      12-26-2011, 09:24 AM   #221
Beedub
Originally Posted by Caddyshk View Post
Assuming folks are running 235's on the front with the 8.5 ET32 setup. Do research on tire brand - there is significant differences between brands on the width of the tread shoulders.
Im running pss in 235
      01-05-2012, 03:54 PM   #222
TexasZed4MC
TexasZed4MC's Avatar
Drives: 2006 Interlagos Z4 M Coupe
18x8.5 et 35 and 245/40/18 front
18x9.5 et 22 and 285/35/18 rears
VERY close to stock diameters just wider.
Stock suspension buy calculations everything looks good any comments?
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor
      01-11-2012, 10:35 AM   #223
SmartBastard
Stupid as shit
SmartBastard's Avatar
Austria
25
Drives: '08 M Coupe
APEX ARC-8 Wheel Group Buy http://www.zpost.com/forums/showthread.php?t=633970
      01-11-2012, 11:01 PM   #224
RedDotRacer
Drives: 07 Z4mc
I have a totally stock suspension on my mc. Will this size fit without rubbing issues? Was looking at the apex group buy option. Is a squared setup not recommended for our cars? I don't really see too many with this sizing.
Group #6
18x9.5 et22 (F)
18x9.5 et35 (R)
      01-12-2012, 02:30 AM   #225
SmartBastard
Stupid as shit
Austria
25
Drives: '08 M Coupe
Group #6
18x9.5 et22 (F)
18x9.5 et35 (R)
18x9.5 et22 is for us (Z4M) rear not front, it is listed as front only for E9x M3
18x9.5 et35 for rear this would fit, but you will probably want to get spacers since the wheel will be only 1mm outer than the stock
For front you should get 18x8.5 et38 with a 245 tire for perfect fit
There's some feedback on the GB thread regarding the 9.5" ET22 - unfortunately they don't have enough wheels to sell the ET22 to us as rear wheels :-(
      01-15-2012, 10:38 AM   #226
Hoa
No_Country
513
Drives: BMW
I have both the M Roadster and M Coupe. Both are lowered. The BBS CH setup have a little more rubbing in the rear on big bumps. The BBS LM setup has almost no rubbing at all. Both setup have the same tire size. The fronts do rub a little if I make a full lock turn on the BBS LM. Not so much on the BBS CH. The BBS CH setup used no not rub as much until I got new Michelin Super Sport tires on it. The Continentals worked better for me.
Here are my setups
M Roadster
BBS CH
Front 19X8.5 +35 245/35/19
Rear 19X10 +20 275/30/19
M Coupe
Front 19X8.5 +32 245/35/19
Rear 19X10 +25 275/30/19
Here are some pics:
The M Roadster is being put back to stock to trade in so it is higher now. With stock suspension, it haven't rubbed at all. I drive through the same exact roads that always rub and its as soft as it could be.
      01-18-2012, 02:11 PM   #227
TexasZed4MC
I just replaced the rear tires witht eh stock 255/40/18 on the M Coupe. The fronts will be replaced soon also is there any reason not to put 245/40/18 on the front stock 8" wheel. That will let me get very close to a square setup to use at the track or will this cause me to throw codes and had ABS issues?
      01-18-2012, 05:01 PM   #228
Finnegan
Finnegan's Avatar
Drives: Z4M/. Z3M, E36/46 M3
Folks have run 245/40/18s on the stock wheels for track use. It's pushing what you can fit in terms of tire on the 8" rim, and you won't realize the full width of the tire due to some compression (section width won't be as wide as on a wider wheel).
Here's a comparison grid I threw together awhile back and some other resources.
      01-19-2012, 06:23 AM   #229
Caddyshk
M = Midlife Crisis
Caddyshk's Avatar
Drives: 2006 Z4MC Interlagos
Our cars (2006) use the ABS sensors to monitor any relative change between revolutions across wheels to provide a tire pressure warning system - IIRC its > 15% sets off the low pressure warning. The key to mix and matching tires, beyond fit to rims and wheel wells, is to maintain no greater than a 3% delta between revolutions over a fixed distance mile/kilometre. In addition its recommended by the tire industry and installers alike to not mount different sets (brands, ratings, tread pattern etc.) front to rear.
2006 Z4MC - #LL93158
      01-29-2012, 10:42 AM   #230
_MM
_MM's Avatar
Drives: 2007 M Coupe
Front 19"x8.5" et 30
and
Rear 19"x10" et 22 will these work?
I have a set in mind but this is their limitations
Any more concrete info on this set-up? Assuming stock suspension and 245/35 F and 275/35 R.
Thanks!
      01-29-2012, 12:34 PM   #231
Finnegan
Finnegan's Avatar
Thanks!
Assuming stock you want 245/40-18 and rear:275/35-18. See link in post 228, which also links you to this which should provide more info.
      02-02-2012, 07:16 AM   #232
tomprest
Drives: Z4M Coupe E86
Hi
My brother is offering me his old 3 series wheels.
But the questinon will they fit on my Z4M Coupe E86 2007.
8.5x19" ET35
9.5x19" ET45
      02-02-2012, 01:36 PM   #233
Buryat
Drives: M3 E92 DCT
Hi,
Need your advice, what do you think about these sizes for my z4 mc:
Front: 19x8,5 et15
Rear: 19x9,5 et22
      02-02-2012, 05:40 PM   #234
Beedub
Originally Posted by Buryat View Post
Hi,
Front: 19x8,5 et15
Rear: 19x9,5 et22
that front is never going to happen on the z4m..... the rear will stick out alittle....
      02-02-2012, 05:43 PM   #235
RADRACR
RADRACR's Avatar
Agree on the front, but the rears are fine. I have ET20.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      02-02-2012, 07:10 PM   #236
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
where are all the et20 pics!
'07 MCoupe
lots of mods
      02-02-2012, 07:32 PM   #237
Finnegan
Finnegan's Avatar
Buryat, see this thread before considering an extreme change in offsets from the stock 42mm front for the M.
      02-02-2012, 07:34 PM   #238
zubydafa
tosser
Isle of Man
31
Drives: '07 Z4MC
i've seen RGR's on a few ZM's now. doesn't look like there's rubbing issues on stock ride height but what about a mild drop?
concerned about the rears....19x10et20.
'07 MCoupe
lots of mods
      02-03-2012, 12:06 AM   #239
Buryat
Drives: M3 E92 DCT
Thanks guys.
And what is ideal setup fot TE37 or TE37sl in 19"?
      02-03-2012, 01:28 AM   #240
tomprest
Red face
I need help
Can I use them on my Z4MC 2007
If I have to use spacers What size?
19x8.5 ET35
19x9.5 ET45
      02-05-2012, 06:16 PM   #241
_MM
_MM's Avatar
Is their any consensus of the most aggressive 19" setup (offset and tire size) that can be ran with a stock or slightly modified suspension?
      03-09-2012, 11:07 PM   #242
BIMMERGUY91
Drives: 2014 335I M Sport
do you guys think 18x9.5 et35 with a 245 up front and 18x10 et25 with a 275 in the rear will work. I am dropped pretty low on H&R coilovers and I know I will atleast need 2.5 degrees camber out of some camber plates up front.
2014 335i M Sport
2010 328i M Sport
2007 Z4MC #1019/1815 (Sold)
1997 M3 (Sold)
1991 325i
