      10-06-2023, 08:32 PM   #1
CrazyOneToo
1999 E46, 2002 E53, 2007 E85....all in progress
Drives: 2007 Z4 3.0Si Roadster
2007 roadster Bilstein B4 rear shock install
When installing my B4 shocks on my 2007 roadster they have a rectangular block on one side of the bottom mount.
Is that block mount supposed to be facing the bolt head or the car mount?
When I emailed Bilstein they say it's the opposite of the instructions I found at NewTis and Pelican Parts.
Newtis page shown. What would you go with?
Thanks
1999 328i - 2002 X5 3.0i - 2007 Z4 3.0i...always in progress.....
      10-06-2023, 09:53 PM   #2
maupineda
Drives: E86 Z4MC
You can use a metal washer, that is just to prevent the shock to pull through the bolt
      10-06-2023, 10:09 PM   #3
CrazyOneToo
I don't need a washer. The shocks have the block on them already as I said in the posting.
      10-08-2023, 06:17 PM   #4
rsutoratosu
Drives: Z4 3.0i
I can't remember but that washer is to prevent the bolt from pulling into the bushing.. so it should be on the head side. I would google around and confirm also
My kw just came with circle washer on the bolt heat side.
Page 9 of the kw manual, its on the bolt head side
https://www.kwsuspensions.com/extras...-h68620004.pdf
-Roranji
      10-08-2023, 07:52 PM   #5
CrazyOneToo
My Bilsteins have the rectangle built on. I put them on with that block facing the bolt head so it matches what NewTIS says.
It's just strange that Bilstein said it was the opposite way.
      10-08-2023, 08:35 PM   #6
rsutoratosu
Drives: Z4 3.0i
Yeah I agree.. prevent the bolt from going through the bushing..
-Roranji
