      03-18-2013, 04:51 PM   #1
Spedracer81
Drives: Z4MC
Help..Will these fit??
I found a set of VMR v710s...
Front: 19 x 8.5 et 35
Rear: 19 x 10 et 38
will these fit on my MC with H&R springs installed without rubbing>>>??
| 2008 Interlagos Blue Z4MC |
| AA Tuning | RPI Scoop | H&R Sport Springs | Sportline CS 16 CSL Wheels | Magna Flow Custom Exhaust |
      03-18-2013, 05:00 PM   #2
v3.2mc
Not a New Member
v3.2mc's Avatar
2007 ///M Coupé  [10.00]
you'll need a 13mm spacer in rear. front is perfect.
      03-18-2013, 05:19 PM   #3
Spedracer81
Drives: Z4MC
Is it bad to use spacers? I'd rather not but I think I can get a good deal on these wheels..
Now with that spacer added..I'd have to buy longer studs?..I'd like to use a stud conversion kit..
      03-18-2013, 05:31 PM   #4
v3.2mc
Not a New Member
v3.2mc's Avatar
i wouldn't say "bad"... maybe "not ideal" is more appropriate.
this would be an excellent opportunity to move over to a stud conversion. just remember that not all shops will have an extra-deep socket to get them off, so maybe get one of those as well and keep it in the car.
      03-18-2013, 05:47 PM   #5
Spedracer81
Drives: Z4MC
how do I know what length studs to get?
      03-18-2013, 05:54 PM   #6
itdnwiwbp
Drives: 330iZHP
Also, be prepared for some places to refuse to work on your wheels/tires if you have a lug stud conversion. This happened to me recently at Discount Tire/American Tire. Not a big deal. Just keep in mind that, unless you find a shop that will (which I'm sure would be pretty easy) you'll have to transport the wheels to them for mounting/balancing etc.
      03-18-2013, 06:00 PM   #7
Spedracer81
Drives: Z4MC
Yea, I just have my local shop mount and balance, I like to do the work myself..
I just don't know how I feel about using spacers and rubbing in the rear..
Deciding on a set of wheels is turning out harder than I thought...
      03-18-2013, 07:51 PM   #8
dubsesd
#dubspec
dubsesd's Avatar
No_Country
6327
Don't sweat it. If you get a 12mm spaced in the rear you will be fine. Burger tuning has spacer and longer bolt kits that are excellent quality. Nothing wrong with spacers or longer bolts.
Here you go
http://www.ebay.com/itm/12MM-BMW-Whe...56c754&vxp=mtr
instagram: @ dubsesd
      03-18-2013, 07:55 PM   #9
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
+1. 12mm spacer will have a hub-extender. Issues with spacers come in when something like a 10mm spacer that doesn't have a hub extender. With the right hardware and a good spacer (and good install) there isn't anything to worry about.
      03-18-2013, 08:01 PM   #10
Spedracer81
Drives: Z4MC
Sweet thanks for the info...I'm waiting to see if this guy accepts my offer..
      03-20-2013, 04:37 PM   #11
dudekma
Drives: 2006 BMW Z4 3.0i
You will want 90mm stud conversion kit for any spacer over 10mm. Just for comparison sake, I run 255/40/r17 Direzza Z2s with 5mm spacers and 75mm studs (square setup) on an 06 3.0i. They are as far as I'd be able to push them out.
