07-01-2017, 07:10 PM | #1 |
Rep 66
GROM BT-3 Review
Not a lot of info on this unit, or first hand reviews on forums. Debated the various audiovox, aux/bt hardwired units, parrot offerings out there and finally settled on the GROM.
So far so good, signal is a little weak so it's recommended that place the unit in the cabin (I initially left it in the trunk @ the cd changer wires). If you don't have BT music and would like to, I wouldn't hesitate to recommend this one. Haven't tried any preset playlists or really know how that works, I just wanted to be able to skip songs with the car controls using pandora/Spotify. |
08-12-2017, 12:26 PM | #3 | |
Rep 66
09-01-2017, 01:53 PM | #4 | |
Rep 29
Drives: 2003 BMW Z4 3.0i 6 speed
Does it have ... 1) SD memory that is playable - 2) can it read a USB thumb drive with music on it? What did you use to relocate it (wires)? I believe it has ipod connections and Bluetooth although, I'm assuming the Ipod cable is sold separately? https://www.amazon.com/dp/B00FGAS448...=27NQ9S3KYC5W5 Please let me know how you get on with the Grom, I have brain ache trying to find a unit that meets what I'm looking for a 2003 z4 Business CD without multi player - yet to dig in the trunk for cables! |
09-07-2017, 03:38 PM | #5 |
Rep 162
Drives: 2008 Z4 3.0si Coupe
I have another version of the GROM (Model USB3 for trunk). I like it a lot. It took a while to wire everything up and I had to take apart all the carpeting and paneling in the trunk to install it. It was installed as a "CD changer". I fed a female USB cable through the center console so it's accessible via the center storage area (where the nav computer is). It came with a microphone but I chose to to use it since I have one built-in my steering column already.
I've worked with GROM customer support before and they're awesome. I bought mine with the DSP adapter but realized I didn't need it. I was able to send the adapter back and they refunded me for that portion. No questions asked. The version of the GROM I have allows for BT connectivity (A2DP), and has USB input. You can play music via USB but it only trickle charges your phone (no fast-charge due to low energy output). I have tested audio via iPhone (lightning) and Android phones (micro-USB). Audio works just fine. On very rare occasions BT doesn't sync up when I turn on my car, but I just fall back on USB. This model can play music via flash drives. Yes, my steering wheel and stereo controls can skip tracks in either BT or USB mode. Interesting side-note: You can pair your phone to both the GROM and your built-in BT for the car. However, on iPhones you cannot set which connection is for phone calls and which is for audio (i.e. music). It's all or nothing in this situation. Android users rejoice! You can actually set the BT connection to feed phone calls to your car (if you have the built-in BT module and mic), while simultaneously outputting music audio to the GROM unit.
2008 Z4 3.0si Coupe
Jsinghzzzz76.50 |
09-16-2017, 11:08 AM | #6 |
Rep 2,869
Drives: Anything
This is great to hear, I may have to spring for the BT module now. I had the same GROM unit for a few years now and really love it. Only complain is the minimum MP3 Tag display even on the NAV screen and some quirkiness with the controls. Being able to stream A2DP to it and keep the BT connection of the car is awesome
06-26-2020, 11:15 AM | #7 |
Rep 4
koruptor -
I know its been a few years but I am installing a GROM in my 04 Z4 with DSP, no Nav I am able to connect the 3 pin wiring harness and get everything but actual sound. The track I am playing is on the radio but no sound. I do not have the 6 pin connection wired because I cant find one and my best guess is that I need the DSP adapter. You said you didnt need it. Did you wire anything to the 6 pin plug from the GROM? |
06-26-2020, 12:45 PM | #9 | |||
Rep 162
Hey christophertemple.
It's been many years and I don't remember the details about the installation. Note: The following is assuming you are installing the trunk module, and not the one directly to the back of the radio. I was able to find this installation video by GROM. They appear to fish both connectors from behind the amp. Here's another video with a different BMW that shows the two connectors. As far as the 6-pin connector is concerned, I'm fuzzy on what I did with it. However, as I'm revisiting the docs right now it seems to be DSP-related. According to the GROM DSP doc, it refers to this as the analog DSP connector: Quote:
There are additional things worth double checking. Per the instructions for the USB3 Trunk module, they warn against connecting the 3-pin to the wrong connector: Quote:
I've had a good experience with GROM customer support. It may be helpful reaching out to them if none of the above helps. Good luck! Quote:
2008 Z4 3.0si Coupe
06-26-2020, 12:50 PM | #10 |
Rep 4
After a little more work and some more thread searching I found that some of the E85s did not have the 6 pin adapter. Some people swear they do and I even removed the subwoofer from the passenger side and made sure there were no wires or harnesses tucked away and it simply is not there.
The one thread I found on this the guy had to buy the DSP adapter after all because instead of a 6 pin, there is a coax/DSP plug which I have just like him, its on the same harness as where the 6 pin would have been located. I went ahead and ordered the $75 adapter. Thanks for the heads up. |
06-26-2020, 09:30 PM | #11 | |
Rep 162
Glad you were able to identify the issue!
2008 Z4 3.0si Coupe
07-13-2020, 05:37 PM | #12 |
Rep 2
Drives: 2003 BMW Z4
I can't figure this out at all - my amp is in the base of the trunk by the battery and I can't find the 3 or 6 pin connectors anywhere... any idea how far up the wires I'd have to go?
07-13-2020, 11:10 PM | #13 |
Rep 411
I had a look using google on the installation of the Mediabridge unit I have.... and some posts... as I said the . ..."wires were tucked underneath the bottom of the black center storage compartment, accessible only from the trunk bulkhead."
So... Lift up the bottom of the carpeting ... check the area of the bottom behind the metal crossmembers at the center of the bulkhead.... stick your fingers under and behind everything to locate it. This is the install guide that has info.... https://www.voxxintl.com/docs/common...500-BMW_OM.pdf
Sent from my smart phone...
