03-15-2013, 08:47 PM | #1 |
Rep 832
Tire sizes for new wheels
OK, I am getting the EC7s from the GB soon and for now, I am going to put the stocks on them, pretty certain sizes are fine. I am picking up:
18x8.5et35 fronts - stock tires are 225/45 18x9.5et22 rears - stock tires are 255/40 As soon as I can afford them, possibly even at the same time if I can make it work, I am going to pick up PSSs. I know I can obviously pick up the same size tires in PSS but I am wondering if there is a benefit to a different size than stock. Thoughts? |
03-15-2013, 09:24 PM | #2 | |
Rep 1,031
When I spoke with Joe he said the largest I should go is 235 front and 265 rear for that rim size. I plan on going with that eventually as my current rubber wears out. Might be a while though. Otherwise sticking with stock sizes for now.
http://www.zpost.com/forums/showthread.php?t=815267 Quote:
03-16-2013, 09:38 PM | #3 |
Rep 832
So, assuming I go with 235 and 265, the next question of course is height of the tires.
For fronts, if I go with 235/40, looks like the overall diameter is .5inch less. 1010 tire calculator shows this as a 2.2% variance over stock (within their 3% recommendation). I also, therefore, assume this allows me more room for lowering...maybe even adding a spacer to push the et35 wheel out a little. 45s are bigger and will likely hurt when it comes to lowering. For the rears, if I go with 265/35, diameter is .7inch less which equals a 2.8% variance. 40s would be .3inch (1.21%) bigger...not sure if this is as big a deal so I could go with either size here I think. Thoughts? |
03-16-2013, 10:31 PM | #4 |
703
235/40 and 265/35 will work, so will 245/40 and 275/35. Course you can go with stock sizes too. Benefit? Hack's post touches on this. The wider tires give the rims some protection, and IMO they look good! The red car in this thread has your rim size and 245/40 275/35 tires.
03-16-2013, 10:39 PM | #5 | |
Rep 832
03-17-2013, 12:50 PM | #8 | |
Rep 820
Drives: 2007 Z4MR silver grey
John |
03-17-2013, 01:00 PM | #9 | ||
Rep 832
Thx |
03-17-2013, 04:36 PM | #10 |
Rep 820
No spacers, I have the Eibach Pro Kit springs on the car, no rubbing at all.
03-17-2013, 05:07 PM | #12 | |
Rep 11,667
I like the 235/265 combo with 8.5 & 9.5 wheels
03-17-2013, 05:10 PM | #13 |
M = Midlife Crisis
65
Rep 2,006
This is what I currently have on those wheel sizes
235/40ZR18 Hankook Ventus R-S3 265/35ZR18 Hankook Ventus R-S3
2006 Z4MC - #LL93158
