      06-11-2014, 01:27 PM   #1
omglukewtf
Drives: 2008 Z4 M Coupe / 2011 E93 M3
Royal Purple Max Gear Spec for Diff Oil
I've searched but can't find an answer to this. I'm going to replace my diff oil with Royal Purple Max Gear but don't know if I should use 75W-140 or 75W-90
Any suggestions?
      06-11-2014, 08:05 PM   #2
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Don't. e46 crowd reported problems...
2006 Z4MC - #LL93158
      06-13-2014, 12:27 AM   #3
StickMon
StickMon's Avatar
Drives: 2006 MR
Royal Purple in the trans, OEM with FM Boo$ter in the diff.
      06-13-2014, 10:39 AM   #4
omglukewtf
Thanks for the info, from the sounds of it people are having mixed results with it so I'll just avoid it and go OEM.
      06-13-2014, 08:01 PM   #5
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
I recently purchased Motul to replace the OE. I recall seeing somewhere it is Castrol or vise versa...
      06-14-2014, 01:02 AM   #6
Shipkiller
Shipkiller's Avatar
Drives: Me
FM Booster is only needed if you hear grinding when doing very tight, low speed turns. Most cars (Z4M's) do not need it. Some do. There is a SIB on this.
I take a CLEAN one gal. jug (I sourced from my local Granger store) to my dealer and he puts two pints of SAF-XJ in the jug.
Castrol SAF-XJ PN # 83 22 1 467 993 (expensive)
Castrol SAF-XJ + FM PN # 83 22 2 282 583 (really expensive)
      06-16-2014, 03:43 PM   #7
DanFromTucson
Drives: Z4 M Coupe
I have redline, and I do experience the grinding. Has anyone tried adding the friction modifier to redline fluid?
