      03-16-2017, 01:06 PM   #1
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
2008 BMW Z4 3.0si  [9.00]
ESS Supercharger for N52
Has anyone purchased and installed one of these yet for their Z4? I'm thinking of getting it this year.
      04-04-2017, 02:48 PM   #2
Harrison256
Drives: 2006 BMW Z4 3.0si
I'm going to do the same. Just picked up my 06 Z4 3.0Si w/ 32k miles and it seems like the perfect candidate for a supercharger as soon as I'm done fixing the top. I'll go with VF or ESS, whoever has a 15%-30% sale first lol..
Back in 14 I believe VF had a 25% off spring sale on superchargers, if they run a deal similar to that I'll pull the trigger in a heartbeat.
      04-04-2017, 03:26 PM   #3
Steeler
Steeler's Avatar
2428
I was not aware that VF had a kit for the N52!!
      04-06-2017, 02:32 PM   #4
Harrison256
Well now I can't seem to find it lol. Maybe I imagined it damn
      07-12-2017, 11:43 AM   #5
Forbes
Daily driver/Weekend mechanic
Forbes's Avatar
Drives: '06 Z4 3.0i Roadster
2006 Z4 3.0i  [6.00]
2014 BMW 328i  [0.00]
It's through ESSTuning.
Here's the link:
http://esstuning.com/ess-n52-vt1-sup...-system-gen-2/
Mine was delivered a few days ago. Now I'm reading through the instructions prepping (i.e.: The car's last dealer checkup, dyno, etc.), and finding a free weekend for a DIY install.
      07-12-2017, 11:46 AM   #6
Forbes
Forbes's Avatar
2006 Z4 3.0i  [6.00]
PS, they gave me a 5% discount x-mil
      07-12-2017, 12:55 PM   #7
3002 tii
3002 tii's Avatar
2282
I know bmwZ installed it but there might be one other member. Be sure to follow this thread as BPC is doing a custom tune for an E90 owner:
http://www.e90post.com/forums/showthread.php?t=1393038
Follow for latest mods
      07-25-2017, 02:12 AM   #8
Forbes
Forbes's Avatar
2006 Z4 3.0i  [6.00]
Here's what mine looks like. It was about a 12-hour job. Less if you know what you're doing.
SaltyNC369.50
      10-16-2017, 08:34 PM   #9
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
How's it running? Have you run it on a dyno yet?
      10-19-2017, 05:44 AM   #10
pokeybritches
pokeybritches's Avatar
2006 BMW Z4M  [10.00]
2006 BMW Z4M  [8.50]
2003 BMW Z4 3.0i  [9.00]
Where is your MAF sensor located?
      11-13-2017, 03:26 PM   #11
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Updates? Almost ready to pull trigger on s/c, have ss headers waiting to be put in, but would like to do it all in one go
      11-14-2017, 02:58 PM   #12
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
You'll need a custom tune for the headers - ESS won't touch them.
      11-14-2017, 07:53 PM   #13
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Was planning on doing bpc tune with headers/sc
      11-15-2017, 01:39 AM   #14
TRiCC
E86 M Coupe
TRiCC's Avatar
265
Drives: Z4M Coupe
My new favorite thread! I have the supercharger and headers in mind for up coming mods in the future!
      02-21-2018, 12:19 AM   #15
Forbes
Forbes's Avatar
2006 Z4 3.0i  [6.00]
I had to uninstall it for emissions pass and tags.
Install requires you to cut the MAF sensor wiring. I installed a bridge circuit. Will reinstall in a few weeks after the paint dries on my new bumpers and hood, and winter ends.
Unfortunately, I'll be missing the club dyno day.
      02-21-2018, 01:44 AM   #16
Forbes
Forbes's Avatar
2006 Z4 3.0i  [6.00]
Factory location of the MAF is on top of the pipe leading from the filter box to the throttle body. Basically the first thing to disconnect when replacing the air filter.
The kit relocates it to the bottom of the ESS pipe leading to the throttle body. The kit was not designed for the E85 - lots of leftover and spare parts. There is plenty of room for improvement or custom fabrication work.
      10-10-2018, 01:47 PM   #17
Aries326
Aries326's Avatar
2013 E92 M3  [0.00]
Was this the version 2 kit?
      10-11-2018, 04:54 PM   #18
pokeybritches
2006 BMW Z4M  [8.50]
I guess what I'm trying to figure out is whether it's a draw thru or blow thru setup. Most aftermarket kits are draw thru, which requires a higher safety margin in the tune (since inlet air temp is calculated and not directly measured as part of the MAF), and can't account for boost leaks, heat soak, or allow use of a blow off valve vs a bypass. Blow thru setups require more MAF scaling and risk MAF sensor contamination due to oil (from CCV), but measure the air right before the throttle body so it's most accurate (assuming no contamination).
My VF kit is draw thru, and I've considered converting to blow thru with an intercooler.
      03-31-2019, 10:30 PM   #19
Hush Paranoia
Drives: BMW Z4 3.0si Coupe
Hey Forbes! I was wondering if you still have the supercharger on? How has it held up? I was wanting to purchase and do an install within the next couple of weeks if ESS ever restocks their website. How many miles did you have on your car when you installed it? Sorry for so many questions but you are the only person I know who has done this.
      04-02-2019, 03:43 PM   #20
WickedNy
Get Some
WickedNy's Avatar
Drives: 07 Z4 3.0si
07 z4 3.0si  [0.00]
Had mine installed with 100k on it and meth injected as well, pulls great sounds like a Mac truck idling until after it breaks in...have about 7k put on ad still going well
      04-19-2019, 03:57 PM   #21
CRE
Drives: 2007 Z4 3.0si Convertible
Anyone have dynos of their own setup? Preferably 3.0si.
      04-17-2020, 09:13 PM   #22
Forbes
Forbes's Avatar
2006 Z4 3.0i  [6.00]
Never reinstalled after removing to pass air care.
That was about 3000 miles of fun. The power was great. But the list of cons include:
Not street legal, about 20% decrease in milage, increased maintenance (R&R SC lubricant), it is dirty (the blow-by overwhelms the car's oil separator) and worst, the sound is unnatural.
