04-03-2018, 08:03 AM | #1 |
Rep 2,703
50#/HR S54 Injectors
This set of 6 fuel injectors fit the OEM fuel rail and intake for the 2001-06 BMW 3.2 inline 6, S54 Price $350usd Bosch EV14 - 6-hole - Stainless steel nozzles 525cc/50lb custom manufactured and flow-matched set of fuel injectors. Flow chart attached. These sets are very consistent and will require no more than 1% trim for easy tuning with accurate compensation down to 1.5 ms Injector type: EV14, internal filter Part number: 117U525/Adpater Flow Rate: 50 lbs/hr, 525 cc/min at 43.5 PSI (3.0 bar) Resistance: 12.8 Ohms Voltage: 8-15 Volts, Nominal 13.5 Volts Pressure: Min. 36 PSI (2.5 bar), Max. 100 PSI (7 bar) Connector: Jetronic All Viton 14.5 mm o-rings Included for installation. Retail price is $449 Payment by Paypal as gift or add 3%
04-16-2018, 11:52 AM | #2 |
Rep 2,703
Bumper
04-17-2018, 08:15 AM | #3 |
1621
Rep 4,294
Hey buddy, intrested.... I guess id have to re-tune for the puppies?
what sort of setup where you intending on running these with? the dinan enlarged throttle boddies? cheers
Powered by |
04-17-2018, 09:03 AM | #4 |
Rep 2,703
Hey Vanne,
These were sent to me by mistake. I don't know what the stock injectors are rated at, so I am not sure whether the DME can adjust. Worse case you would need a tune.
04-18-2018, 07:39 PM | #5 |
Rep 2,703
Sent you a PM Vanne
04-19-2018, 06:06 AM | #7 |
Rep 2,703
NP
