      01-04-2016, 01:42 AM   #397
AriuSen
AriuSen's Avatar
Drives: Z4M Coupe
Originally Posted by kklin View Post
FYI - I just put 18x9.5 et35 Apex ARC-8 wheels (all 4 corners) with 265 Star Specs with OE suspension and factory alignment. Only thing I needed to do was add 5mm spacers on the fronts so the tire's rim protector would not brush the strut. Installed wheel studs. Have driven ~75 street/highway miles with no problems.
This is while I wait for AST 4150s to become available at Vorshlag at which time I will get camber plates as well.
if you can fit 18x9.5 et35 with a 5mm spacer, does that mean I can fit a 18x9.5 et 22 with no spacer?
      02-23-2016, 09:10 PM   #398
ZeroDrift
Drives: 2007 Z4 M-Coupe
Having trouble determining if these wheels will fit and could use some guidance.
F: 18x9 +30 245-40R18
R: 18x9.5 +25 275-35R18
Based on the offset calculator, the front would stick out an extra 25mm. The rear seems like it would fit perfectly. Any guidance on this would be greatly appreciated! Purchased the tires, and the original wheels I had in mind are on back order for 2+ months.
      02-26-2016, 04:12 PM   #399
XMetal
XMetal's Avatar
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
For stock suspension and fenders, what is the best wheel combo setup if I want to run the following tire sizes?
F: 245/35/19
R: 275/30/19
For front wheels, I have the following choices:
19x8.5, 5x120, ET35
19x9, 5x120, ET32
For rear wheels, I have the following choices:
19x9.5, 5x120, ET25
19x10, 5x120, ET25
Thanks.
      05-10-2016, 10:26 AM   #400
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
Just wondering if I will get into trouble with these......
19x9 et31 with 235/35
19x10 et 25 with 265/30
On BC coilovers.
      05-10-2016, 10:41 AM   #401
RADRACR
RADRACR's Avatar
On BC coilovers.
I can't confirm but it "seems" ok. The rims will be very close to making contact on the inside. Probably nothing a 5mm spacer can't fix. Those tires are quite skinny for the rim width so that can only help make it fit. A stance look for sure with this setup.
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts
'09 X5 35dSpace Grey / Saddle Brown
20" Forgestar F14 / SCR Delete
      05-10-2016, 11:06 AM   #402
angelr
Drives: 07 aw/ir m coupe, 2013 S4
I don't think I ever posted my wheel and tire sizes in this thread.
HRE Fall Line R43
18x9.5 et 26 front 255/35/18
18x10 et22 rear 265/35/18
      05-10-2016, 11:07 AM   #403
RADRACR
RADRACR's Avatar
HRE Fall Line R43
Pics of front?
      05-31-2016, 01:54 PM   #404
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
I just put on Rival S in 255/40/17 on 17x9.5 ET35 wheels, square. Stock suspension. 5mm spacer up front to clear the suspension since I have camber washers for -2.7* up front. 12mm spacer in the rear so they are more flush. No rubbing in normal driving/parking but I have an autocross event this weekend so we'll see what happens. I had no rubbing with 2013 Rival in 245/40/18x9 ET38 and 275/35/18x10 ET25.
      06-05-2016, 02:24 PM   #405
tominizer
tominizer's Avatar
I know its been done but I can't find the details on how to make them work..... are the rims a direct bolt on or spacers required for an '07 Z4M roadster?? Sorry only had the car a few weeks and it came on snow tires for heavens sake......
BMW x5 wheels
19x9j et48 front
19x 10j et45 rear
BMW OEM Style 225's...... ??
Specs:
19x8 ET37 front
19x9 ET39 rear
      06-07-2016, 09:24 AM   #406
intoflatlines
I think front should be OK as long as you don't have camber washers. Rear should be OK but could probably use a spacer to sit more flush.
      06-10-2016, 11:00 PM   #407
intoflatlines
No rubbing. Short/tight course but it was good fun.
      07-05-2016, 07:57 PM   #408
Caosa
Drives: Z4MC TiAg
Hey guys,
Just wondering if these will fit?
Noteworthy: Looking to drop the car to fill the gap between fender and tyre after the wheels are fitted.
Front: 19x9.5" +23
Rear: 19x10.5" +38
If not what would I have to do?
Looking at picking up a set of semiforged wheels:
http://www.m3post.com/forums/showthread.php?t=1266813
      07-06-2016, 11:17 AM   #409
angelr
Originally Posted by RADRACR View Post
Pics of front?
Sorry I missed this. I don't have any pics hosted at the moment and can't get tapatalk to work...so below are a few links to some fb pics showing the front fitment. Pm me an email address and I can send you whatever you'd like to see.
https://www.facebook.com/photo.php?f...type=3&theater
      07-07-2016, 08:54 AM   #410
jns_e85
jns_e85's Avatar
74
Drives: '05 X3 2.5i, '06 z4M, '17 M2
I ended up buying a dedicated autocross 17" square set up from Tire Rack for my Z4M (Kosei K1 in 17x8.5 et 40 with RS-3 tires 255/40/17) and am wondering about wheel spacer needs.
The car is all stock suspension wise, with the alignment pins going to be pulled when the new set comes and is aligned to get more negative camber up front.
Tire Rack is providing 18mm spacers and longer bolts for the rear, but I am wondering if a front spacer is needed. Checked on willtheyfit.com and it looks like they will push in 4mm to the strut. Would there still be enough clearance that suspension rub will not be an issue?
Thanks!
2017 M2 - Camber Hubs, MPE, and some other goodies
2006 Z4M - Epic Tune / Eventuri CAI / Euro Headers / Stromung / FA 500 / AS SSK / Arc 8s
2004 Z4 3.0i - Gone, but not forgotten!
      07-08-2016, 10:10 AM   #411
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Originally Posted by AriuSen
anyone knows what would be required to run 275 square?
Can I use 18x10 et25?
I'm running 265 semi-square right now on 9.5" but different f/r ETS
FWIW I'm seriously looking at going back to staggered
      07-08-2016, 01:12 PM   #412
Beedub
currently running
8.5 x 18 ET 29
9.5 x 18 ET 23
absolutely perfect setup imo , very aggressive and zero rub, it will STILL rush the liners at the front edge of the front bumper in track extreme fully loaded , full compression but we are talking a scuff no where near to rub through the liner just mark it with the faintest of lines. Im also running semi slick tyres which tend to run wider also.
this stagger, offset and width really work after trying numerous wheel combos.
      07-09-2016, 06:30 PM   #413
Sanderskog
Drives: 2006 Z4MR
M3 Competition Wheels (OEM style 359)
19x9 front ET31
19x10 rear ET25
Tires are 245/35R19 in the front and 285/30R19 in the rear.
No rubbing. Love the look.
3002 tii2281.50
      07-21-2016, 02:24 PM   #414
rockstar93
rockstar93's Avatar
Drives: E86 Z4MC; E92 M3
I get a super deal on Fast wheels through work and since I need new tires, figured now's as good a time as ever for new wheels - but I'm not sure the specs they're selling me will work based on my own homework.
These are the options they have:
They're telling me 18x9 ET40 square will work, however I don't think that's right.
I'm thinking 18x9 ET30 square, perhaps with a small spacer in the rear if I want more of a flush fitment to the fender.
Anybody have any suggestions? I'm hoping I can figure something out because my cost would work out to be about $145(CAD)/wheel, for pretty light, flow-formed wheels that look half-decent.
      07-28-2016, 12:11 PM   #415
Shutterspeed
Shutterspeed's Avatar
Drives: 2008 Z4 M Coupe
Originally Posted by Beedub View Post
currently running
8.5 x 18 ET 29
9.5 x 18 ET 23
Stock suspension?
      07-28-2016, 12:12 PM   #416
Shutterspeed
How much trouble would it be to run:
18x8.5 +18 in the front on the M Coupe. I've seen 9.5 +26, and that's roughly an inch wider.
Any help?
      07-28-2016, 12:17 PM   #417
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
Why are you looking at a square setup??
      07-28-2016, 02:38 PM   #418
rockstar93
rockstar93's Avatar
Complete lapse in my thought process I will admit. I liked the idea of being able to rotate/swap wheels back to front. But then I remembered shortly after that post that I was going staggered tire sizes still so went back to 18x8/18x9 sizes (which dropped the price even more).
Now if only I could find somebody to code my TPMS to FTM I can save $250 and order new wheels.
