11-02-2010, 04:50 PM | #23 |
///M-fanatic
193
Rep 3,885
That's odd...I had my trusted mechanic walk me through the install the first time around. When that showed increased vibration, I went back in and redid everything myself, knowing full well that I'd have to put pressure on the bushings prior to tightening down the nuts. I really took my time as well, to make sure everything was carefully addressed. However, I still am having vibration throughout the rev range. Perhaps it was the same vibration from before I did the mounts simply coming from the motor, and that when swapping the mounts I happened to pay closer attention to how the car felt?
11-02-2010, 05:08 PM | #24 |
Hooligan
55
Rep 680
what weight of rp syncromax should I ask my mechanic to order? 90 weight?
On another note, I am a little perplexed by the reports of problematic tranny mount installations. I watched it get done and it was a relatively low complexity procedure, I am surprised that anything could go wrong.
2014 Porsche Cayenne Turbo S 2011 X5 5.0 Dinan - SOLD 2007 Imola Red Z4 M Coupe -SOLD 2004 Navy Blue BMW 325Ci |
11-02-2010, 05:41 PM | #25 | |
M = Midlife Crisis
65
Rep 2,006
http://www.royalpurple.com/prod-pdfs/synchromax-ps.pdf http://www.royalpurple.com/transmission-chart.html
2006 Z4MC - #LL93158
11-03-2010, 09:15 PM | #26 |
Rep 2,460
just got my RE tranny mounts , almost put them in today my mechanic says we gotta drop out everything to include section of the exhaust and what not to do it right....any advice here?
11-03-2010, 09:43 PM | #27 |
Hooligan
55
Rep 680
my guy did it without removing the exhaust
11-04-2010, 12:40 AM | #30 |
Rep 1,543
I had the RE trans mount, CDV and RE clutch stop all installed at once a couple of weeks ago. The Clutch/Shifter feel in the MR, to me is the weakest link of whole the car, has improved tremendously. I don't have any increased vibration. The infamous 1-2 shift effect has reduced greatly, it feels tighter, slight more notchy but the feeling of click-click while shifting is pure joy. The whole shifting business just feel tight.
I don't have any experience with UUC mounts but I recommend RE trans mount to anyone. BTW, what's the forum consensus on the recommend mileage to change to Royal Purple Syncromax? None tracked MR.. TIA, |
11-04-2010, 01:31 AM | #31 |
///M-fanatic
193
Rep 3,885
You can use a jack and a wooden plank to prop the transmission bell housing up a little bit to gain some extra access room to slide the tranny mount bracket back in. That's what I did at least, since I didn't have the star bolt socket required to take off the section 1 piping.
11-04-2010, 10:29 AM | #32 |
Rep 1,143
You don't need to remove the exhaust. Just look at Blind32's DIY post. It's tight, but a 13mm box wrench (ratcheting type helps a lot) will work.
11-27-2010, 01:38 AM | #34 |
Rep 185
anybody know exactly how many quartz our tranny takes. i want to order the sychromax from royal purple but i also dont want to order too much
11-27-2010, 07:13 AM | #35 | |
Rep 37
- DERJ
11-27-2010, 02:05 PM | #36 |
Rep 2,866
11-28-2010, 05:22 PM | #37 |
Hooligan
55
Rep 680
A guy on 133 in laguna beach....Laguna Motorwerks.....75 bux. lmk if you're interested I'll give u his digits
11-30-2010, 01:28 AM | #38 |
Rep 2,866
His number/contact would be much appreciated. Did you have any added vibration after having the mounts installed as some have experienced? Thanks.
11-30-2010, 06:54 AM | #39 |
Rep 11,667
FWIW I had some very minor NVH right after installing UUC black mounts.
They settled in after a week & don't notice any NVH now.
