      09-03-2012, 09:30 PM   #1
pjusa10
pjusa10's Avatar
Drives: '07 M Coupe,'07 Z4 3.0si Coupe
Apex EC-7 on AW Z4 MC
Just wanted to share some pics of the Apex EC-7 wheels in Anthracite. I am very happy with the quality and the wheels are actually much nicer in person than in pictures. I would love to lower the car, but the angle of my driveway just won't allow it. Either way, I love the change from stock.
Wheel sizes are 18x8.5" ET35 and 18x9.5" ET22 and went with Michelin Pilot Super Sports 235/40/18 and 265/35/18. One neat touch was getting the gunmetal valve springs 43mm from Bavarianx.com. They really match nicely with the Anthracite wheels and are much better than going with silver valve stems.
      09-03-2012, 10:12 PM   #2
Rated M Roadster
Rated M Roadster's Avatar
160
Drives: F10 M5, i3, Z4M
Looks awesome!
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX
SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i
      09-03-2012, 11:23 PM   #3
Daemonblitz
Commander
Daemonblitz's Avatar
221
Drives: Z4MC/M5/640iX/M1000RR
2008 BMW M5  [9.50]
2006 Z4M Coupe  [8.77]
2010 BMW S1000RR  [10.00]
Love the EC-7s, I just wish you could get a front rim that was more concave than the "Concave Profile 1"
Even if you go with 9" fronts and 10" rears you still have the same concave profiles as these.
      09-04-2012, 04:59 AM   #4
MHeavNC
Turd in the Punch Bowl
MHeavNC's Avatar
Drives: 2007 Z4 3.0i /// 2008 M Coupe
Nice pics.. I guess I will throw a couple more in the mix I took the other day.. They really do look good in person!!
      09-04-2012, 10:37 AM   #5
gferil
gferil's Avatar
30
Drives: 06 Z4MC
Looking good! They really are nice wheels aren't they? And I'm loving the PSS's as well. Similar set up on mine, except I went with 10" rears on 275's
      09-04-2012, 11:38 AM   #6
pjusa10
pjusa10's Avatar
Thanks. Yes, they are really nice and I am very happy wtih the PSS as well. Surprising how quiet they are, but coming from the OEM Conti's it is not surprising. Any pics of car?
      09-04-2012, 11:44 AM   #7
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
I love them! Have a set sitting in the garage for when I find my perfect M Coupe.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      09-04-2012, 11:44 AM   #8
pjusa10
pjusa10's Avatar
I would have liked the Profile 2 as well, but the Profile 1 is better than I expected. I actually like them in combination with the Profile 3 of the rears. Since I am on stock suspension, they are pushed pretty close to the edge.
      09-05-2012, 05:25 PM   #9
bavarianx
bavarianx's Avatar
Drives: 2006 X5 4.4i
Looks Great!!
      09-05-2012, 05:33 PM   #10
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
It is very possible to fit profile 2 EC-7s on a Z4 M as long as negative camber (camber plates) and a suspension that can properly clear the wheel and tire are introduced into the equation. It is important that the lower spring perch remain above the tire. If the spring or perch is next to the tire, then a thick spacer may be required for clearance which makes the fitment far too aggressive. A 5mm spacer would be acceptable, but anything thicker would push the setup too far out. The stock strut’s integrated lower spring perch can clear the 265 setup, so a simple lowering spring and camber plate install can make for a very ideal track setup on the Z4 M. Many coilovers use long springs, helper/tender springs, or cone shaped springs. These may have to be replaced with a single shorter spring usually 6-5″ in length to guarantee that the perch remains above the tire.
On this car we used an 18x9.5" ET43 (Profile 2) with a 12mm spacer and a 265/35/18 tire. This made the wheel effectively an 18x9.5" ET31. As long as you have about -2 degrees camber an 18x9" ET31 could also be used in the front with a 245/40/18 tire.
An 18x9.5" ET35 can also be used without a spacer in the front with a 265/35/18 tire and -2.5 to -3 degrees negative camber. Like below:
      09-05-2012, 05:38 PM   #11
ZStig
instagram 997turbotom
279
Drives: Interlagos Z4MR
sweet
      03-17-2013, 11:00 AM   #12
Daemonblitz
Commander
221
2008 BMW M5  [9.50]
So the 18x9" ET31 should fit ok with about -2 camber and a 245/40 tire even without a spacer correct ?
      03-18-2013, 12:23 PM   #13
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
A 245/40/18 tire is too tall to fit in the front of your Z4 unless you have much more than -2 degrees of camber. If you are looking to use a 245 width tire and have -2 degrees and do not have the ability to obtain more negative camber than a 245/35/18 tire is the only option.
