      04-07-2013, 03:30 PM   #1
SILLY
Drives: Black 3.0i Z4 2006 Roadster
shift knob removal
Help please. Got my new aero bumper, side skirts, and spoiler installed. AWESOME.
Now I'm trying to get the shift knob off to install my new type r. I put all I had into pulling off the stock shifter, but it didn't move. Any tips on getting it off? Put the top down and stood on seats even. Afraid of yanking to much, don't want to hurt the Z. Should it be in gear, or not? Thanks in advance.
      04-07-2013, 04:13 PM   #2
speddmn
Drives: 05 3.0i
Auto or Standard?
      04-07-2013, 07:31 PM   #3
WestCDA
Drives: 2006 Z4R 3.0si
Don't try to do a gradual pull - just a sharp tug straight up will break it loose. Doesn't matter if the car is in gear or not, just orient the shifter lever so it's pointed in the direction you are pulling. Roof down should make it easier to kneel on the seat and get over it - careful not to get too close and smash yourself in the face.
If you continue to have a problem, you can adapt an 'L' bracket for a slide hammer that will fit under the knob - but that really shouldn't be necessary.
Good luck ...
      04-07-2013, 10:38 PM   #4
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Originally Posted by speddmn View Post
Auto or Standard?
Shouldn't matter. Auto or Stick knob comes out the same way - just a sharp tug straight up as WestCDA suggested.
      04-08-2013, 12:08 PM   #5
SILLY
Sounds good. I was just doing a steady pull, so I'll try a little more aggression. Thanks.
      04-08-2013, 02:35 PM   #6
M-Power M3
Retrograde
M-Power M3's Avatar
18
Drives: Bagged Z4
Helps to put a pillow in between your face and the shift knob if its giving you trouble. Don't want to explain that black eye lol
      04-08-2013, 03:14 PM   #7
Loogey Clapp
Loogey Clapp's Avatar
Drives: 2006 Z4 3.0si
If you're standing over it, watch your manly-bits too!
      04-09-2013, 12:54 PM   #8
speddmn
Drives: 05 3.0i
Good to know!
