      10-24-2013, 07:12 PM   #23
The_Ring_Monster
The_Ring_Monster's Avatar
Drives: '07 Z4M
That looks awesome. Great, now not only do I have to choose between EC7 and ARC8, I also have to decide between 17" and 18" ... Thanks guy!
      10-25-2013, 10:28 AM   #24
Platinum Child
Platinum Child's Avatar
128
Drives: Tiag z4mc
Looks terrible in my opinion, but I'm sure it works very well on the street/track and must have a super comfortable ride.
Also, you must love ordering tires now
IG - @sd262
      10-25-2013, 01:07 PM   #25
3002 tii
3002 tii's Avatar
2282
I'm not a fan of the stretched stanced look which I know is what you like but different strokes for different zed owners.
I sold my Apex 17's after I got my bbk but I loved the way they looked at the time. Meaty tires with a wide aggressive profile.
Follow for latest mods
      10-25-2013, 01:44 PM   #26
angelr
Drives: 07 aw/ir m coupe, 2013 S4
I've thought about 17's as well due to lighter wheels and cheaper tires. Wonder if I can find a wheel to clear my rear brakes in 17? Will have to measure and have a look. I've currently got stockers, 18x9.5/18x10 her r43's and a set of 18x9.5 3sdm 0.001's for the car. Would like to have another option for track tires.
      10-28-2013, 04:39 AM   #27
Beedub
wonder if the 17s would clear my AP BBK...... hmmm i love the look and the tyre cheapness.
the 17 x 9....... 17 x 10...... are great sizes....
APex, any chance i could get the AP BBk template to you for you to check this for me??
Edit ; here it is..
http://www.apracing.com/Drawings/P16230.pdf
      10-28-2013, 11:42 PM   #28
mtrhed
mtrhed's Avatar
13
Drives: 06 AW Z4MR/w211 e63 AMG/325XiT
I think it looks sweet! The wheels and the tires!
I have a set of Kosei K1 in 17x8.5 that I have used on my old e46 and on my e28. Just found that they will clear the stock M brakes so I'm gonna see how they look! Not as nice as the arc-8 but nice and lite.
Update! Mounted the 17/8.5 Kosei K1, 18mm spacer rear/5mm spacer front, shod with 235/45r17 PSS today and went for a drive. Better acceleration, car feels much more nimble, didn't notice any sacrifice in handling/grip although I know ultimate grip is reduced, especially in back. Think I'll use these tires up and mount 255/40r17 next.
Thanks for the idea!
06 Alpinweiss Z4M R
Anthracite Apex EC-7 9F/9.5R, 245/275 Super Sport's, 17" Kosei K1 255/40r17 Direzza II, SS Lines, Pagid RS29, Ate SuperBlue, VT Comp. MM's, RE trans. mounts, AST 4150, Swift springs, Vorschlag camber plates, RE RSM, H&R swaybars, spherical rtabs, SuperFlex poly fcabs, StrongStrut Braces, Euro Headers, Stromung exhaust, ESS Tune, Eventuri intake
      11-02-2013, 12:17 PM   #29
drbvac
drbvac's Avatar
Drives: 2006 BMW M COUPE
Question for EDDY
They will absolutely fit over stock brakes. Every ARC-8 size can clear stock brakes. A Big Brake Kit usually requires 1-2" more clearance than stock.[/QUOTE]
WHAT would be the largest size 17' wheels for a M-Coupe with stock suspension - not tracked - just like the beef and width
Any idea of tire sizes for max width wheel
Thankkz
2006 M COUPE - 380 total production, 1 of 40Imola Red produced for NA , ESS 455 Supercharger, Speedhut Gauges, VPM CLS wheels, 19" Hancooks, Stromung Exhaust, Carbon fibre accessories and black and white badging,
      01-20-2014, 11:46 PM   #30
S2000
Drives: E86 Z4M, E60 M5, E92 M3
Originally Posted by colatkitty View Post
17" vs 18"
How does the 17" cs 18" compare on the track with the same tire width and rubber compound? For example : RA-1 275/40/17 vs 275/35/18)
      01-21-2014, 02:59 AM   #31
Beedub
the z4m looks so right with smaller wheels and a fat tyre......
      01-22-2014, 12:10 PM   #32
gmd2003
gmd2003's Avatar
352
265/35/18 and 285/30/18 Hankook TD's on Apex EC-7 18x9 et31 and 18x10 et25 , no spacers , KWV3's , camber plates , -3.2 front ,-2.2 rear , clears PFC 355 mm BBK with ease . Out handles a Porsche GT3RS on R comps in the corners .
      01-23-2014, 03:14 PM   #33
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
I can't tell you how long I've stared at this thread and this particular meaty set up.
I want to do something like this so bad, but I do not have the means to get lower to make this work (which looks to be a very key part in this). But I want that meaty look without having to increase wheel gap.
This is an absolute dream, and this thread will likely be bookmarked until 2 years down the road when said mods will likely come into play.
      01-23-2014, 08:04 PM   #34
fullerra
fullerra's Avatar
14
Drives: 08 Z4M Coupe
test test  [0.00]
2008 BMW Z4MC  [0.00]
Damn uuuuu!
This setup is badass!!
Now I have to think about a 17 inch wheel option!
      01-23-2014, 10:04 PM   #35
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
I forgot how beautiful your car is
      02-18-2014, 05:49 PM   #36
fullerra
fullerra's Avatar
14
test test  [0.00]
Edit ; here it is..
Did they ever get back on whether the 17" would clear the front AP caliper and rotor? I just installed AP's on my ride, and love this look as well!
      02-18-2014, 06:29 PM   #37
Expert@ApexWheels
Expert@ApexWheels's Avatar
3523
Drives: M3
Happened to stumble upon this page today and noticed some questions left unanswered. The car looks great OP, thank you for sharing your photos.
Thankkz
The widest wheels in stock suspension would be the 17x9" ET30 and 17x10" ET25 ARC-8's, which can be used with 245/40/17 and 275/40/17 street tires. Using a wider 255/40/17 front tire would require camber plates to dial in around -2.5 degrees for proper fender clearance.
Your car looks great, thank you for sharing your specifications.
Originally Posted by fullerra View Post
Damn uuuuu!
The 17" ARC-8's are a great alternative for track setups to keep tire costs down and is quickly becoming a popular choice. The meaty tires definitely add a mean look to the Z.
      03-15-2014, 02:43 PM   #38
DonDP
DonDP's Avatar
48
Drives: F31 330d / Z4M Coupe
Thanks for clearing up those questions David@Apex.
I have another.... I am considering the 18 inch versions however, i could do with some clarification of what setup would clear the AP racing kit with the CP 5575 calipers? I have been informed that the ARC 8 wont clear the AP kit. I really hope this isnt the case.
      03-15-2014, 05:18 PM   #39
nekky
Wagon life
nekky's Avatar
Drives: '16 328d M Sport Touring
New favourite roadster man! WOW! Never seen pics of your car before, and you've driven me to want to get a colour matched hardtop even more now... I have a very similar setup, except with KW CS and VT2-500 instead of your V3/VT2-525.
Absolutely gorgeous.
      03-18-2014, 02:57 PM   #40
Beedub
it won't in the higher offset version..... some of them will easily however...
      03-19-2014, 01:47 PM   #41
Expert@ApexWheels
3523
Drives: M3
As long as the Z4M front BBK from AP Racing that uses the 5575 caliper is identical to the E46 M3 front BBK, the 5575 calipers clear our 18x9.5" ET35 ARC-8's without the requirement of a spacer, though it is close and only a few mm of clearance. The EC-7 is definitely the wheel with better brake clearance, but the ARC-8's do work with the 5575 calipers for the E46 M3, which we've been told is the same for the Z4M front brakes.
      06-13-2014, 06:41 PM   #42
donoman
Rookie
33
Drives: 03 Z4 2.5i 5MT
Originally Posted by Eddy@ApexRaceParts View Post
The 17x9.5" ET35 wheels were even tested spacer free on a non-M Z4 up front.
I am going to install the M-sport suspension on my 2.5i non-M with RE Camber plates (-1.5 deg). Will 17x9.5 ET35 square fit on my car, and if so, then what tire size would work? Will this work without camber plates?
2003 Z4 2.5i
2013 FR-S
1990 911 C2
1983 Wife
      12-28-2020, 10:45 AM   #43
///A D O L F O
Drives: 2003 BMW Z4 (e85) 3.0i
Track Setup: Konig Hypergram 17x9 (et35)
Hello, ZPOST!
Wheels: Konig Hypergram (17x9 et 35)
Tires: Hankook Ventus Evo 2 (255/40/17)
Suspension: Megan Racing Euro II
      12-30-2020, 11:03 AM   #44
B328iC
Drives: 97 328iC, 2003 Z4
I know this is an old post but haw does the switching to the 17's from 18's effect handling? Does the increased "foot print" of the wider tires help it or does it make it easier to break loose due to the less rigidly of the sidewall. How does it effect the ride? On the street does the extra tire sidewall add a little more protection to the rim? I have a stock setup and only street drive mine.
Tags
17", apex, arc-8, track, wheels
