05-26-2012, 01:47 PM | #1 |
Rep 61
18x9 +40 Tire size and flush look questions
Hi,
I have a set of wheels for the rear, they are 18x9 +40. My questions: - to get a flush look, how can I accomplish this? I assume spacers? what size? - what is the widest tire I can run on this? I was told 275 but a bit of bulg. Anyone have photos of 275s on a 18x9 wheel? Thanks in advance! |
05-26-2012, 02:03 PM | #3 |
instagram 997turbotom
284
Rep 7,377
I'm running 265x35x18 all around, 12mm spacer up front and 18mm in the rear. Lowered about 1.5" on coilovers. Its a good fit, minor fender lining in the front that can be cured with a heat gun. You can probably be more flush on a 22-23mm spacer in rear, and 15mm spacer in front if you roll the fenders
05-26-2012, 04:25 PM | #6 | |
Rep 12,568
06-18-2012, 10:14 AM | #7 |
Rep 446
Drives: 2013 335is
I am looking at a set of MRR GT-7's with 35 offset on front and rear, will would I need spacer to get the wheel all the way out to the wheel wheel? 8.5 x 18 35et and 9.5 x 18 35 et.
Regards
2013 335is E93 2018 X5 35d BMWCCA / ZSCCA Member |
06-18-2012, 10:37 AM | #8 | |
Rep 208
The spacers (they are nice) are for sale and listed here - http://www.zpost.com/forums/showthread.php?t=655700 |
