      07-09-2015, 09:13 AM   #23
Incompatible
Drives: 07 AW Z4C 3.0Si
Originally Posted by Wolfelet View Post
Also did the front lip. Side skirts will follow soon.
Interested in your thoughts on the quality and fit of the side skirts. thx
      07-09-2015, 09:23 AM   #24
Wolfelet
'98 Z3 retired / '03 Z4 SMG Supercharged retired
Drives: 2009 Z4 sdrive 35i juiced
I've seen them in person on another car. They do not come with the internal screens, so that has to be figured out. Fit seems pretty good. They required some surface finishing, but not too much. I found a US based location that sells them for an awesome price. The one I saw had custom ducting done to make them truly functional brake vents. It doesn't seem that difficult. I'll keep you posted on mine once I get them. It'll be a month or 2 before I order them.
      07-25-2015, 11:45 AM   #25
Wolfelet
The lower piece is just a hollow core piece of fiberglass. After measuring 3.5 inches, I drilled holes through the lower piece. I then taped the risers in place to mark the holes. The risers are solid resin/fiberglass, so after the holes were drilled, I put in anchors to reinforce the union. I added some brackets on the backside for even more strength (they're not visible from the front). I have some screw caps that will cover the screws on the very bottom once the final test fit is finished so the screws cannot be seen. Then paint and install. Afterwards, new dual heat shielding from a Z4M along with the center tunnel cover that covers the relocated fuel evaporater box. Relocate the battery to the trunk and place a new floor cover to cover the hole left by the battery box being removed. Once complete, the true dual exhaust can be ran with straight pipes from the cats back.
      07-26-2015, 02:09 PM   #26
Wolfelet
Ongoing process
      07-26-2015, 08:06 PM   #27
Wolfelet
Completed rear extension
