      04-23-2014, 10:22 AM   #353
Z4Murder
Z4Murder's Avatar
Drives: > speed limit
will (18x9 et 31 with 245/40/18 front, 18x10 et 25 with 275/35/18 rear) fit well on stock suspension? thanks
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 *
'14 Jeep Grand Cherokee Overland Hemi... No more snow for the M!
      04-23-2014, 11:04 AM   #354
Beedub
stock e92 m3 18" 260 wheel fitment.
8.5"x18 et 29 front & 9.5 x18 et 23
front fitment is less than ideal, needs significant camber to tuck into the fender ( not an issue with my aggressive track setup) running a 235/40 semi slick and this is as far as i comfortably can go, 245 i tried before hand rubbed significantly ( luckily i only tested static and by getting my GF to turn wheel while stationary so no damage caused)
Rear fits perfectly, on semi slick no larger than a 265/35 , anything larger will rub.
ill report back after my first track day, i may need to dial I more camber up front as it may still rub with -2.7 i have at the moment, its definitely close.
All in all this really works well on an aggressively setup car and looks very nice, the fenders are filled like pamela anderson's Bra.
      05-07-2014, 10:59 AM   #355
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
I'm currently running the following setup
19x9 +30 (245/35/19) - Nitto NT555
19x10 +18 (275/30/19) - Nitto NT555
On Fortune Auto Coilovers (~2" drop and -1.5 Camber (Front)/-3.0 Camber (Rear), fenders are rolled. The rears are fine but the front rubs on the liner pretty bad on the area where the fender liner and bumper connect when turning. Does anyone know if by going to a smaller tire size will help? Maybe a 235/35/19 or should I go lower profile too? Thoughts? Thanks in advance
      05-07-2014, 11:07 AM   #356
RADRACR
RADRACR's Avatar
I think a smaller tire will look weird and will promote understeer. Perhaps more camber? I have same front spec as you on a 8.5" wheel. Full lock to RIGHT rubs, but LEFT does not. What's interesting is that it started doing this after my BBK, which must have offset the wheels 2mm tops. So I think it's just barely rubbing for you if you can knock off 2mm or so.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      05-07-2014, 11:39 AM   #357
R0ME0
"The Midas Touch"
R0ME0's Avatar
521
2017 M2  [10.00]
What would look weird? running a 235/35/19 in the front? or running a 235/30/19 or both? When I was on my H&R (~1" drop) spring drop I was rubbing very slightly but now that I'm lower on coils it rubs pretty bad. I just want this to be drivable
      05-07-2014, 11:43 AM   #358
RADRACR
RADRACR's Avatar
If you don't mind the stretched look and a bit less grip, it's an idea. Personally I would try camber first. Like -2.5 to -3.0
      07-18-2014, 05:07 AM   #359
asirvr4
Oman
38
Drives: '06 M Coupe VRS Blue
my current setup:
Apex Arc-8 Nitto Invo
F 18 x 9 ET42 245/40-18
R 18 x 10 ET25 275/35-18
15mm spacers at front. 5mm spacers at rear.
Lowered with KW V3. At minimum height it rubbed like hell. Raised it, now rubs little at front only.
If I stay at my current wheels setup, which front tire size I should get:
245/35-18
or
255/35-18
or
235/40-18
And which rear tire size to match?
      07-21-2014, 04:28 PM   #360
007M
007M's Avatar
17
Drives: '007 ///M Coupe & Boxster S
I'm currently running stock everything (except a supercharger) and I'm in need of new tires and was hoping to get new rims at the same time. I happened upon the following:
VMR V710
F: 19x9.5 et 22
R: 19x11 et 25
I've gone completely through the "aggressive wheels" thread and this thread and have found that the closest thing anyone has run without rubbing is:
F: 18x9.5 et 35 +5mm spacer @(245/40/18)
R: 19x10.5 et 25 @(275/30/19) or (285/30/19)
I would *LOVE* the extra traction but don't want to mod my fenders, and I would prefer not to use camber plates. I'll use spacers where necessary.
What do you guys think? Will they work?
Thanks in advance!
GT
      07-25-2014, 06:17 PM   #361
heligarret
Drives: 2007 Z4M Roadster
Fit???
Hi new to the form and bought a 2007 m roadster last week. Looking at some mods ie. wheels exhaust and short shift kit. If anyone wants to sell any of these feel free to contact me.
Can anyone please give me some advise. I have found these wheels and tires and wondering if they will fit 2007 Z4M roadster.
Wheel/Rim:
Brand OE Replica Wheels
Make Alloy
Structure One Piece
Finish Black / Machined Face
Front Size 19x8.5
Offset 35
Rear Size 19x9.5
Offset ET 37
Bolt Pattern 5x120
TIRES Size Front - 235/35/19 Rear- 265/30/19
Thanks for any and all advise
      10-20-2014, 06:43 PM   #362
UntzUntzUntz
UntzUntzUntz's Avatar
Drives: 21 M2 Comp
Originally Posted by asirvr4 View Post
my current setup:
245/35-18
or
255/35-18
or
235/40-18
I have almost the exact setup. ARC-8 18x9 in the front with 12mm spacing and 18x10.5 in the back. Also lowered on V3's.
Tire specs:
245/40/18 front (also rubbing)
275/35/18 back
For the front, stick to 245/40/18, I stress the 40 so the tire diameter would be equivalent to the back tire. Otherwise it won't be the proper rolling diameter.
For the back, 275/35/18 would give you the most performance.
I'm not even flush and it's rubbing on hard cornering. And maybe it's just in my head, but it only happens when going downhill.
This Wednesday I'ma corner balance it. Hopefully it goes away
      11-07-2014, 04:26 PM   #363
Z4Murder
Z4Murder's Avatar
bump
2007 TiAg ///MCoupe
      11-15-2014, 09:31 PM   #364
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
bump
I think so. Some have run a 265 front with stock suspension on a 9.5 wheel with 9.5 ET35 wheel with 5M spacer (that's a 30 offset). A 9 ET31 has more 5mm more space to the strut and 7mm more from the fender. YMMD depending on type of tire (square or rounded sidewall) used, camber settings, and so on. Rear is no problem.
Have a look for yourself and do the calculations. Don't count on me only!
      11-18-2014, 02:06 PM   #365
Z4Murder
Z4Murder's Avatar
Cool, thanks for the input. I think i'm going to be going with the NT05 again this spring
2007 TiAg ///MCoupe
      11-27-2014, 02:56 PM   #366
VossenCoupe
Drives: Z4 M Coupe
i run on vossen cv3
front 9x20 et35 hancook 225/30/20
rear 10.5x20 et27 hancook 265/25/20
no rubbing at all
full lock steering no problem
      11-27-2014, 05:54 PM   #367
Nate4641
Nate4641's Avatar
Drives: '07 M Roadster
Originally Posted by VossenCoupe View Post
i run on vossen cv3
no rubbing at all
Those look like they're photoshopped on! lol And the treadwall is so thin, is the rubber just glued to the wheel? Looks pretty sweet!
      11-28-2014, 12:25 AM   #368
VossenCoupe
Drives: Z4 M Coupe
whaha no photoshop
      12-16-2014, 07:04 AM   #369
evel karnievel
braaap
evel karnievel's Avatar
Germany
44
Drives: Z4M QP
has anyone mounted the follow wheelspecs?
front: 18x8,5 ET35 (like apex)
rear: 18x9,5 ET35
      12-16-2014, 07:12 AM   #370
RADRACR
RADRACR's Avatar
rear: 18x9,5 ET35
Front works. You'll want a 10-15mm spacer for Rear.
      12-16-2014, 07:51 AM   #371
evel karnievel
braaap
Germany
44
Drives: Z4M QP
rear: 18x9,5 ET35
Will it rub on the inner side without a spacer?
      12-16-2014, 08:27 AM   #372
RADRACR
RADRACR's Avatar
Not sure about that, but you'll be 12mm closer to it. And it won't look good. If you're conservative, go with a 10-12mm spacer.
      12-16-2014, 10:14 AM   #373
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Originally Posted by intoflatlines View Post
Stock suspension/alignment
245/40/18x9 ET42
275/35/18X10 ET25
BFGoodrich Rival
No rubbing in daily driving but I will report back after the first autocross of the season.
Did two autocrosses without rubbing. Then I got camber washers up front. Tires wouldn't clear the struts so I had to get 5mm spacers. No rubbing for 4 more autocrosses with that setup. So I am currently at:
245/40/18x9 ET37 (ET42 plus 5mm spacer) -2.7* camber
275/35/18x10 ET25 -2.1* camber
      12-31-2014, 08:31 AM   #374
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
19x11 +17 275/30/19
19x10 +15 235/30/19
No rubbing at all
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
