Go Back   ZPOST > BMW Z4 Roadster and Coupe > Regional Forums > USA - California
      06-13-2022, 06:58 PM   #1
tenfootelvis
Drives: 2006 Z4 Si Roadster
Mechanic/Shop for Z4 top SF Bay Area?
My top mechanism won't work properly. I can hear the pump/motor working and it will open but it seems to not generate enough pressure to raise the top at all. Not sure if it's maybe a pump problem or maybe a hydraulic leak. My normal shop in Walnut Creek won't work on the top.
Does anyone have a recommendation for a good shop that works on tops? Ideally in the SF EAST BAY area. Thanks!
      04-04-2023, 06:52 PM   #2
WAGMI
Drives: '08 Z4MR
Did you ever find one?
      06-08-2023, 01:25 PM   #3
gartnert
gartnert's Avatar
Drives: 2004 Z4 3.0i
I can help
I am in San Jose, just repaired my top. the hydraulic hinges had a seal break so had to replace hinges.
Tags
mechanic, shop
