08-13-2012, 10:01 AM | #1 |
Rep 74
Ebay Diagnostic Cable?
Has anyone used an OBDC to USB cable sold on places like eBay? I'd like the ability to pull engine codes and do some minor reprogramming and at $40 including the necessary PC app it seems like a no-brainer...assuming it works.
Good to have? Waste of money?? |
08-13-2012, 12:09 PM | #2 |
Rep 932
Check xcar360. I got the cable from them. You can do some programming too. Search for BMW Scanner 1.4.0 / Car Diagnostic Interface Tool Code Reader for BMW Scanner 1.4.0 Version. It was $32 when I purchased it.
08-14-2012, 03:22 AM | #3 |
Rep 701
Just bought THIS one off eBay.
Another forum member has the same one and they reported it works very well. Will let you know more when I do.
08-16-2012, 10:55 PM | #4 |
Rep 701
Buy the one RobMCoupe said or any BMW Scanner that uses V1.4.0 software from China.
Using an OBD-II scanner with the OEM BMW software program tools is a total Head F@#k of massive proportions.
08-17-2012, 01:38 AM | #5 | |
707
Were you able to get the one you bought up and running? Those who have got the software itself running are using tech professionals, so if you did get it to run, props. But using it, after it's installed, is another story as well. There are forums developed to that proposition exclusively. I went the V1.4.0 route myself. Doesn't do everything, but it was a simple driver install (copy the file to disk) and then connect the cable, and bang, it works. I runs diagnostics, reports faults, clears codes, allows for basic programming features, and can code new modules (assuming your brave enough to try that). |
08-19-2012, 07:30 PM | #6 | |
Rep 701
INPA and EDIABAS and DIS were all running. However, there were not at all as intuitive to operate as I had hoped for. I finally got everything installed after 6+ hrs of torment only to find the package was largely unusable with my level of programming knowledge. The online forums devoted to these areas of expertise I have concluded to be frequented by some of the biggest bunch of conceited and unhelpful Pricks on the face of this Earth that after reading a few introductory posts I was permanently turned off without even registering to ask a simple question that others have been more or less bitch slapped for their troubles. I guess I expected that being official BMW programs they would be ‘better’ than others which indeed they may well be but certainly not easier to use for the average BMW enthusiast than 1.4.0 looks to be. Have ordered 1.4.0 and I will report back once installed. Even though it may not do everything, neither does my girlfriend which at the end of the day is no big deal as long as the main functions work A-OK. I am only looking for basic coding functions and fault reading ability which I guess 1.4.0 will be much better suited to my needs.
08-19-2012, 08:18 PM | #7 |
6 of Diamonds (ret)
82
Rep 566
+1 for PA Soft 1.4 Simple to install - relatively simple to use, & CHEAP!!!!
2007 Z4Si(gone)
Couple E30 Verts (DD) 2003 330i 2011 E93 335is - current fav |
08-19-2012, 09:51 PM | #8 |
Rep 1,107
08-22-2012, 06:05 PM | #9 |
Rep 1,107
Hi, any update on this? People on E46fanatics have been reporting mixed successes with the 1.40 tool. Also, is the total price $50+ including shipping?
Thanks! |
08-22-2012, 06:10 PM | #10 |
Rep 701
Still waiting on mine.
China Post is F'N slow.
08-23-2012, 12:10 AM | #11 |
636
Rep 3,124
I bought one and covered it in this thread.
Definitely got my money's worth for $43, but the software install isn't for the uninitiated. Haven't gotten around to another try to get NCSExpert to run under 64-bit Windows 7. Microsoft has an XP virtual machine for 64-bit Win 7 that should do the trick. So many gadgets, so little time. |
08-23-2012, 04:05 PM | #12 | |
Rep 269
I'm computer literate and have a bunch of Windows XP laptops lying around, so unless the software is completely terrible, I like the challenge. Having said that, is it possible to completely goober something up with this?? |
08-23-2012, 04:50 PM | #13 |
636
Rep 3,124
The cables typically come with 2 programs to change settings, Progman (a.k.a. SSS) and NCSExpert.
Progman is very user friendly, and I think only lets you into a safe subset of things you can tweak. Auto locks may have been in there. NCSExpert allows you to tweak a wider range of options, and I've heard you can muck things up if you're not careful, but I imagine you would have to be pretty reckless. Then again if it turns out to be in all German ... Like I said, I haven't gotten around to getting it running yet. The DIS and INPA diagnostic programs are hours of fun. |
08-26-2012, 12:42 AM | #14 |
636
Rep 3,124
You can turn auto lock on or off with Progman. I think I read somewhere that NCSExpert will let you set the exact speed that it locks at, but I may be hallucinating.
08-26-2012, 03:59 AM | #15 |
Dark Sider
129
Rep 1,779
Drives: 2008 Space Gray Z4MC
It says only up to 2007 models. i assume it would work for a 2008?
09-04-2012, 06:16 AM | #16 |
Rep 701
Finally received the BMW Scanner off eBay and am running V1.4.0.9 with great success.
Overall I am very happy with this program and Scanner. I was a little pissed off I had to search for a fix and then solder pins 1-2 and 7-8 before all functions were working on the coding side of things. As if the people who made this Scanner couldn't have done that. I have been able to read all fault codes and change to auto door locking, and a few other small things. I have yet to be able to remove the 'Nav Accept' Nag Screen with this program, so if anybody knows how please chip in.
09-05-2012, 12:17 AM | #17 |
636
Rep 3,124
You need to update your Nav firmware to V31. See this thread.
Haha. Now that I re-read that thread, I realize I did this: On the MKIV systems, if you do the upgrade and then install an older software version (such as going from V23 down to V22.1 and then back to V23) , the navigation system may reset out of USA mode and put you into UK mode. You will know this has happened if you are now receiving directions in yards instead of feet and the "Emergency" option has disappeared from your main menu. The advantage of this is that you no longer have the annoying "Accept" screen to hassle with every time you turn on the car. To fix this, the dealer can hook the car up to their computer and reset the navigation system to "USA". Actually I prefer yards, but I wonder if this is also the reason my Nav seems to have a weak concept of cities. I'll have to check this weekend and see if I can find this UK/USA switch in Progman. Last edited by StickMon; 09-05-2012 at 12:26 AM.. |
09-05-2012, 02:59 AM | #18 | |
Rep 701
I am running V32 being SW4-1/00. Still cannot see how to disable the Accept Nav Screen
09-05-2012, 03:27 AM | #19 |
Rep 701
Actually, the Live Data screen is also not working in the BMW Scanner program.
It is greyed out in the DME menu contrary to other reports.
09-05-2012, 12:55 PM | #20 |
636
Rep 3,124
09-05-2012, 01:43 PM | #21 | |
Rep 11,668
09-05-2012, 02:01 PM | #22 |
Rep 701
Click HERE
