      06-03-2014, 10:38 PM   #1
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Question STR Wheel fitment on NonM
Can anyone confirm these will fit a 07 si coupe with sport. Coming from 203s. Stock suspension as far as I'm aware.
STR 607
front 18x8 et35
rear 18x9 et40
      06-03-2014, 11:57 PM   #2
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
Those should fit no problem. You could get away with 10mm spacers on each depending on the tire/fitment you want. But with stock suspension and normal sized tires there should be no issues.
Bagged e85 Z4 | www.ogretrograde.com
Bagged TT 225Q SOLD - e46 M3 SOLD - W202 SOLD - e46 325i SOLD
      06-04-2014, 01:57 PM   #3
jmilt13
jmilt13's Avatar
19
Drives: 3.0si Coupe
Cool, my best guess was that the fronts would stick out about 0.4" more than normal and the rears about 0.7" more than normal. Which might look better actually.
Thanks!
      06-04-2014, 06:37 PM   #4
cervasa
Drives: 04 Z4 3.0 6spd
if your going str and using stock tires just get 2 sets of the rears and some 15mm spacers all around
      06-05-2014, 10:20 AM   #5
2282
I read this the same way but I don't think OP is referring to Street Touring Class (STR) rather the wheel brand STR (see center cap in picture).
      06-05-2014, 06:28 PM   #6
cervasa
ahh true i over looked that
