03-08-2013, 09:04 PM | #1 |
Rep 805
maximum spacer size for Z4M with stock OEM wheels
Hi Guys - I did a search and didn't come up with much. So, what is the maximum size spacer one can put on a 07' Z4M with stock suspension and oem wheels? If anyone has pictures, I'd love to see them. Thanks.
I'm running 245/40/18 in front and 265/40/18 in the rear on OEM Z4M wheels |
03-09-2013, 07:16 AM | #2 |
M = Midlife Crisis
65
Rep 2,006
I had slight rub on the rears with 12.5mm with 265/40/18 lowered ~ 1". Fronts should work fine
2006 Z4MC - #LL93158
03-09-2013, 08:03 AM | #3 |
Rep 1,031
I think you would get rub slight rub with 245 in the front and a 12.5mm spacer. I am lowered slightly (.5-1") and running stock 225 up front and over big bumps or tight corners I can hear a slight rub. I am not running spacers in the rear so cant say.
Ga41 is running 12.5mm and has rub in the front with Yokohama AD08s in stock sizes. No rubbing in the rear with a 12.5 spacer and stock size. He emailed me when I was asking about his BBK. Hope its okay I am quoting him. |
03-09-2013, 11:02 AM | #4 |
Rep 805
Thanks Guys...so maybe I go with a 10mm in front and a 12.5 in the rear since I'm on stock suspension, but slightly larger than OEM tire sizes? I don't want to rub at all.
Anyone have pics of how this looks on OEM wheels? |
03-09-2013, 12:43 PM | #5 | ||
M = Midlife Crisis
65
Rep 2,006
03-09-2013, 10:22 PM | #7 | |
Rep 12,565
Or the vibration could be a variety of other reasons, unbalanced wheel, lack of hubcentric adapters (if using non-oem wheel), if the hub is chamfered or not, etc. |
03-10-2013, 11:15 AM | #8 |
Rep 805
03-10-2013, 01:28 PM | #9 | |
Rep 503
Drives: Z4 M Coupe
Now i've got 235/40/18's front (before 225/45/18) still Yokohama AD08's, but since i've flattened those small plastic protrusions in the wheel wells it doesn't seem to rub even after a track day. Rears are same size as before, stock 255/40/18. The most recent pictures i have are these but they're not the best to judge how much further out the wheels are now.
03-10-2013, 06:04 PM | #10 |
Rep 507
Here are some pics from my setup. I am running pilot super sports, 265/40/18 rear, 235/45/18 front. I am running a 12mm spacer in the rear and 7mm (all i had laying around) in the front. The rear is PERFECT with no rubbing on stock suspension, and the front are still sunk in pretty far, but whatever. Hope this helps.
Front: Rear:
SOLD: 2008 M Coupe
03-10-2013, 06:57 PM | #11 | |
Rep 879
I am asking the question because I tried spacers last year (10mm and 12mm) and there was vibration. When I removed the wheels, I noticed that the spacers were not seating properly on the hub, like if the hub would need to be chamfered... |
03-10-2013, 07:50 PM | #12 | |
Rep 805
03-10-2013, 07:51 PM | #13 | |
Rep 805
03-10-2013, 08:17 PM | #14 |
M = Midlife Crisis
65
Rep 2,006
The TMS 12.5mm seat properly and provide the lip...
03-10-2013, 09:55 PM | #15 | |
Rep 12,565
I started a thread a while back on spacer confusion, it may help. See my first and last post: http://www.zpost.com/forums/showthread.php?t=681842 |
03-13-2013, 06:20 PM | #16 | |
Rep 932
03-13-2013, 09:06 PM | #17 |
Rep 855
Think I could get away with a 7mm front 12mm rear lowered on H&R coilovers about 2.2"
2014 335i M Sport
2010 328i M Sport 2007 Z4MC #1019/1815 (Sold) 1997 M3 (Sold) 1991 325i |
