vipergts450
vipergts450's Avatar
Drives: 2008 Z4 M Roadster
Funny that you also brought this thread back - I wanted to update everyone that I just got the car back after 2 weeks at the dealership for a transmission replacement. The 2nd gear grind got worse over the past few months to the point where engaging 2nd gear at all was a hit-or-miss affair, regardless of how hard I was driving it. Dealer said the synchro failed and they found some metal in the tranny fluid as well. Thank god for the CPO warranty...
New transmission feels super tight, but I haven't tried any high RPM 1-2 shifts yet until it gets some more casual shifts on it.
      10-07-2012, 11:41 PM   #240
RADRACR
RADRACR's Avatar
This is all anyone cares about so keep us posted.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      10-08-2012, 01:26 AM   #241
G80indy
Save the Manuals
G80indy's Avatar
Break her in right.... a fluid change at 1200 miles I suppose.
Did the mechanic state if this synchro failure was a rare thing or not?
2023 G80 6MT, CCBs
      10-08-2012, 10:00 AM   #242
vipergts450
I tried to get a real answer out of him, but he gave the BMW party line that "synchros break sometimes no matter what you do" and "the M transmission was made to be driven hard, so you shouldn't worry about it too much." That said, given the history of this thread and the numerous reports of gear issues, I wouldn't be surprised if it's not as rare as we hope. The real answer I was looking for and couldn't get was whether the NEW transmission is a revised model which fixed the defects of the original, or if it's just a replacement of the exact same model. I really, really don't expect to (or should have to, for that matter) shell $10K out of pocket in another 30K miles to replace it again...
My odometer is about 29500 right now. For those of you who have also experienced consistent grinds, how many miles do you have on your Z4M's?
