      04-08-2015, 11:01 PM   #1
ajw45
Drives: Z4M Coupe
Harness Mounting?
Hey there, trying to plan out a fixed back seat and harness solution for the coupe and ran across these pics of harness mounts through the OEM trim. Is this anyone's car? Does anyone know if there are hard points behind the trim that are safe for mounting harnesses? Seems like a great way to have a bar and harnesses without taking any space behind the seats or losing the storage compartment....
      04-09-2015, 09:22 AM   #2
F360C
Drives: E86 S54
Wow this is a great idea! Would love more info on this.
07 Z4 M Coupe AW/IR
      04-09-2015, 10:45 AM   #3
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
Seems like quite a clean install, I person would be a little anxious that those two mounting points would be able to hold up to potentially a lot of force with a front end collision, regardless to what they are fixed to. In addition it's very important to get the height of the anchors correct esp when using a hans device, that the belts don't pull down too hard in a collision.
      04-09-2015, 01:30 PM   #4
F360C
Drives: E86 S54
It looks like they mounted it to the same location on the bulk head where the stock seat belt retractor is located. I will need to tear my car apart to verify this but looking at pictures on the internet it seems that is the mounting location they used. I circled in red in the pictures below what i think is the seat belt retractor.
07 Z4 M Coupe AW/IR
      04-09-2015, 02:46 PM   #5
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Subscribed.
      04-09-2015, 02:51 PM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by F360C View Post
........... I circled in red in the pictures below what i think is the seat belt retractor.
Confirmed.
Those are definitely the seat belt retractors.
I just finished reinstalling mine.
      04-09-2015, 02:51 PM   #7
F360C
Drives: E86 S54
I was able to find the company that did the bar..... The shop is called Cantrell Motorsports in Washington state. I wonder if they made a jig for the roll bar or harness mounts?
07 Z4 M Coupe AW/IR
      04-09-2015, 02:53 PM   #8
F360C
Drives: E86 S54
Confirmed.
Well if it is a strong enough mounting point for the stock belts maybe will alittle extra reinforcement it would okay for mounting harnesses
07 Z4 M Coupe AW/IR
      04-09-2015, 08:40 PM   #9
sipman
Drives: 2007 Z4MC
subscribed
      04-10-2015, 11:32 AM   #10
z4msteve
Drives: '07 Z4MC
Just to throw something else into the mix, I've been talking with Terry @ Vorshlag about having a harness bar made or some kind of solution. This might be something else worth looking into.
RPI scoop, Euro headers, SS PowerLoop, Epic race tune, AKG motor/trans mounts, Turner camber bolts
      04-10-2015, 02:31 PM   #11
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
Ill subscribe!
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      04-10-2015, 08:26 PM   #12
fullerra
fullerra's Avatar
14
test test  [0.00]
I don't want to pee in your soup, but a buddy of mine from work who is building a 944 track car, relayed to me that there is a current recall of Recaro seats (not sure what specific model(s)) b/c the shell was unstable in the event of impact. (as per HMS motorsport)
If the anchor point and bolts you are using are solid, then this otherwise appears to be an excellent option, and something I would have ended up going with a couple yrs ago before the half-cage went in.
      04-10-2015, 11:00 PM   #13
ajw45
Drives: Z4M Coupe
If I wasn't in MA, I would just send my car to them Also, the bar seems to be welded to the bulkhead and the rear shock mounts. I wonder if the rear bulkhead is strong enough to mount the roll hoop to vs. the floor.....
      04-10-2015, 11:26 PM   #14
Finnegan
Finnegan's Avatar
This is what I found.
http://www.nasarockymountain.com/nas...ead.php?t=6684
      10-26-2015, 04:17 PM   #15
mfanatic325
///M-fanatic
mfanatic325's Avatar
Taiwan
193
Drives: '01 911 Turbo
I don't have a cage of any sort, but I've been using the following...
Floor mounts: Macht Schnell (same as E46 fitment)
Side mounts: Sparco steel mounts
Seat: Sparco Pro2000
Harness: Sparco 6-point
Harness bar: custom bar from a shop up in Canada, which makes use of the factory B-pillar mounting position. I bored the existing holes in the B-pillar just so I could put in larger bolts (felt it would be safer).
