11-15-2010, 10:22 PM | #1 |
Rep 82
I think I need new control arm bushings....?
My z4 tends to want to go in both directions sorta. It pulls left to right with a wobbly feeling. When you tap on the brakes you can visibly see what looks like the front wheels bounce front to back like dribbling a basket ball. I'm wondering if is the control arm bushings that could cause this. Also, if it is, then is that something I can easily change myself? I've done brakes, and clutches, so I'm a decent home mechanic. Will it need a new alignment after?
11-15-2010, 11:12 PM | #2 |
///M'n it Up
17
Rep 344
Only a visual inspection of the bushings can tell you whether you need new bushings. Post pictures, and we can tell you.
You might just need an alignment. |
11-15-2010, 11:16 PM | #3 | |
Rep 82
ok thanks
Edit: From what I watched on a video, it looks easy to change if it really needs the bushings. It looks like 2 bolts then tear off the housing then pull off the piece that is still attached. Then tap on the new one and bolt it down. Last edited by Jeffrimerman; 11-15-2010 at 11:42 PM.. Reason: info |
11-16-2010, 02:54 AM | #4 |
Rep 2,782
Front control arm bushings are a breeze. If they haven't been replaced by 123k miles then you probably need them. Use a gear puller to get the old ones off and some Dawn soap to lube up the new ones as you slide them on. Do NOT use an air chisel. I replaced mine with the Bavauto heavy duty bushings at 108k miles. The difference in handling was night and day.
11-16-2010, 07:26 AM | #5 |
Rep 2,703
Drives: 2009 335i - Sport PKG
Do you guys mean he should replace lower control arms and bushings?
11-16-2010, 11:18 AM | #7 |
///M'n it Up
17
Rep 344
11-16-2010, 07:16 PM | #8 |
Rep 2,782
11-17-2010, 01:43 PM | #9 |
Rep 82
Here is a picture, but I can't see if it is bad.
With 123k miles I will change them anyways. My drifting steering must be from bad ones. How do I remove them? Do I need to remove the big metal thing from under it first?
11-17-2010, 02:02 PM | #10 |
Rep 374
11-17-2010, 02:06 PM | #11 | |
Rep 82
Thank you Nickpapa
11-17-2010, 02:17 PM | #12 |
///M'n it Up
17
Rep 344
Hard to tell exactly from that picture, we'd need one that's up close and personal with the rubber center of the bushing.
However, from what I can see, that bushing looks fine. Its very normal for the bushing to be ok after 120k miles, especially if the car has been garaged and driven in a temperate climate. You should try having a simple alignment done first. You might also check the steering rack and rubber components. |
11-17-2010, 02:22 PM | #13 | |
Rep 82
ok Thank you
11-17-2010, 02:25 PM | #14 | |
///M'n it Up
17
Rep 344
Yes, you should look at the tie rod ends to see if they're rotted and sticking. |
11-17-2010, 02:31 PM | #15 |
Rep 4,365
What's a tie rod? Haha. I need a mechanic friend so I can have some clue what you guys are talking about.. especially since I want to start doing my own work...
11-17-2010, 02:46 PM | #16 |
Rep 82
ok hehe, I will check it out
When I first posted I mentioned the front wheels moving back as one taps on the brakes. I'm thinking the bushings seem most likely since the steering related things shouldn't allow the wheel to be straight, but literally move back a couple inches. Or maybe they will also.
11-17-2010, 02:48 PM | #17 |
Rep 374
11-17-2010, 03:42 PM | #18 | |
///M'n it Up
17
Rep 344
Follow the evidence. If the bushings are fine, its not the bushings. |
11-17-2010, 06:34 PM | #19 |
Rep 82
Here's little more info that might help. My front tires have worn perfectly fine. I've put 50k miles since I bought the car and they were used before that. Would an alignment issue allow for that? It feels like there is some play of some sort as if the left and right tire want to go in different directions, so a little wobbly, but I've driven it like that all the time and just thought maybe the wider tires caused this. On the freeway if there is a lane with one grain, it is fine, if there is two(when they redo the lanes from what was two different lanes) the tires seem to fight each other for control of which direction to go. Not sure if they sheds any more light. I ordered some bushings on ebay and will change them since they weren't expensive and I can eliminate one thing.
11-17-2010, 07:27 PM | #20 |
Rep 2,782
11-20-2010, 05:25 PM | #21 |
Rep 82
ok so I changed the bushings.
I haven't taken it on the freeway yet, so I won't say it was taken care of for sure, but on the streets it feels like I am getting more feedback from the road. It's always been the way it was before, so is that normal to have a little feedback in our cars? By feedback I mean I can feel the road in the steering wheel. The old bushings had a lot of play even though they weren't totally destroyed.
