06-01-2011, 04:18 PM | #1 |
Rep 7
Switching to non run-flat tires?
What are the pros and cons of switiching from the run-flat tires on a 2003 Z4? Is it possible? Is it adviseable? I have heard that non run-flat tires provide a softer ride and last longer. BUT . . . what happens if you get a flat or blow-out and you have non run-flat tires? Is there even a way to jack-up the Z4? Thanks for insights and info.
06-01-2011, 04:40 PM | #2 |
701
It's possible, feasible, and advisable. I'll be honest, I'm biased on RFTs. They're expensive, noisey, overly hard/harsh due to the necessary sidewall constuction, and difficult in many cases to repair. A good set of real tires belongs on a car like the Z.
As far as tire issues, get a tire-fix kit/pump (like this one) and a tire plug repair kit. The "M" version comes with a tire sealing goop and a little cig lighter plug in pump. Many of us supplement that with a tire plug kit (Google "tire plug kit"). As for tire options themselves, it depends on your needs (performance, all-season needs, weather/location). In your case you might do well with an good summer performance tire for the warmer parts of the year and snow oriented for winter. Conti DWS might be worth looking at as you could run the DWS year round if you want one set. If you don't plan to run in snow/cold/winter, and plan on driving hard or doing autoX or tracking, then car a more performance oriented tire would be indicated. What are your needs/goals for this car/tires? |
06-01-2011, 07:44 PM | #3 | |
Rep 49
06-02-2011, 12:37 PM | #4 |
Rep 956
I switched to Conti DWSs and got a spare with a bag to throw in the trunk. It was worth every penny. I would never go back to those awful run-flats. I run the Contis all year long in Chicago driving in ridiculous snow last winter and it was great. I would recommend it without a second of hesitation.
06-04-2011, 12:43 AM | #5 |
Rep 7
Thanks a bunch . . . to each of you. Makes sense. I live in Colorado, so I'll try the Conti DWS for all year wear. By the way, I'm originally from Chicago (inner city) and grew up with the hot, steamy summers and the cold, freezing winters. One tire that is good for both seems that's the way to go. Thanks again.
10-04-2011, 02:10 AM | #6 |
Rep 1,461
Biggest pro for run flast is.....when you have a tread explosion(LIKE I DID) you can keep going..con ride can be harsh...and when you need to replace them do it ride gets reallllly brutal....but It gives me serious peace of mind when I have mine on them....
10-27-2011, 11:08 PM | #8 |
Rep 1,034
Yes, regular tires fit the stock wheels just fine, if it was an issue someone would have probably mentioned it.
11-04-2011, 08:03 AM | #10 |
Rep 4
I put non-RFT Michelin on the back, the front tires still have tread so left the RFTs on, seems the car 'swims' a bit now and handling is a bit touchy, anyone have experience on having non-RFT and RFT on the car at the same time. 2006 Z4 3.0Si
11-04-2011, 08:38 AM | #11 |
Rep 1,034
I had a mix of all season on the front and summer on the back, I hated it. It was fine in a straight line, but long sweeping turns messed with the traction control.
11-04-2011, 08:52 AM | #12 |
Rep 623
One odd thing I noted with my run flats is:
They replaced the rears when I purchased her. So I really could not justify replacing them. After 10,000 miles when it came up again that just the rears needing replacing...I made the mistake of having them put the same thing back on. It is very odd after 10,000 miles the tires they felt much better. I would venture to say that the sidewall starts to breakdown or give more with age? Then again I am not a tire engineer so I may be full of crap. With the tires feeling much better (I thought I was just getting used to the RFTs). The new ones tramline horribly, I am looking forward to 10,000, miles form now, as I will not make the mistake again. On certain roads I feel like I am fighting her to drive. Steve |
11-04-2011, 11:31 AM | #13 |
Rep 376
I have been considering switching to non-RFTs when I need to get some tires. Especially because of all the discussion of tramlining which I notice on certain parts of I-5. Last time I was at the BMW Parts Center at my dealer, I was talking to the guy behind the counter about tramlining, switching to non-RFTs and getting the Mobility Kit. He said that tramlining is NOT caused by the RFT tires but instead caused by sport tires. There are so many people on this forum that have been driving Z4s for years that swear it is the RFTs that cause tramlining and I tend to believe them over one person behind the parts counter. However, now he has me wondering...
06-04-2012, 12:29 PM | #15 | |
Rep 69
I switched to Continental Extreme Contact DWS and my tramlining is totally gone. The DWS tires are smoother and quieter and give superb traction. The added benefit is that I will have great traction below 40 degrees instead of 4 hockey pucks. Ask yourself why BMW does not install RFTs on the Z4M but instead uses real performance tires and provides the M a tire inflation kit for emergencies. I carry a can of Slime fix-a-flat, a small Slime pump and a plug kit (all of which I carried and never used on my motorcycle) |
06-04-2012, 03:07 PM | #16 |
Rep 987
I hate RFTs. I have a donut spare and jack that I keep in the car when I go far from home (mini road trip). Otherwise when in town I just drive around with regular tires and if I get a flat I'll call a family member to bring me the spare. It's always in the garage to throw into the trunk when needed.
