11-28-2010, 09:50 AM | #2 |
Rep 2,431
I'm not sure what the psi should be but from my experience they ranged from 175-190, but what's more important is the deviation from each cylinder
F80 m3, 997 gt3, 14 ram ctd, f15 x5, drz400sm Gone:z4m, boss 302, c6 z06, m6,z3m |
11-28-2010, 05:58 PM | #3 |
Rep 2,460
my friend is running 160 across the board after his motor ate itself by way of a timing chain being eaten by the entire valave train....bmw is giving him the standard " go away" attitude. just trying to pick up som info....thanks
11-28-2010, 11:20 PM | #6 |
Rep 527
A compression test is done by replacing the spark plug in a given cylinder and cranking the engine over without starting it. The maximum pressure recorded from the compression created by cranking the engine is your compression test result. Compression tests are useful for diagnosing faulty piston rings, blown head gaskets, bent valves, or bad valve seals.
A leakdown test is done by placing the cam shafts at top dead center for a given cylinder to effectively "seal" the combustion chamber by closing both intake and exhaust valves and bringing the piston to it's highest stroke point, introducing pressurized air from an air compressor, and recording the percentage of air pressure loss that occurs. If the loss is higher than 10% or so, there are is likely valve damage, piston ring, or head gasket damage. One can also listen to the intake and exhaust tract for rushing air sounds to determine if a leaky valve is on the intake or exhaust valve train of the cylinder that is being tested or if no sound can be heard but air is moving into the crank case, then piston rings are the problem. Compression tests use less sophisticated tools and can be helpful in initial engine problem diagnosis. Leakdown tests help identify more specific problem areas to track down the actual culprit. Which type of test is your friend doing? I ask this because the results of a leakdown test are not given in PSI but rather a percentage of air pressurization loss. Also, compression test results will vary depending on the temperature of the engine. A cold engine will produce lower compression numbers than a warm one. As stated above, since there are many variables in the process, the actual number is not the most vital piece of information in the test, but rather the variation between cylinders. Last edited by JPWEraser; 11-28-2010 at 11:29 PM.. |
