      04-21-2013, 03:21 PM   #1
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
DIY - 80mm tips on OEM ///M cans
CAUTION! this DIY will ruin your factory tips. do not attempt this if you are avoiding permanent damage to them.
disclaimer out of the way...
I was super rushed taking the pics for this, so they are of super low quality. I do apologize for them.
step #1: get yourself qty 4 of PN 18307610633. these are the f30 335i sport package tips. they are also available in chrome
(luxury pkg) and matte silver (modern pkg). I chose these for two reasons... first, they look bigger in the darker color when matched to sepang.
and two, they hide any dirt/carbon buildup caused by the straight through mod that I've done to the mufflers...
step #2: inside you'll see three pressure tabs that allow the tip to center on the f30 exhaust.
obviously this won't do for us, so these need to be modified. select the orientation (rotationally) that you want them to sit on each muffler.
I chose to have the seams on the bottom so that there was no visible line seen from above. this is not required, just my preference. once
you've decided for yourself, pick the two tabs farthest from the space between the tips and cut them like so (I just used a pair of side cutters).
DO NOT remove the tabs entirely. they are critical to these staying on the car...
the remaining tab on each tip should be trimmed thusly...
step #3: measure from the tip end back 4 1/8" and place tape around the circumference...
using the edge of the tape (farthest from the tip outlet) cut along the line, then deburr...
step #4: cut a section of wheel tape weight (i used 3M PN 61405) to a length of 2 1/2"...
place the weight inside the tip between the tip's lip and the shortest/smallest tab that was cut previously...
step #5: install on vehicle! make sure that the weights on each tip are close together and SLOWLY press them over
the OE tip. if you go too fast, you risk peeling the weight off. i recommend partially installing the outer tip first so as to not mar the finish on
the inner tip's surface that is still visible. you may need a mallet and a block of wood to get these on (i certainly did)...
      04-21-2013, 04:42 PM   #2
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
looks interesting, gonna need more finished pics
      04-21-2013, 05:01 PM   #3
v3.2mc
Not a New Member
v3.2mc's Avatar
done.
please note that the weird vertical alignment is due to the mufflers, not the tips. I still have to get the car on a hoist to get the mufflers aligned correctly after reinstalling them.
      04-21-2013, 06:45 PM   #4
mgwatson48
mgwatson48's Avatar
Drives: 2008 E86 M
Either your tips are crookedly installed or your OEM cans are somehow out of proper alignment?
SOLD: 2008 M Coupe
      04-21-2013, 07:31 PM   #5
v3.2mc
Not a New Member
v3.2mc's Avatar
the post directly above yours addresses that.
      04-21-2013, 10:06 PM   #6
GammaZeta
Drives: 1
I like it, but for over $200 worth of parts, wouldn't it be better just to kick in for a used or cheaper exhaust system, like Stromung?
      04-21-2013, 11:37 PM   #7
v3.2mc
Not a New Member
v3.2mc's Avatar
I hear what you're saying, but a few things factored in...
1) I didn't spend that much
2) I like the OEM look
3) I like the OEM sound
the most important thing is though, many people just simply want options. I am in no way saying this is the best one, and a vast majority of the time this DIY will get filed away in people's mind as an "ok, that's been done". but... to my knowledge... no one else as tried to fit anything larger than 76mm tips to the OE cans, and if they have they didn't post it to zpost. now it has, and the curiosity is satiated.
      04-22-2013, 12:03 AM   #8
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Hey! Pretty cool! Innovative. Looks good!
      04-22-2013, 06:35 AM   #9
GammaZeta
Drives: 1
How much did you spend then? I see each tip going for $50.
      04-22-2013, 07:53 AM   #10
v3.2mc
Not a New Member
v3.2mc's Avatar
MSRP = $56.50/ea.
BMWCCA = $45.20/ea.
i paid ~ $43/ea. by asking for a discount at the local dealer.
for comparison's sake... the eurosport design tips are $45/ea. plus shipping.
      04-23-2013, 09:48 PM   #11
TiAgMC
Drives: BMWs
you should change that license plate to TURDMBL Eric
      04-23-2013, 09:53 PM   #12
v3.2mc
Not a New Member
v3.2mc's Avatar
cause it's brown, right?
i'll think about it.
