      01-27-2014, 07:45 PM   #1
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
Drives: F87 LBB ///M2
2017 M2  [10.00]
2008 Z4M - SOLD  [0.00]
Will this agressive 19 setup fit? (How much camber / Fender Rolling involved)
I am looking to go with the following 19inch setup, would love to get feedback if anyone has run it before. Trying to avoid rubbing and wanted to see your experience with it and how much fender rolling (if any is required) and how much camber you ran). Currently running H&R springs but looking to go lower on coils. Thanks in advance!
Front:
19x8.5 +30
245/35/19
Rear
19x10 +20
275/30/19
      01-27-2014, 08:16 PM   #2
DRedman45
DRedman45's Avatar
35
Drives: E86 //M coupe
That's really not that agressive, you should be ok without any rolling with the springs, the rear may need a bit of a roll when you switch to coilovers
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread
      01-27-2014, 09:28 PM   #3
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
2017 M2  [10.00]
Thanks for your feedback. Will this be overall pretty flush or a bit more on the stanced side? Do you think I can tuck a 255 / 285 on there instead since the setup isn't super aggressive? Will I need camber plates and arms to make this work? I'm a bit concerned of the front plastics rubbing, but I'm trying to go for a great but functional stanced fitment. Thanks again!
      01-27-2014, 10:19 PM   #4
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
2017 M2  [10.00]
The offsets can be custom but I have to stick to a 10 in the back and 8.5 in the front. Any recommendations would be nice. Looking for a good pretty agressive stance but still have great function for daily. Maybe going a bit more aggressive say:
19x8.5 +26 (245/35/19)
19x10 +15 (275/30/19)
      01-28-2014, 10:47 AM   #5
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
2017 M2  [10.00]
Anyone?
      01-28-2014, 10:53 AM   #6
angelr
Drives: 07 aw/ir m coupe, 2013 S4
The backs might rub a little on the outer liner if you go very low but wouldn't require much to gain the needed clearance. I run a 10" et 22 in the rear of mine with a 265 tire and can tuck the wheel and tire without issue. up front you'll be fine, that's not aggressive at all. I run a 9.5" et 26 up front with a 265 and have a little rubbing on the liner at the leading edge after a mild fender roll and with camber in the mid -2 range currently.
I'd run your original 10" et 20 out back and change the front to the et 26,maybe even go to a 9" at that offset if you have the option.
      01-28-2014, 01:30 PM   #7
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
2017 M2  [10.00]
Did some more measuring and changed it up a bit:
Front:
19x9 +30
245/35/19
Rear:
19x10 +14
275/30/19
Rears should be good with some camber, rolling and heating up the liner
The fronts, I hope there will not be too much rubbing on the front with my H&R drop. Planning to camber as well.
      01-28-2014, 09:06 PM   #8
i2ichal2dZ4M
Drives: 2007 BSM Z4MC
front should be fine, you rear is pushing it.
      01-29-2014, 04:05 AM   #9
R0ME0
"The Midas Touch"
R0ME0's Avatar
519
2017 M2  [10.00]
Thanks Bud! Dialed back a bit. Making my order now!
Front:
19x9 +30
245/35/19
Rear:
19x10 +18
275/30/19
      06-13-2014, 12:14 PM   #10
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
Front:
19x9 +30
245/35/19
Rear:
19x10 +18
275/30/19
Curious which wheels you ordered man!
