      05-27-2009, 04:12 PM   #23
Chuck I
Chuck I's Avatar
Drives: '03 Z4 + '07 ///M Roadster
Build date
Originally Posted by nickpapa View Post
Chuck I was is your build date?
12/2002 is the build date... Chuck I
      05-27-2009, 04:17 PM   #24
Chuck I
Chuck I's Avatar
Connector
Originally Posted by Ron Stygar View Post
How many wires on the connector?
What colors are they?
It's a 6 pin connector with 5 wires.
Pin 1 Brown/Black
Pin 2 Slate (gray)/Red
Pin 3 Black/Slate (gray)
Pin 4 Green/Blue
Pin 5 Black/Yellow
Pin 6 Empty
I had a hard time seeing these because of the fact they are wrapped really tight and the lighting was not that good... The Slate (gray) may actually be white...
Hope this helps... Chuck I
      05-27-2009, 04:31 PM   #25
nlink720
Drives: 2004 BMW Z4 Roadster
I have a sport button.. wonder if there is a way to disable certain functions such as the increase in throttle sensitivity but still allowing the steering to be stiffer. Maybe severing the correct wire could achieve that, but then again it may throw a code too.
I may join you all in experimentation.
FS: Leather Recaro Pole Position Seats & Hardware
      05-27-2009, 04:43 PM   #26
Chuck I
Chuck I's Avatar
Unfortunately I don't have a wiring diagram. I have the TIS CD but it's no help.. It would be interesting to know where the wires go... Chuck I
      05-27-2009, 09:09 PM   #27
Ron Stygar
Drives: 2006 Z4 M Coupe
Pin 1 Brown/Black
Pin 4 Green/Blue
Pin 5 Black/Yellow
Pin 6 Empty
Pin 1 is BR/SW Brown/Black = Ground
Pin 2 is GR/RT Gray/Red = Dimmed lighting
Pin 3 is SW/GR/GE Black/Gray/Yellow = Power steering
Pin 4 is GN/BL/GE Green//Blue/Yellow = Power, fuse 7
Pin 5 is SW/RT/GE Black/Red/Yellow = To DME via module (VM)
Not sure this WDS print goes with your '03 car.
MVRS4.50
      05-27-2009, 09:12 PM   #28
Chuck I
Chuck I's Avatar
Hey Man THANKS! I've been trying to get the the WDS software to run online, but the diagrams don't come up.. This looks good! Chuck I
      05-27-2009, 09:24 PM   #29
Ron Stygar
      05-27-2009, 10:00 PM   #30
nlink720
Ron,
As you have consistently provided over the years, this is more great data. Thanks!!
Before I mess with anything, do you think there would be any harm in interrupting the pin 5 wire to disable the throttle change? (not looking to induce faults)
I really want to tun sport mode again, but autocross is much harder with the throttle being too sensitive. I want to get rid of that functionality, but keep the steering tighter.
      05-27-2009, 10:26 PM   #31
Chuck I
Chuck I's Avatar
Thanks Ron. I just checked and F7 does say Sport Button and there is a 5 amp fuse in it.. Looks like I'm ready to go.. Just waiting on the button. Chuck I
      05-27-2009, 10:41 PM   #32
Ron Stygar
Hope it works for you.
What's the last seven of your VIN number?
      05-27-2009, 10:44 PM   #33
Ron Stygar
Ron,
Don't know. You would have to try and see.
      05-27-2009, 10:47 PM   #34
Chuck I
Chuck I's Avatar
LS42659 - Chuck I
      05-28-2009, 01:18 AM   #35
Hawker 800XP
Hawker 800XP's Avatar
Drives: Z4
I thought about this all day... got home, removed the ashtray and button panel. I didn't see any cable. I then unsecured the gear lever cover and moved it to the side... I then started feeling the cables and noticed that the one on the left had two ends... one went to the gear shift lever and the other went under the carpet... I took a hook and pulled the carpet up next to the gear shift lever.... GUESS WHAT... There it was the connector for the sport button... My button is on order... when it comes in, I'm just going to plug it in and see what happens... I then have to cut the hole, but that's easy enough... I'll keep you posted... so far, this has taken about 15 minutes... Chuck I
Very interesting. As far as cutting the hole, I think the console is perforated underneath and just needs to be punched out.
      05-28-2009, 02:10 AM   #36
blade80
Drives: 2013 535i M sport
is it just for automatic tranny, or can be worked on manual as well?
and how much was the part cost?
      05-28-2009, 03:20 AM   #37
Matty C
Matty C's Avatar
Germany
20
Drives: 2007 Z4 M Roadster, 2006 M3
It might also be a difference between a 2.5 and a 3.0.
      05-28-2009, 06:29 AM   #38
Chuck I
Chuck I's Avatar
To me it looks like it should work for both. BUT, I won't know if it works at all until I plug it in. My hope is that the software is there... From the way the switch is built it looks like the light will function but I'll have to wait to see if the DME and the EPS will respond. I know that on my M, the Sport button make a difference so I'm hoping I'll be able to tell the difference here. There's another issue, your connector may not be there. As you can read above, JRA's car didn't have it... My car is a very early unit built in 12/2002. I lucked out. My suggestion would be that before anyone buys the switch that they check to see if the connector is there. You can get the switch for less than $80, probably cheaper if you shop around... Chuck I
      05-28-2009, 09:23 AM   #39
Hawkeye
Hawkeye's Avatar
No_Country
2070
Originally Posted by gearl View Post
that was my point it is kind of like taking off the 3.0si badge and replacing it with a M badge. When you order the sport package from the factory it comes with both the suspension and the shift change but it appears he has already upgraded his suspension.
Yeah, but if you can add a little functionality it is still worth it IMO. It is not like he is just switching badges (where did that even come from?)
If it was easy to change my 3.0 into a 3.2 (dumb example, I know) I would do it in a heartbeat. Would you give me crap cause I didn't have the steering wheel and suspension, etc from the M? I doubt it.
I think this is a good find personally
      05-28-2009, 12:09 PM   #40
caseysc
caseysc's Avatar
Drives: 2010 128i Conv.
2005 Z4 2.5i  [8.00]
The button is $59 + shipping for my '05 2.5i from Tischer BMW.
      05-28-2009, 02:43 PM   #41
Ron Stygar
See if you have the VM module.
~5 x 6" black plastic box.
In the back of the left front shock tower.
Will post a pic if I get a chance.
      05-28-2009, 04:53 PM   #42
Ron Stygar
VM Module
      05-28-2009, 05:39 PM   #43
z4dawg
Drives: Bright Red '06 3.0i Z4
Question
A starting point for Manual/3.0s/Newer models
I have a 2006 3.0i
I'm pretty new to getting my hands dirty when it comes to my Z but this interested me so I figured what the hell and I jumped right in.
First, I checked under the hood, and although I don't know what it means, I do have that black VM module.
Second, I got the knob and boot off (easy enough).
I was left with this (sorry, iPhone quality here):
After carefully (it wasn't difficult at all) removing the foam, I saw this:
As described, it's carpeted. I don't know anything about wires, and at this point the iPhone was really grainy in low light conditions, but this is what I saw along the left side:
I wasn't about to start pulling random wires but is the connector needed in this grouping? Or do I need to reach further under the carpet?
Don't know if any of this really helps...
      05-28-2009, 05:42 PM   #44
Chuck I
Chuck I's Avatar
Oh Boy.... No VM module... Not looking good... I'm going to try and see if I can find the cables x60191 and x60193. Chuck I
