      04-24-2023, 12:08 PM   #1
bcolins
Wildwestrider
Drives: E83, R1200GS, ,
Horn inoperative on 2005 Z4
Replaced the fuse and still not working. Is there a common issue causing this? Can't get it inspected until working.
Brian
      04-25-2023, 08:26 AM   #2
3002 tii
3002 tii's Avatar
2304
Could be the horn themselves, maybe wires corroded. Pretty easy to replace, directly accessible from wheel liner
Follow for latest mods
      07-12-2023, 03:37 PM   #3
pandry
Drives: BMW Z4 3.0is 2008
Horn not working
When I got my Z4 a couple of weeks ago, the horn(s) would only work for a very short time, after which nothing until the following day. I had to have them working to get my registration and license plate. I paid $60.00 to a repair shop, only to be told that both horns were worn out.... Apparently, it is not uncommon for both high and low horns to fail at the same time(?).
Anyway, I held out for BMW horns (unavailable from local shops) until the new BMW horns with BMW's connectors arrived. I did not want to be splicing and soldering after-market horns in such a restrictive space. Two nuts off, old horns removed, new horns on, plug and play - all is well.
      01-04-2024, 02:09 PM   #4
dhlairbusb4@cs.com
Drives: bmw z4
My horn is really weak, I suspect only one is working. So the question is, what side are the horns located? With my luck I would pull the wheel liner for the wrong side!
Any help appreciated, and Thanks in advance!
2014 Z4 S Drive 28I
