      06-23-2016, 10:41 AM   #1
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
Slight Engine shudder on turn-off ???
........noticed on my (new to me) Z4M roadster a slight engine shudder when I shut her off. Is that normal ?
      06-23-2016, 11:03 AM   #2
StickMon
StickMon's Avatar
Drives: 2006 MR
Yep, normal.
I always thought it was the Vanos using the pressure stored in the accumulator to hammer the exhaust camshaft to the "start position", but I was wrong.
SaltyNC mentioned in another thread that it doesn't do that if you hold the clutch in when you shut it off.
Sure enough!
So it must be the dual-mass flywheel.
      06-23-2016, 03:25 PM   #3
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Originally Posted by StickMon
Yep, normal.
Sure enough!
^WHS
      07-04-2016, 10:47 PM   #4
N55_Mike
N55_Mike's Avatar
Drives: 135i, Z4MC, MK7 GTI
Throw out bearing is gone, Same issue with my Z.
      07-08-2016, 08:02 AM   #5
tecnicaeleven
Drives: 07 Cooper S / 07 M Roadster
So we all agree its the flywheel/clutch.
Now... is it normal? Or is there a problem like what was posted above?
      07-08-2016, 08:49 AM   #6
tominizer
tominizer's Avatar
My mechanic doesn't seem to think it's the throw out bearing at all. Can you confirm that after repairing the TOB, this shuddering stops when you shut off the car?
BTW, there's a ton of posts relating to the S54 motor that this shuddering is normal. Personally, I find that hard to believe. I've driven other S54 cars and this was not occurring.
      07-08-2016, 08:12 PM   #7
N55_Mike
N55_Mike's Avatar
I had a master transmission builder diagnosis the sound, before I assumed anything. He told me it's the throw out bearing, and said might as well do a clutch/flywheel job at the same time, and rear main seal. All the noise disappeared once I completed the job replacing all mentioned parts..
      07-08-2016, 08:15 PM   #8
N55_Mike
N55_Mike's Avatar
I put 35k miles on my car with the shutteringuys, which includes a lot of stopped traffic/tracking/drag strip and not a single thing happened.
      07-11-2016, 06:45 PM   #9
tominizer
tominizer's Avatar
thanks
      07-12-2016, 07:33 PM   #10
StickMon
StickMon's Avatar
Drives: 2006 MR
I put 100,000 miles on mine with the shudder at turn off.
No noise at all idling with foot off the clutch that would indicate TOB trouble.
      07-12-2016, 09:19 PM   #11
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
^this.
Usually TOB problem is noticeable idling in neutral with clutch out
      07-13-2016, 10:38 AM   #12
tominizer
tominizer's Avatar
nope. I don't have that issue.
