      04-29-2014, 03:36 PM   #45
3002 tii
3002 tii's Avatar
2288
Originally Posted by R0ME0 View Post
Great write up. I'm getting ready to complete my seat install too. What size torx screw is the seatbelt buckle fastened in with? None of mine seem to fit so will prob have to go out to buy a set.
I think T50, don't recall
Follow for latest mods
      03-15-2016, 04:57 AM   #46
Vanne
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
hows the occupancy emulator going? still good? one question i have, if you don't mind is how you have the stock seatbelt receptacle mounted and how do you buckle up the seat belt? do you have the receptacle coming into the seat through the side hole, or something else. would love a pic or 2
Powered by
      03-15-2016, 06:38 AM   #47
3002 tii
3002 tii's Avatar
2288
Emulator still working great. See this post:
http://www.zpost.com/forums/showpost...3&postcount=33
      03-15-2016, 09:47 AM   #48
Vanne
Vanne's Avatar
1621
Drives: 2007 Z4MC
Thats great mate, very cool. Hey question, is it not possible to just get the VAC 90 degree side mounts and mount them directly to the floor and then the chairs to them? Why the need for the ground adaptor, unless you have bottom mount seats ofcourse.. looking to order a few bits and pieces today. Also regarding no running sliders, you think this would be an issue with clearance at the rear of the seat base? Looking to sit lower than stock as I am rather tall at 6,1..
Powered by
      03-15-2016, 08:22 PM   #49
3002 tii
3002 tii's Avatar
2288
I don't think the VAC side mount holes are same size as the factory studs on the floor. Not to mention you'd have no adjustability so even if you got it work you'd have to use that one seating position (distance). The Swiss cheese pattern on the floor mounts is what let's you play with the right seating position.
If you're worried about height just don't get any sliders and choose the lowest seating position on the side mounts (there's 2 if not 3 vertical holes on most side mounts).
      04-10-2023, 04:24 PM   #50
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Originally Posted by MFGJR View Post
Couldn't you use the child seat airbag defeat switch (activated with key inside the passenger door jamb) to avoid this problem? Seems like that overrides airbag deployment with an occupied seat, which is what we'd want when driving solo.
Digging up from the grave. 3002 tii did anyone ever figure out if the airbag defeat switch is still function with this emulator?
      04-10-2023, 05:20 PM   #51
3002 tii
3002 tii's Avatar
2288
If you’re asking did I confirm if the airbag would ever deploy, fortunately/unfortunately no I never had chance to test it out lol.
86Zed932.00
      04-10-2023, 07:16 PM   #52
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
Glad to hear that. Ultimately asking if you can still toggle the airbag on/off with an emulator in place, using the factory key and airbag off (child seat) mode?
      04-11-2023, 12:00 AM   #53
3002 tii
3002 tii's Avatar
2288
Don’t have the car anymore but I recall the key still being able to enable/disable the airbag.
86Zed932.00
