10-31-2010, 12:51 AM | #3 |
///M-fanatic
193
Rep 3,885
I put in my UUC "black" tranny mounts recently but there's a vibrational issue that I'm feeling throughout the rev-range whether I'm in gear or not. I was informed that I might've overtightened them, but I tried re-installing them today and made sure everything was only hand-tight, but I still feel some vibration. It's weird.
10-31-2010, 01:57 AM | #4 |
Rep 1,739
Drives: 2008 Z4MC
^^^ Just ordered those as well. Hope someone chimes in, because vibrational issues aren't what we signed up for. How's the shifting though? (before/after)
10-31-2010, 02:33 AM | #5 | |
///M-fanatic
193
Rep 3,885
If only we could switch back and forth between aftermarket and stock components at the touch of a button |
10-31-2010, 09:24 AM | #7 | |
Rep 1,143
http://www.zpost.com/forums/showpost.php?p=7979028 The key was removing the jack supporting the transmission after mounting the bracket but before installing the nuts on the actual mounts. I also went for an easy drive around the block, which further allowed the transmissions to settle to its natural resting state. Simply loosening the nuts and retightening them won't do anything (I tried that initially). |
10-31-2010, 12:52 PM | #8 | |
///M-fanatic
193
Rep 3,885
10-31-2010, 02:07 PM | #9 |
Rep 4,726
Define sloppiness more clearly. I don't find the transmission sloppy, but the shift selector and carrier bushings could be a little stiffer.
10-31-2010, 02:36 PM | #10 | |
///M-fanatic
193
Rep 3,885
In between shifts isn't bad at all, but getting into each gate is too crunchy/notchy imho, especially 1st and 2nd gear which are used the most. |
10-31-2010, 02:53 PM | #11 |
Rep 4,726
I like notchy transmissions, hate transmission that just go into gear, makes me think ok its there, but is it actually in?
10-31-2010, 05:15 PM | #12 |
///M-fanatic
193
Rep 3,885
10-31-2010, 05:28 PM | #13 |
M = Midlife Crisis
65
Rep 2,006
WHSRP Synchromax too...
2006 Z4MC - #LL93158
11-01-2010, 10:19 PM | #15 |
///M-fanatic
193
Rep 3,885
I'd say go with the UUC black mounts, Royal Purple Synchromax fluid, and AutoSolutions SSK.
Just got back from track day with the black mounts with stock tranny fluid and stock shifter. Am already decently satisfied. Can't wait for the AS SSK and tranny fluid when I'm out of warranty |
11-01-2010, 11:03 PM | #16 |
Hooligan
55
Rep 680
I just had the rogue engineering mounts installed today. I also have the UUC ssk and rk5 knob and am having royal purple swapped in next week. I have to say, of the three modifications, the rogue transmission mounts did the most to "clean up" the sloppy unpredictable feeling you are talking about. I have not noticed any increased vibrations in the cabin.
When the mechanic first put the car up on the lift and examined the stock tranny mounts he said they looked like brand new and thought it was unnecessary to change them. I insisted and when he took off the stock mounts their consistency was noticeably more rubbery than that of the rogue version. I can only assume that the result is greater stabilization of the tranny etc...
2014 Porsche Cayenne Turbo S 2011 X5 5.0 Dinan - SOLD 2007 Imola Red Z4 M Coupe -SOLD 2004 Navy Blue BMW 325Ci |
11-01-2010, 11:10 PM | #17 | |
701
11-02-2010, 10:03 AM | #19 | |
Rep 232
11-02-2010, 10:19 AM | #20 |
Engineer
212
Rep 2,122
Drives: M235I 2015, 335i 2011
I have the UUC red ones and I don't have any vibration, and it's a great improvement over stock.
11-02-2010, 12:36 PM | #21 |
Rep 1,739
Drives: 2008 Z4MC
^^^ Well if you don't have vibration, then it would appear that any vibration in the black UUC/RE units are an install issue; because the reds are that much more firm should translate even more through the system.
11-02-2010, 01:29 PM | #22 |
Engineer
212
Rep 2,122
I had installed by a shop since I had problems with bad install before, not using the proper pressure on it will cause vibration and premature failure.
